09-14-2011, 12:10 AM | #45 | |
108
Rep 697
No undue rotor wear. I got 30k out of the oem rotors before they wore to min specs. You'll probably have to scrap the rotors due to cracking before you wear them down to min thickness. |
09-14-2011, 12:29 PM | #46 |
36
Rep 910
When you guys change out your oil, do you just use an extractor and keep the oil filter (changing out the oil filter at the 15K intervals)?
E90 M3: Some cool stuff...more to come
Ducati 1199 Panigale: Bucket full of mods |
09-14-2011, 02:56 PM | #47 | |
90
Rep 1,315
09-14-2011, 02:58 PM | #48 |
90
Rep 1,315
I changed when my engine oil temp overheated or about 2-3 track days depend on how hot the oil temp gets. Always change the oil with oil filter together.
09-14-2011, 03:03 PM | #49 |
36
Rep 910
Please post pic and DIY.
09-16-2011, 04:42 PM | #51 |
Bulldog
482
Rep 3,355
What cooling plates did you use? Any pics?
Prev: Individual F80 M3 - Fjord Blue/Silverstone(interior) | Fashion Grey(exterior)
GTS |
09-16-2011, 05:58 PM | #52 |
11818
Rep 23,187
Mine feels like its wearing out and I am going to be forced to buy a BBK and coilovers
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
09-19-2011, 04:52 PM | #53 |
90
Rep 1,315
I don't know. I believe it's custom made. I'll take some pic when I jack up the car next time.
For the brake ducting, it worked perfectly. If the inconsistent braking gets solved by brake ducting system, then I have 4 guess for the root of cause: 1 my AP bbk can't handle heat; 2 mintex brake pads can't handle heat; 3 BMW didn't build any cooling for the brake; 4 the issue Martin has addressed. |
09-19-2011, 07:59 PM | #54 | |||
376
Rep 8,033
If ABS is not working properly in certain conditions (which could be an issue with the modified bias of an aftermarket system), you might not always feel something significantly different in pedal feel, but can experience significant differences in stopping power/distance. One can usually observe what I mean when trying to threshold brake at a bumpy braking zone vs. a smooth one on the same day at the same track. (Of course, braking on a bumpy section complicates traction as well, which also factors into ABS operation). Anyway, I am speculating and there are many potential causes that might explain the inconsistency.
11-16-2011, 07:09 PM | #55 |
97
Rep 3,246
Well, to keep things on track (pun intended )the car has been holding up great! Have put close to 30 track days on my e90, 25k mileage in total and no concerns whatsoever. I've changed the oil more frequently, every 2-4 events, only a brake flush in the beginning of the season and one bleed thereafter (last 2 years) and have gotten almost 15k out of my AD08's and almost as many track days and the only reason I had to replace at all was due to potholes and a slow leak in the rear, which was just once, so the replacements have been staggered (tough to get a true timeline) but am very impressed with the Advans. Went through 2 sets of race pads this year and a set of rotors which can be pricey, but that's with a shade over 20 events this year Plan on a smaller season next year so who knows but will report back. Would love to hear from people with 50 track days or even better 100. Am trying to stay away from making this, or getting, a dedicated track car, and am really curious about the durability of this car as I plan on testing those limits. I bot it and I plan on using all of its all-aroundness to the max
mods: track ready stuff
05-26-2012, 07:48 AM | #57 |
150
Rep 2,278
I have 40+ track days and 43,000 miles and so far so good. Also my AP brake kit is flawless other than occasional brake groan on the street since I started using Pagid yellows front and rear.
2015 f80 M3, 2016 GT3
05-26-2012, 09:40 AM | #58 |
30
Rep 915
I have a good 40 days at the track in my E92, all at VIR. Stock everything except for PF Race pads, SS brake lines, Apex Rims with BFG R1 275X35X18 compounds sq setup. Brake fluid, oil, filter change at the beginning of the season, checked prior to each event. Have used no oil. Note, my car is not run all that hard each session, however, it does see some agressive driving during every event. I too am struggling with what to do going down the road, seats, restraint, roll bar, suspension, brakes. I think that I will leave the status quo in tact.
vz
Previous Track Toy |
05-26-2012, 10:23 AM | #59 |
1580
Rep 8,077
Drives: 11 E90 M3 Individual
I've beat on my E90 for 6 days over the last month and a half. Not even a year old and its at 17k miles! I'm on my second set of PF01s...the car eats brakes!
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
05-30-2012, 04:45 PM | #60 |
Retired Curmudgeon
2989
Rep 4,056
Had my first track day last Saturday. Car was pretty easy to drive considering how big and heavy it is... This was not a planned track day for this car. A broken car forced a last second switch to this car. 5k miles on the car. My experience level is long and sordid (raced for 10 years, instructor, etc., etc.), though I have no remarkable skills.
Brakes became an issue when I decided to be more aggressive in two pretty heavy braking zones (Spring Mountain Motorsports Ranch in Pahrump, Nevada -- 3.2 mile configuration). Pedal went squishy and stayed squishy. Pressure bled the brakes the next morning and there were no noticable bubbles. The cheese grater brake rotor holes were full of stock pad material (have others seen this?). Clearly, PF-08's would have been a better pad choice, but I wasn't planning on using this car so it didn't happen (I don't have a set of performance pads for this car...). I had a few drops of power steering fluid on the reservior after the event. No noticable oil consumption per the idiot gauge in the dash. No temp issues, but we had absolutely amazing weather with high temps in the low 70's (unheard of). Great day all around!
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
05-30-2012, 06:10 PM | #61 | |
Havin' a blast!
125
Rep 4,847
BRP 1:56 | CVR 2:01 | ACS 1:53 | WSIR 1:34
05-30-2012, 06:40 PM | #62 |
Retired Curmudgeon
2989
Rep 4,056
Pad "knockback" is a phenomenon that happens with BBKs sometimes. Tapping would push the pads back closer to the rotor and leave you with less pedal travel and a more solid 'feel'. Worth a try to see if it helps or not.
06-01-2012, 10:22 AM | #63 |
640
Rep 3,039
Can anyone comment on how their car has held up to the wear? Do your front bumpers/hoods get blasted with debris?
Also, do you think all the tracking will have a substantially negative impact on resale value? I have 35k miles on my car, no track days, the car looks brand new as I've kept really good care of it. I'd like to get into tracking and use my car. I'm afraid of things getting beat up badly. |
06-01-2012, 10:50 AM | #64 |
1580
Rep 8,077
Oh yes, plenty of rock chips on the sides. Not so many on the hood but I have a clear brea on the bumper and front part of the hood up to the bulge.
Without the bra...my car's paint would be looking terrible.
06-01-2012, 11:28 AM | #65 |
11818
Rep 23,187
i bought mine used and made the mistake of not getting clear bra anyway even though there were a few chips. now there are tons. the front fascia and hood need a respray at this point due to tracking.
06-01-2012, 09:38 PM | #66 |
127
Rep 938
