08-22-2018, 09:10 PM | #1 |
216
Rep 982
Hardware For Race Seats - Master Guide
Surprised to find that a search yielded few results with real useful information, and it would be nice to have a master seat hardware thread to compile everyone's thoughts and experiences.
I have had RECARO PP / SPG seats a couple times over the years, and each time I used the provided RECARO side mounts and sliders an paired them with Macht Schnell floor mounts. This time around I have RaceTech 4009HR (driver) & 4009W (passenger) seats with "stealth covers" coming, and not quite sure how I want to address hardware. I will be running harnesses and hans, but will keep the factory 3 points in place for occasional weekend driving. I do not necessarily need sliders since this is not a daily driver, and I also like a lower seating position anyways (the stock E92 seats are like driving a school bus due to the folding mechanisms). RECARO and Sparco seats, followed by Cobra seem to be the most popular within the M community, but who here is running RaceTech seats? I have heard a few times that you must purchase RaceTech's side mounts for their seats, is that true? Most race seat manufactures offer side mounts, and it probably makes sense just to go with them since they are made specially for their seats. Any objections? What floor mounts do you like, and why? What has worked well for you, what has failed or caused problems? Little to no flex and safety is priority of course. Popular Floor Mounts: VAC Macht Schnell Wedge Engineering Bimmerworld Brey-Krause - Floor mounts and side mounts built in one. Leaning in this direction if I can get confirmation they work with the RT seats For those running 6 pt harnesses, did you need to buy sub brackets additionally or were they designed into your seat base?
08-22-2018, 10:30 PM | #2 |
2746
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Brey Krause is all you need to consider. Everything else is mediocre compared. BK has sub strap and lap belt accessories to accommodate. Using OE sliders is so smooth, plus they go in and out with ease. I can't tell you how much I cursed the other mounting options. I have used Recaro, Vac and Cobra side mounts, Recaro, Sparco and Vac sliders, Vac, Macht Schnell and Planted floor mounts. The BK solution is far easier to use and yields far better results.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 08-22-2018 at 11:31 PM.. |
08-22-2018, 11:02 PM | #3 |
197
Rep 283
I have BK fixed mounts and sub strap bars. I think they’re great..other options look like a PITA to use, but I can install or remove my seat in less than five mins. You can also get pretty low with them.
You probably have a different body shape than me, but I think Racetech seats fit me very well and are the most comfortable seats I’ve sat in. Edit: I’m looking at the dimensions of the standard sized seat, and I don’t see why it wouldn’t work with a BK seat mount. 400 mm seat width would work with the 395–409 mm mounts. If seat width is staggered, you can add washers to square up the seat mounts (someone let me know if this is an acceptable solution)? I think not using RT seat mounts will make the setup non-FIA compliant, but I don’t think anyone here is competing in an FIA racing series. https://racetech-usa.com/shop/seats/...torsport-seats Last edited by SQ13; 08-22-2018 at 11:14 PM.. |
08-22-2018, 11:45 PM | #4 | ||
216
Rep 982
08-22-2018, 11:55 PM | #5 |
2746
Rep 6,734
Yes, you can get a low seating position. I will say that my current seat height is a little higher than I would like but I have sufficient helmet room (I'm 5'11"). I have lower mounting points available on the side mounts but I think that the position of the sub-strap mount could limit how low I can place the seat. I have been meaning to look at that more closely and will try to do so on Friday.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
08-23-2018, 05:21 AM | #6 | |
1571
Rep 2,871
And I have the BK bracket mounted on the OEM power mount. Awesome. The only way I can get the sub strap bar to work is if I mount the Recaro on the 4th holes. The seat almost touches the ceiling. Way too high. (As you expect based on my other thread, I tried the seat in Every hole combination to try to get the sub strap to work) I use the first hole in the front and the second hole in the back and I'm long torso 5'10" My only option for sub strap 6-point is to drill the floor, but I don't want to lose the subwoofer. It is going to be a project. |
AP3X_FTW215.50 |
08-24-2018, 09:46 PM | #7 | |
216
Rep 982
Appreciate the feedback. I contacted BK in regards to the two different types of floor mounts, and this was their reply: "RaceTech is the only brand of seats that sometimes has different front/rear mount bolt hole distances than every other seat on the market. From what I've seen to date, this has been limited to their 1000 series of seats, but if you could measure the distance between the front/rear hole I can confirm. That said, almost certainly it'll work. The sub strap clearance varies by the seat-- with the seat having a flat bottom like the 4009W, it likely will need to be in a high position to clear the sub strap. In cases like that, unless you're short, the above slider sub strap mount isn't a great option-- in that case, I'd go straight to the floor. Annoyingly, the is just no way to mount the sub strap lower with the stock sliders. To make the R-9280 be able to clear the tunnel with wide seats, we had to place the seat slightly off center (outboard). Since your seats are in the narrow end of the R-9280's range, I'd go with one R-9280 and one R-9281. By combing the parts from both, you can put the seat back on center on both the driver and passenger side, without spending any extra, and need less spacers (probably none). Or, you could use the R-9260 without sliders, which will allow plenty of space for our sub strap mount with any seat-- but at the expense of sliders." Confirmation that it is not possible to use middle to lower mounting holes on the R-9280 floor mounts with OEM sliders due to the sub bar floor clearance (unless you have a seat that does not have a flat bottom). This in combination with the seat needing to be offset to clear the trans tunnel is enough motivation for me to use R-9260 mounts directly to the floor - at lest for the drivers seat.
slicer2745.50 |
09-23-2018, 11:11 PM | #8 |
216
Rep 982
Thread update. Racetech 4009W seats do not work with Brey Krause R-9260 seat mounts, despite the seat falling into the allowable width range outlined by BK. The distance between the mounting holes on the seat are about 1/3" further apart than the BK mounts unfortunately.
It looks like I'll be running Racetech mounts and the BK sub strap bar afterall. The Racetech mounts are silver, otherwise I would have gotten them in the first place. Since everything in the car is black and I have a bit of OCD, I was really hoping the BK's would work out. I'll just powder coat the Racetechs
09-24-2018, 11:38 AM | #9 | |
197
Rep 283
09-24-2018, 01:02 PM | #10 | |
2435
Rep 11,669
(more info here)
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
09-24-2018, 04:04 PM | #11 | |
216
Rep 982
I am actually going to explore this option tonight. I believe the front slots on the BK mounts are already pretty close to to the edge, but it might be feasible.
09-24-2018, 06:59 PM | #12 | |
///M Powered for Life
11502
Rep 10,334
I bought the full Recaro sliders plus the Macht Schnell seat mount hardware and it was a bunch of shit. There's no better way to put it. The experience with BK seat mounts that allow you to reuse OEM sliders is light years away from those dark days. The BK stuff is so superior that if a seat I wanted to buy does not work with BK mounts I will look for another seat. It is a night and day difference |
09-24-2018, 08:42 PM | #13 |
1571
Rep 2,871
Here is an alternate sub strap location for the BK sub strap. Ian from BK REALLY liked this solution, but it modify the OEM bracket.
. Credit goes to Autocouture.. . |
06-14-2021, 01:56 PM | #14 |
90
Rep 363
If I have power sliders would using the BK sliders for OEM retain the power sliders? What If I want to use the BK sliders with a manual slider and not power to remove most of the weight there. Would I have to source bmw oem manual sliders then attach the BK seat mounts to the new manual sliders?
06-14-2021, 02:08 PM | #15 | |
3996
Rep 3,412
You could use the same BK side mounts on a pair of oem manual sliders too. Just need to source those which can be hard. Look for i3 seat mount on eBay.
Not a Doctor, those are just my initials.
06-15-2021, 10:55 AM | #16 |
27
Rep 38
I have VAC floor adaptors with Recaro sliders and VAC side mounts. I'm really happy with this setup although it is expensive!
Brey-Krause unfortunately do not have an official supplier here in the UK otherwise I would have looked into them. I am quite interested in their harness assembly for the E90 though as they seem to be the only people who make one. $800 though! |
06-15-2021, 05:52 PM | #17 |
Derbo Tuning
3612
Rep 3,026
Bride also makes a bottom and side mount with sliders built in.
It should fit a bunch of seats as well. One of the locals theunholy has it in his car and its nice quality. https://www.dsgperformance.com/bride...2-us-passenger
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
08-17-2021, 05:59 PM | #18 |
90
Rep 363
Anyone here use the Sparco seat base, sparco sliders, and sparco side mounts with a sparco seat (qrt-r). I want a direct seat swap so I do not have to take apart the stock seat ideas to use power for the BK mounts.
03-07-2024, 12:13 AM | #19 | |
Rep 75
Sorry to bump up an old thread but what exactly was the modification you made? I can’t seem to follow. Thnx! |
03-20-2024, 12:08 PM | #20 |
1567
Rep 672
Macht Schnell Clubsport mount is a super easy, secure and light option. A lot of people remember the Macht Schnell and VAC old style mounts which were just heavy pieces that required a lot of assembly, but the clubsport mount does not. Includes anti-sub and sliders. Have run it in the E92 since day one and just used it again for a passengers seat.
https://www.sub2speedhouse.com/colle...nell-clubsport
03-21-2024, 12:17 AM | #21 | |
3996
Rep 3,412
berns1566.50 |
03-31-2024, 10:53 AM | #22 | |
126
Rep 290
