07-25-2023, 08:03 PM | #23 |
35
Rep 46
Chiming in…
I got the StoNSho model for the M Sport without adapaptive cruise control. stoNSho Some pics attached. Excuse the background. |
mm340i28.50 calbearz2435.50 |
07-31-2023, 11:02 PM | #25 | |
Rep 60
Drives: BMW M340i
Amazon says Sto N Sho is less than one pound in weight, so only need to worry about wind resistance. I also have the OEM bracket, was going to 3M that on, but the pegs where you screw it on stand off a bit much. I will have to use 3, or 4 strips of tape on top of each other just to start clearing those. Choices.... Just want to take my car off probable cause mode |
08-02-2023, 11:50 AM | #26 |
35
Rep 46
StoNSho is quick release. On my 2023 330e M Sport I mounted the bracket under the front lip. The plate holder slips into two holes and locks into place via a spring loaded pin. Just pull the pin and slip the plate holder out.
08-07-2023, 05:57 PM | #28 | |
35
Rep 46
In my photo above, I do NOT have adaptive cruise. You can see some holes where the sensor panel thing can be attached, but it’s not there. Hope that helps. |
08-19-2023, 07:11 AM | #37 |
71
Rep 64
Drives: 2023 BMW M340i xDrive
08-19-2023, 03:19 PM | #38 |
29
Rep 82
08-19-2023, 08:47 PM | #39 | |
71
Rep 64
Code:
Currently not available on cars equipped with Adaptive Cruise Control (Large sensor in the middle of the lower grille) from 2022-2024 |
mm340i28.50 |
08-28-2023, 12:49 PM | #40 | |
29
Rep 82
08-29-2023, 07:21 AM | #41 |
71
Rep 64
10-05-2023, 07:20 PM | #44 |
Rep 3
I also wound up going with Slybrackets, and also did not install the leveler. I did buy the leveler but found it wasn’t needed and would have pushed the plate further away from the car, so I didn’t install that extra part. Yes it is off center (which I was also trying to avoid), but I didn’t want to wait anymore and the Slybrackets one does seem to be high quality.
I originally bought the Carbonio one (before they added the disclaimer) and can confirm it doesn’t work for LCI. If you don’t have the adaptive cruise control, the Slybrackets one should fit centered in the lower grill. |
mm340i28.50 |
