why is there big dips in so many n55 dynos?!?....answer inside
02-02-2011, 03:42 PM | #23 | |
103
Rep 3,460
I did all that on stock boost control hardware. Last edited by Clap135; 02-02-2011 at 03:47 PM.. |
02-02-2011, 03:56 PM | #25 |
103
Rep 3,460
And what is that suppose to prove? Like I said show me a stock turbo dyno.
I owned that car for two years. To this day no one has beat my stock trubo trap speed or dyno number. Yes I do know why boost stops at 22.34, same reason on the n54. Last edited by Clap135; 02-02-2011 at 04:03 PM.. |
02-02-2011, 04:03 PM | #26 |
34
Rep 522
congrats on your record.
i'm not trying to prove anything, that is just a log of a MZP 6 with a GM boost controll solenoid tuned trough a accessport with ATR, belive it or not.... |
02-02-2011, 04:07 PM | #27 |
103
Rep 3,460
02-02-2011, 05:34 PM | #31 |
103
Rep 3,460
This is the real subject. People are claiming the wgdc do not reflect the actual wg position. Some claim by switching boost control hardware, the wg position will be correctly reflected
02-02-2011, 06:41 PM | #32 | |
34
Rep 522
the wgdc is not wastegate position. it represents the boost solenoid's duty cycle, whether it's vacuum or boost assisted. listen, I'm not saying that were going to figure out a way to put a GM BC solenoid and magically the turbo is going to happily hold PSI to 7k RPM, and that the DME is going to be "happy" with this..... what i am saying is that sometimes there is a hardware limitation, and that sometimes it can be worked around. |
02-02-2011, 07:01 PM | #33 | |
1740
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
In the case of the n54/n55, which has vacuum actuated wastegates, it works by opposite means. But the idea is the same. It's unlikely we can find replacement flyback solenoids with larger orifices. But we can effectively do the same thing by increasing the mechanical tension of the wastegate actuator. I guess we will see soon enough... shiv |
02-02-2011, 07:06 PM | #34 | |
798
Rep 4,784
ERnie
2016 BSM/f80/ZCP |
02-02-2011, 07:24 PM | #35 | |
103
Rep 3,460
Trust me i know how wastegates work |
02-02-2011, 08:09 PM | #36 |
34
Rep 522
^^^it was a stock turbo car....but i realize that this is not going to get anywere with you, your going to belive what you already belive and that's fine.
i tried to use a simple example of a simple concept and you took it personal, aparently because of your "record". so let's just let the thread stay on the original subject and go our marry ways. |
02-02-2011, 08:17 PM | #37 |
657
Rep 8,801
damn.
FrankiE90 AKA:.[The TANK] *CLICK THE SIG
E90s (been gone but not forgotten) • KW clubsports • • • • • • • • • • 18" BBS GT4 // Build E30 (pending) + E46 M3 Wagon ESTORIL Blue |
02-02-2011, 08:35 PM | #39 | |
103
Rep 3,460
02-03-2011, 06:55 AM | #43 |
70
Rep 1,565
Looks pretty clear that the boost is overshooting by the graphs, then it is closing the throttle, then it slowly ramps back up from there on out. The HP dips also.
2020 M340i: Dravit Grey Mettalic. Loaded.
02-03-2011, 06:58 AM | #44 | |
70
Rep 1,565
23psi...that is probably close to it's peak and sounds about right to me.
