2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications VANOS Solenoid Replacement
      06-17-2020, 03:35 PM   #1
David_Vasha
David_Vasha's Avatar
35
Drives: 2011 535i XDrive
Has anyone had any good luck with aftermarket VANOS solenoids? Thinking about buying Beck/Arnley brand solenoids since they are a solid manufacturer for BMW.
      06-17-2020, 07:29 PM   #2
beegeezy
beegeezy's Avatar
70
Drives: 2013 535i M-Sport
They might be reboxed OE parts too. I’ve had that happen with B/A before with other cars.
      06-17-2020, 08:58 PM   #3
David_Vasha
35
Originally Posted by beegeezy View Post
They might be reboxed OE parts too. I've had that happen with B/A before with other cars.
I've been thinking the same thing too
      06-17-2020, 08:59 PM   #4
Trainwreck914
Trainwreck914's Avatar
132
Drives: BMW F10 F15 E39 E90 E53
Not sure who is the or supplier. Usually fcp will have that info. But they only show Bmw for $$$
      06-17-2020, 09:16 PM   #5
David_Vasha
35
I'm thinking going with beck Arnley or gates should be fine. I just can't justify buying ONE solenoid for $180z
      06-18-2020, 08:04 AM   #6
OnlyGerman
OnlyGerman's Avatar
364
Drives: F15, F13, F10, E60
When should these be changed?
      06-18-2020, 10:43 AM   #7
David_Vasha
35
I believe you change them once they start throwing codes and mess with the smoothness of the idle and whatnot.
      06-19-2020, 09:52 AM   #8
David_Vasha
35
Has anyone made bought aftermarket (reputable brand) before? How was it?
      06-19-2020, 09:05 PM   #9
Wht550jersey
13
Drives: 2011 550i
50k -80k should be cleaned or swapped
      06-21-2020, 03:00 AM   #10
HotSpicyChicken90
22
Drives: BMW 535i
OE manufacturer is Pierburg
Cleaning the solenoids is more then often enough. Be sure to clean them from the INSIDE OUT!
Spray the brake cleaner on the inside until it flows out.
      06-21-2020, 09:11 AM   #11
brz62
15
Drives: 2012 BMW 550i xdrive
Be sure to clean the filters as well.
      06-21-2020, 10:28 AM   #12
David_Vasha
35
Will do. Thanks
      06-21-2020, 09:57 PM   #13
David_Vasha
35
Just changed the oil today and the idle issue that I have has gotten better. This further leads me to believe it could be Vanos if it's oil related.
      06-22-2020, 07:06 PM   #14
Trainwreck914
132
Anyone find the pierburg equivalent? I'd like to change mine also. But can't justify the $180 for bmw
      06-22-2020, 08:10 PM   #15
David_Vasha
35
I believe the website autohauz has them. They go for about $85 each
      06-23-2020, 05:39 PM   #16
Trainwreck914
132
Thanks found them.
      06-25-2020, 12:02 PM   #17
David_Vasha
35
Thanks found them.
Let me know if you buy them/install them
      04-02-2024, 11:16 PM   #18
ashmailusa
Drives: F10 535 Xi
Hey folks!
I don't have any codes, but my idle is rough at times(on cold), low power on low RPM, bad fuel milage - a lot of match in the symptoms.
Solenoids were cleaned once by dealership during previous ownership of my car.
Can' decide on what I should do with the solenoids. I've read mixed success stories about cleaning with 5-10V activation. Some claim replacement is the only option..
I was also looking into OE replacement options: a lot of positive reviews about Dorman.
Interesting find: SKP branded number SK916717 almost completely matches DORMAN part number 916717. Do yo think one of them is just repackaged version of the other brand? SKP is $30 vs $80 for Dorman
I would appreciate your input!
Cheers,
Alex
      04-03-2024, 06:39 PM   #19
Conserve
186
Drives: 1976 BMW 2002 & 2015 BMW535i
So, looked up DORMAN (part # you gave) then I did confirmation fit that was good but look at the review. People saying IT ALMOST FIT, which I say it is not good enough.
      04-04-2024, 09:16 AM   #20
ChiltiCoatl89
ChiltiCoatl89's Avatar
1775
Drives: 2016 F10 BMW 535i M Sport
Originally Posted by ashmailusa View Post
Hey folks!
Cheers,
Alex
Do not accept anything Less than BMW or OE Equivalent for these solenoids, spend the money upfront for the quality part(s), rather than spend money more than once for possible multiple issues in the future.
      04-05-2024, 03:51 PM   #21
Surly73
535
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
I'll pile on here.
Personally, I would not go any "lower" than the Pierburg units (offered by FCP and others like Rock Auto). Even those are classed as "aftermarket" and not "OE" or "OEM" by FCP so you might still be taking your chances.
Appreciate 2
5post
