12-13-2014, 11:06 PM | #1 |
274
Rep 2,665
Drives: Goggomobil
Thud in the drivetrain with test pipes and tune
I have been experiencing some run-over "burble" and a thud when I take the foot off the accelerator since I installed test pipes and tune. The smoothness that existed with the primary cat when you abruptly took the foot off the "happy" pedal is no longer there.
Is it just me and my car, or anyone else have experienced this too? I have test pipes with BPM Stage II. This is in no way a criticism of the tune or the test pipes, but just trying to understand whether it's normal. I've been wanting to post this for a long time but somehow have been forgetting.
F86 X6///
12-14-2014, 12:13 AM | #2 | |
165
Rep 1,790
Stupid Photobucket
12-14-2014, 04:26 AM | #3 |
274
Rep 2,665
Drives: Goggomobil
Thanks for the feedback. Good to know it's normal behaviour.
F86 X6///
12-15-2014, 11:52 PM | #4 |
Rep 10
I have a similar setup but with a different tune. I get a thud or a jerk letting off the throttle at low gears and high gears at mid to high rpms. Is there a way to soften this with the tune configuration?
Thx |
12-28-2014, 10:08 AM | #7 |
274
Rep 2,665
Drives: Goggomobil
So then why do you feel it more in a catless setup?
F86 X6///
12-28-2014, 09:55 PM | #8 |
254
Rep 551
Burble
Just guessing but the front cats seem to add enough back pressure to limit any sudden changes in exhaust gas flow resulting in the 'thud' that is appears when they are removed. if the car was engineered without the front cats then I'm sure there would be no thud, but it seems that we are tinkering with a balanced design..... I just don't get that we haven't heard about this before....
12-28-2014, 10:23 PM | #9 | |
274
Rep 2,665
Drives: Goggomobil
F86 X6///
12-29-2014, 12:09 AM | #10 |
118
Rep 621
Drives: 2008 Jerez Black E92 M3
this is news that concerns me as I am about to do test pipes, x pipe swap and tune mods. I need to ride in your car aussiem3.
Jerez Black 2008 6MT with Borla Atak Exhaust/ M3 World X Pipe and Test Pipes/ aFe Pro Stage 2 Intake / 19" Advan DZ-DF Forged Wheels wrapped in ContiSport Contact 5P 245/35/19 Fronts & 285/30/19 Rears/ KW Var 3 Coilovers / BPM Sports Stage 2 Tuned/ VAC Rod Bearing Replacement / Throttle Body Actuator Gear Set
12-29-2014, 12:32 AM | #11 |
Rep 10
In my case, the thud/jerk is more pronounced with the tune than with factory software. I have had my car into the dealership and they checked for faults and made sure there was no wear with engine or other types of mounts, therefore I believe it is "normal" for primary cat delete + tune
Is this a symptom specific to 2008 models? Is there any reason to believe this is caused by flywheel in 2008 that was changed in later models? |
12-29-2014, 01:20 AM | #12 |
274
Rep 2,665
Drives: Goggomobil
Let me know when if you can't wait till the next coffee catch up. I am happy to do it sooner
F86 X6///
12-29-2014, 01:22 AM | #13 | |
274
Rep 2,665
Drives: Goggomobil
F86 X6///
12-29-2014, 10:15 AM | #14 |
254
Rep 551
Aussie, how about changing the title of the posting to see if others are experiencing this ..... 'Thud in drivetrain after test pipes and a tune, anyone else?
12-29-2014, 11:30 AM | #16 |
BimmerPost Supporting Vendor
3388
Rep 7,542
Flash the car back to stock, this isn't something the tune should cause. Try normal mode instead of power.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
12-29-2014, 04:55 PM | #17 |
274
Rep 2,665
Drives: Goggomobil
Good point. Done
F86 X6///
12-30-2014, 02:51 AM | #18 |
532
Rep 1,464
Drives: BMW X5M Comp
As well as the comments to date, you might want to check the clamp seals on the track pipes, it might be sucking air causing more of a pop. I tried full catless a while ago and really got some good pops and the occasional flame :-)
Also spoke with Mike Benvo who is not in the slightest concerned, so many M3s have primary cat delete without issue Remember the performance gains from getting rid of those shocking 400 cpsi power robbers. |
12-30-2014, 02:50 PM | #19 |
254
Rep 551
Sounds like you're saying the 'thud' is not normal, which is a relief but not the feedback from the early days of the post. It never sounded like a tune issue just a mechanical issue, I.e., front cat delete with or without a tune would always result in a thud due to changes in back pressure, un burnt fuel or whatever.... I still have the lingering feeling that if I'm one of the 'unlucky ones' I will have a thud when I let off the gas.....unacceptable. I'd be putting the cats back on right away and flogging the test pipes on the classifieds, notwithstanding the extra power...... Be nice to know though..... Seems what's happening to those with the problem (I think it's a problem, others might not care) should be happening to all those with a cat delete, but that's not emerging, so I wonder, why some and not others?
12-30-2014, 04:05 PM | #20 | |
274
Rep 2,665
Drives: Goggomobil
F86 X6///
12-30-2014, 04:06 PM | #21 | |
532
Rep 1,464
Nearly everyone I know with an M3 has a primary cat delete and tune and nobody has ever mentioned a problem before. |
12-30-2014, 04:15 PM | #22 | |
274
Rep 2,665
Drives: Goggomobil
F86 X6///
