07-04-2007, 08:50 AM | #23 |
Santa Fe Concorso
103
Rep 2,984
You've also convinced me. But I'm already a 135i whore.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
07-04-2007, 10:23 AM | #25 | |
Zoom Zoom
38
Rep 1,069
07-04-2007, 03:45 PM | #26 |
Rep 289
Let us not forget that their appears to be brake cooling ducts in the front valance of the 135i (hopefully attached to some NACA ducts).
This car has a very serious braking setup, stock. It makes me very happy, not only for the sheer mechanical efficiency they will provide, but also the depth of focus BMW took this car to. If the brakes are this good (to me, brakes are too often overlooked), I can only imagine what the handling will be like.... |
07-04-2007, 05:10 PM | #27 | |
20
Rep 722
Does anyone else have any concerns over this? If the 135i is as good as it's looking to be, then I would like to keep this car a very long time. |
07-04-2007, 05:30 PM | #28 | |
Rep 289
07-04-2007, 06:01 PM | #30 |
Santa Fe Concorso
103
Rep 2,984
Look at the E36 M3. It sold, oh, maybe 75K units in the U.S. over its production run at ~$45K. Granted it is less technically complex than current era vehicles, but it is not really expensive to maintain. The 135i has the potential to sell many more units than the E36 M3, so let's hope the volume produced will soften the cost of maintenance.
07-05-2007, 12:13 AM | #31 |
Rep 146
You've convinced me. But I'm already a 135i whore. :wink:
2010 135i Coupe | Black Sapphire Metallic | Red Leather | Poplar Grey Wood Trim | 6MT | Premium pack | M Sport pack | Heated Seats | HK Premium sound | USB | Smartphone integration | Automatic high beams
07-05-2007, 10:36 AM | #32 |
Zoom Zoom
38
Rep 1,069
07-18-2007, 11:45 AM | #34 | |
Rep 80
Will definitely want to pop the hood after a quick Solo2 run. :biggrin: |
07-18-2007, 03:19 PM | #35 | |
27
Rep 290
Klinn, out of curiosity, how does your m-tech suspension compare to a regular sport suspension in your experiecnce with your car? Haveyou ridden in both? The 135i coming with m-springs makes me wonder what the difference is. |
07-18-2007, 08:27 PM | #36 | |
Rep 80
On a purely subjective level, it felt like the body roll was halved. That's a gross approximation and in no way an objective measurement, just the "feel". It's not as buttoned down as the M3, but the ride isn't as punishing either. We have lots of frost heaves up here in the great white north, so it was a good compromise for me. The M-Tech suspension is basically what ended up being used later on the 330 ZHP "Performance" model, although my earlier package has 17" wheels instead of 18"s. |
07-27-2007, 08:02 PM | #37 |
Stay a while and listen...
21
Rep 375
You mean pads and brake lines/fluid. The rotors will be fine. Pads fade before the rotors warp. Remember that pad deposits are what is perceived as rotor warp 95% of the time. If you are a road course guy you wont want cross-drilled, if anything you want slotted. Reasons being is the rotor is a heat sink and it needs mass in order to take the heat. Cross-drilling takes away from that mass. So w/o getting too technical... road course=Slotted FTW autocross should be fine with cross-drilled but you still have to worry about cracks.
07-30-2007, 02:22 AM | #38 |
28
Rep 1,035
Ehhhhhhhhhh, my 2005 Mini Cooper S needed Stoptechs and it only weighed under 2700 pounds.
07-30-2007, 02:59 PM | #39 | |
17
Rep 524
The amount of heat generated during braking is proportional to the weight of the car (twice as heavy means double the heat), but it is also proportional to the square of the velocity (so, if you're going twice as fast at the braking zone, it produces 4 times the heat). So, a fast car is always going to need big brakes, just not as big as a fast & heavy car... |
07-30-2007, 03:04 PM | #40 |
17
Rep 524
One other item - people keep talking about the 6-piston brakes holding up better on the track. Don't be confused. Better calipers only mean they can squeeze harder (and more evenly on the pads), so changing to better calipers will likely create as much or more heat and cause fade to occur just as soon or sooner. The real important thing is to have big rotors (lots of steel - large diameter and thick). Cooling vias air ducting and ventilated rotors is important too.
Brembos are great for pedal feel though (if used with the proper master cylinder and not overly assisted)! |
07-30-2007, 03:14 PM | #41 | |
28
Rep 1,035
EDIT: They're 338mm. That will be plenty IMHO, considering that the 135i deletes the foglights in order to accomodate brake ducting. Now I jus hope Hawk makes HT-10s or DTC70s in 135i fitment. I've seen people talk about Brembos on the 135i a lot. I've never seen BMW use a Brembo caliper before, and I didn't see it in any of the press releases. Has this been confirmed? |
07-30-2007, 08:45 PM | #42 | |
2433
Rep 11,667
There's no point increasing rotor size unnecessarily.... you'd just be increasing unsprung weight, w/o getting anything in return.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
07-31-2007, 11:56 AM | #43 | |
17
Rep 524
It's a difficult balance to choose a rotor that isn't too heavy for the road but heavy enough for the track. I think the track junkies will want/need to upgrade to something bigger (especially with extra boost giving close to 400hp/400TQ) |
07-31-2007, 11:58 AM | #44 |
17
Rep 524
What's the width though? Most Brembos are 34mm wide in that diameter - I think these are in the mid-high 20's - BIG diffference
