03-26-2024, 04:51 PM | #1 |
Rep 1
Hi, im currently running 225/45/19 front tires and 255/40/19 rear tires and i dont want to swap them.
I want to buy new rims with the following specs: 1st spec: 8.5jx19 et 30 front and 9.5jx19 et 35 rear. 2nd spec: 9jx19 et ?? front and 10jx19 et ?? rear. My questions are the following: -will my tires fit the 1st and 2nd specs with or without them stretching? -what would be the perfect et’s for the 2nd spec? NOTE: i’ve installed eibach prokit on |
03-26-2024, 09:26 PM | #2 |
8279
Rep 16,143
Wrong forum. Post in https://f30.bimmerpost.com/forums/fo...play.php?f=423
rusb.gdan4.00 |
03-26-2024, 10:37 PM | #3 |
39
Rep 79
1st spec you are at the max limits on tire size but would work. 2nd spec would be stretching it. Pun intended. Plenty of info with a quick google search. I run a 225/45 19 8.5 square with no issues. Also tire brands vary somewhat so may be a crap shoot trying to get a 225 on a 9” rim and certainly not reccomended. However, it’s been done.
rusb.gdan4.00 |
03-27-2024, 09:34 AM | #4 | |
287
Rep 482
For example: I wanted stock staggered 598m rims to sit level with fenders. So I've used spacers 10/12 front/rear to make the ETs 20 and 30 respectively (rims are 8"x19 ET30 and 9"x19 ET42 front/rear). I have Prokit springs installed in the front only. 2. This is a very handy and accurate tool for doing wheel/tire combinations as compare (including offsets): https://www.wheel-size.com/calc/
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
