12-19-2016, 03:04 PM | #1 |
1504
Rep 2,032
Clutch vibration from a standstill
Here's a new one: when going from a stop, moderate acceleration (not a burnout, not a launch), in the last 10% of clutch pedal travel, there's a noticeable stutter / vibration, to the point where even a passenger feels it. Not the car lurching, but like there's something rattling in the clutch itself. Happens only on moderate power from N-1 and sometimes (less frequently) from 1-2.
Any ideas? It's at the shop right now, they're "unable to reproduce." When I told them it happens around 2500 rpm, the SA told me "well you're burning the clutch if you're at 2500 rpm" ... uh.. wat?
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
12-20-2016, 06:38 AM | #2 | |
Driver
465
Rep 1,002
12-21-2016, 12:36 PM | #3 |
2253
Rep 3,622
I can't blame the SA, your description sounds like you're partially depressing the clutch so it's not fully engaged while having the engine at 2.5k.
I get that you're saying that's not it, so the only way is to get a tech to feel it.
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
12-29-2016, 03:57 AM | #4 | |
Driver
465
Rep 1,002
OP, let us know what the dealer does to resolve please! |
01-03-2017, 05:29 PM | #6 |
Driver
465
Rep 1,002
Really!? So when you pull away (in a manual) you don't press the accelerator before you release the clutch???
01-20-2017, 10:11 AM | #7 |
49
Rep 202
Just put it in 6th gear and lug it out at 600rpm around town. That is the best way to take care of your engine. If you can't feel a lurch every time the cylinders fire, then you might want to call your dealership and ask them about your turbo encabulator.
KD0752.50 |
02-02-2017, 12:47 PM | #8 | |
890
Rep 7,047
Those are just questions to help explain what may have happened, not to indict you. You may have "glazed" your clutch and/or flywheel. This is similar to brake pedal "chatter/judder", it can feel like a light pulsation that has an oscillating quality to it. It feels that way because the brake disc rotates and where there might be some pad material build up the pad grabs, and as it passes that point the friction lightens, so as the driver is braking normally it feels like a light pulsation. Often this is mislabeled as "disc warp" or a "warped disc", when more likely it's a pad material build-up/glaze. The same applies to the clutch and flywheel. Under certain conditions some of the clutch material can deposit unevenly on the flywheel, and the driver will feel it as a pulse or judder/chatter. Normally, it feels worse on take off, which is when the clutch first starts to contact the flywheel, and then it can happen between shifts depending on how quickly the driver shifts. Also, this is mostly felt in 1st gear on take off and maybe the next gear. The feeling tends to not be felt once in 3rd gear or higher. If this is the case, you can try to de-glaze this yourself simply by how you drive and apply the clutch. Just to start with, simply drive normally for the next few days making sure to NOT "ride" the clutch, don't slip it too much especially during take off. So, light rpm take offs, and quick shifts to the next gear. Over time and miles the parts should de-glaze naturally. Another method is to take off from stand still in higher gear like 2nd, and don't over rev or ride the clutch. Just take off normally but in a higher gear. Give it some time and some miles and see/feel if it helps. If not, then there is always the dealer tech, but remember the clutch is a "wear" item, so make sure your warrant covers that or you may get charged. |
02-03-2017, 02:24 AM | #9 |
53
Rep 182
Lol wait... you're engaging 1st gear at around 2500 rpms? Unless you're launching the car, that should never be the case. Maybe only when I'm on a steep hill or trying to get up and going quickly from a dead stop, I'll never get above 1500 rpms at most before fully engaged in 1st gear. Almost never even above 1000 rpms if I'm driving normal on a flat surface. Not trying to knock you or anything, but that tech guy that told you you're burning the clutch isn't crazy at all. If you've been engaging 1st gear at around 2500 rpms for a while now, that is probably the cause of the problem you're experiencing.
2016 340i - 6MT // M-Sport // JB4 // BMS Intake // AFE catback
eluded3048.50 |
02-04-2017, 11:40 PM | #10 |
49
Rep 202
There is nothing wrong with engaging the gear at 2500 as long as its not an extended slip. People do much more damage launching their cars over and over than you're going to get from a moderate acceleration from a stand still with decent engagement without excessive slippage. If he's riding the clutch half engaged for too long and doing this routinely, then yes I can see how the clutch will be prematurely damaged/glazed.
02-05-2017, 03:45 AM | #11 | |
2JZ-GTE
3049
Rep 4,002
If you're struggling at driving your car off of the line without excessive RPMs. I might suggest the following. Go to the parking lot or whatever away from traffic. And start from a stop without using the gas pedal. Do this 10 or 20 or 30 times or as many as it takes. After that you can use the gas pedal again. |
Beek707.00 |
02-05-2017, 06:03 AM | #12 | |
Driver
465
Rep 1,002
02-06-2017, 11:01 PM | #13 | |
1504
Rep 2,032
RPM90 this was a while ago, so I can't remember exactly. I don't really do launches or burnouts, but my wife drives the car on occasion and it's possible that she downshifted poorly (her 1 year of experience on stick vs my 18). thanks for the info, i'll give it a go.
