Tuning E92 335xi (Higher Mileage) Looking for Feedback!
05-09-2024, 01:42 PM | #1 |
Rep 1
Hello all!
I would love some feedback regarding tuning a higher mileage N55. I have owned the car for around 2 years and daily drive it. Is there anything else I should do for the sake of longevity for the engine/surrounding components? Is it smarter to get it tuned in a shop rather than by flashing? Last major failure point I have not addressed is the HPFP but plan to over the summer. Miles as of current day: 102,144 Current Parts List:
Will be changing spark plugs/coils prior to tuning. Below is the maintenance history: Spark Plugs/Coils: Will be installing the OE kit from FCP Euro prior to flashing. Transmission Service (ZF6AT): Has never been done. Alternator: Replaced within the last 1k miles. Water Pump/TStat: Replaced within the last 1k miles. Drive Accessory Belt/Pulleys/Idler Pulley: Replaced within the last 2k miles. VCG: Replaced at 81k miles. Radiator: Replaced at 81k miles. Coolant Resovior: Replaced at 81k miles. HPFP: Original has not been replaced. Oil Changes: Every 5k miles with 5w40 from Liqui Moly. |
05-10-2024, 03:36 AM | #2 |
48
Rep 89
Sounds like you are on top of everything really. I'd expect any issues to be exposed through the mapping. For example, only after I had flashed MHD did I start getting codes regarding the HPFP in my car.
The OTS maps via MHD are cheap and easy as a starting point. |
05-10-2024, 10:33 AM | #3 |
19
Rep 80
Same as wrevilo said.
Spark plugs and ignition coils and you are good to go to Stage 2+ Maybe a good idea to change also the fluid in the front/rear differentials and transfer case along with the transmission service. |
ChicagoE920.00 Malteser_wfj51.50 |
