F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > 13 F30 N20 xdrive 8HP Cooler Line replacement
proTUNING Freaks
      03-31-2024, 08:37 AM   #1
klho222
Drives: 13 BMW 328XI
Looking to see if anyone has changed their transmission oil cooler lines.
I took a look at mine and appears to be leaking from the trans inlet and outlet ports on the driver side of the 8HP.
Currently have 30k on the car since the last fluid change and no issues with shifting. I have been expecting one day that it wont come out of park due to a low fluid level.
Checked the Bentley manual and ISTA but not really any detail on how to get the coolant line out and replace. Best I have found is there is a single bolt holding the lines to the transmission and then I suspect clips along the way to the oil cooler.
Per SI B24 02 15 (https://static.nhtsa.gov/odi/tsbs/20...46786-9999.pdf) its best to change the whole line ($130).
Anyone done this before? Any tips? I plan to do it when Im due for a fluid change/pan change in ~20k miles.
f30post
