BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    New Vessel HF-5 21" - Rubbing front vents - 2022 M5 Comp
      03-02-2024, 03:10 PM   #1
CLEbmw
23
Drives: BMW 328d, X7 M60i
Hi all,
I just mounted up my new Vossen HF-5 gloss black wheels, wrapped in Michelin Pilot PS4 tires. Fitment is mostly ok, except the front. When turning the front wheels, they rub on the front brake vents. I believe the offset is 20 in front and 25 in back. The back wheels are perfectly fine.
Any suggestions to stop the rubbing? Also, the car is bone stock, no lowering has been done.
GranitM5366.00
      03-02-2024, 04:32 PM   #2
S EyeLand
165
Drives: F90 M5C
My set of 21s have 275 30 PS4S in the front. ET22. Thats a 5mm difference in diameter, 704 vs 699.
Edit you're rubbing directly in line with the hub so it's not a suspension issue, this is strictly down to the radius being too long from the hub.
      03-02-2024, 04:48 PM   #3
S EyeLand
165
Drives: F90 M5C
The more i think about it, stretching 275s will also round the edges and provide even further clearance. Not sure why this hasn't happened to anyone else.
      03-02-2024, 04:57 PM   #4
CLEbmw
23
Ahh, so you think dropping to 275 will solve the issue from the 285? I went with 285 as it looked like that’s what most were running with 10” wheels up front.
      03-02-2024, 05:35 PM   #5
S EyeLand
165
Drives: F90 M5C
I know people run 285 on 20s which would be .5" more radial clearance vs 21s but I'm sure with the right tire, one with round corners, you could run that on 21s as well but unless your car was in an accident or has damage that would cause that inner lining to shift, I'm thinking 285 30 21 PS4S are too wide and square to clear but I'm not an expert. If you were in the area i would test fit my 21s on your car... maybe someone in your area can help you with that.
      03-02-2024, 08:25 PM   #6
josec70
josec70's Avatar
4081
Drives: 22' Individual Chalk M5C
I’m on 21” BBS FI-R as follows with no rubbing issues:
21 X 10 et 22
21 X 11 et 24
Tires:
Michelin PS4S
285-30-ZR21
295-30-ZR21
I’m also lowered on KW V4’s.
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      03-02-2024, 08:32 PM   #7
CLEbmw
23
21 X 10 et 22
21 X 11 et 24
Tires:
Michelin PS4S
285-30-ZR21
295-30-ZR21
Why the heck am I rubbing then. It’s odd
      03-02-2024, 08:34 PM   #8
josec70
josec70's Avatar
4081
Agreed.
Can you double check the front offsets?
Is it on both fronts or just one?
      03-02-2024, 08:35 PM   #9
CLEbmw
23
Just the driver side. The passenger side clears, just barely.
      03-02-2024, 08:48 PM   #10
S EyeLand
165
Drives: F90 M5C
Measure the back of the tire, at the 3 o'clock, to the fender on the driver's side and the 9 o'clock to the fender on the passenger's side and compare. Its very possible your caster needs adjustment, when was your last alignment.
      03-02-2024, 08:50 PM   #11
CLEbmw
23
Good point. Haven’t done one yet. Just bought the car a few months ago. It’s been in storage due to winter in Ohio.
      03-02-2024, 08:53 PM   #12
S EyeLand
165
Drives: F90 M5C
https://www.m3post.com/forums/showthread.php?t=1918658
      03-02-2024, 10:07 PM   #13
josec70
josec70's Avatar
4081
Check inner lining to ensure that is not the issue and if OK, I would do an alignment.
m5post
