BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > M3 Photos/Video/Media Gallery
EXXEL Distributions
      03-24-2024, 04:08 PM   #1
Mr.Zisky
Mr.Zisky's Avatar
53
Drives: 2013 BMW E93 M3
Swiss 2013 BMW E93 M3 | Supercharged | Build Thread
Hi all!
I finally decided to start a build thread since I just got the ESS G1 Supercharged Kit delivered.
So, after owning E38 and E46 before I finally bought my dream car a E9x M3:
I chose E93 over E92 simply because I live in the Italian part of Switzerland, which means Mediterranean climate so this + listening to S65 with top down I'm definitely not a racer type of guy so I don't mind extra weight of the vert. Well, to be clear, it's very noticeable unfortunately and sure I'd love it to be lighter but the roof down + valves open is just pure ecstasy
The car is 2013 in Space Grey with DCT. I bought it completely stock, but since then the following happened:
- aftermarket headlights (these are just some aliexpres headlights, I'm not proud of them, they meant to be only temporary till I get my bayoptics but that got postponed due to issues with getting them approved in Switzerland)
- New wheels of course. I took a gamble and went for "golden" version which turned out to be waaaay to "gold digger" look than I anticipated so for 2024 I got another set which just got delivered this week but I'll leave that for next post. These (on the picture below) are 19" 9.5/10.5 custom made from local Swiss company. On them, there are 265/30 + 285/30 tires.
- Exhaust. It's Aulitzky exhaust (German manufacturer). Valved. Quiet as OEM (or maybe even quieter) with valves closed and thunder with valves open. Middle section stock (for now)
- Front lip. Not sure what this style is called at the end, I saw it with a few names already.
- Rear trunk lip was already there when I bought the car.
- Right now as I write this post, the car is in the workshop getting TTV Lightweight flywheel installed as well as CMP Solid Subframe Raising Bushes (+ some other OEM stuff like new diff bushings, guibo, central propshaft bearing, etc).
- Sitting in my living room now is ESS G1 Supercharger Kit. This will get installed in the next 2 - 3 weeks.
- Carbon Klasse (half) Carbon Intake Manifold, but that will of course get replaced soon by ESS manifold.
- At the moment car is on lowering springs but suspension (and brakes) will get upgraded in near future too
Instagram: @Mr.Zisky
Appreciate 2
CTMike262.00
      05-06-2024, 04:47 AM   #2
Mr.Zisky
Mr.Zisky's Avatar
53
So first update here as things have progressed since my first post.
First of all. TTV Lightweight flywheel and "CMP Solid Subframe Raising Bushes (+ some other OEM stuff like new diff bushings, guibo, central propshaft bearing, etc)." have been installed. My impressions:
TTV Flywheel - disappointing, unfortunately. I see/feel no difference in revving. I'm not saying there isn't a difference, probably if I had some before and after videos maybe I'd see the difference. So the only thing I "gained" is the chutter of the flywheel. This was of course expected. It's not much, can definitely leave with it. Something that I wasn't expecting (I had E46 with lightweight flywheel before so I'm used to little extra chatter) - starting the car sounds awful Cranking sounds noticeable different (in a bad way) and surprisingly DCT seems to get a little confused at times. It happens maybe like once a week that it feel that shifts are out of sync or RPM drops/raises randomly. Possibly this will fade away with time and as I said it only happens occasionally so not a big deal.
CMP Solid Subframe Raising Bushes + the rest of the drivetrain - definitely noticable improvement but not as huge of a difference as I was expecting. This could be due to fact that my car is 2013 so possibly OEM bushings were still in okeish. Overall I'm very happy - as I said the difference is still noticeable, car feels way better in corners.
ESS G1 - I installed supercharger last weekend so can't say much yet as I only drove for 10 minutes to check if everything is good. I was not supposed to rev it for the first 320km but ow boy I already accidentally hit 7000RPM when I just wanted to do a light 3000 - 5000 RPM pull. What a monster!! Feels like vert lost half of the weight. But that's just initial impression for 10 minute drive so will need more time to get a full picture
Name:  Screenshot 2024-05-05 091404.png
      05-06-2024, 04:49 AM   #3
Mr.Zisky
Mr.Zisky's Avatar
53
Also, in the meantime, I got new wheels...
Name:  Screenshot 2024-05-06 114831.png
      05-10-2024, 11:58 AM   #4
Lamar7
Drives: e92 M3
  [0.00]
Do you have any more impressions with the ESS to update on? The new one comes with the updated heat exchanger right?
      05-10-2024, 12:55 PM   #5
Mr.Zisky
Mr.Zisky's Avatar
53
I'm on vacation now so not yet fully tested but I did already about 200km and so far it's great. I love the car 100x more now. Especially crazy improvement in most useful mid-range. Quick overtaking is so easy now. Yes, it came with new manifold and new heat exchanger. IAT are surprisingly low, but again I didn't push it to the limits yet. I did some spirited driving already but that was like for a minute with max 7000RPM. With 22*C outside I saw max 39*C IAT which is nothing. I was expecting more 60 - 70*C or so (which again! maybe I'll see when doing proper driving). The only thing I don't like about the kit is how ridiculously heavy (and ugly) the manifold is
Appreciate 2
Lamar75.50
M_Torx351.50
m3post
