TireRack
      12-20-2020, 04:01 PM   #1
S.W.G.
Drives: 2009 335i, X5 35I, 2012 X5M
X5M Parking Brake Issue
Hey Guys,
2012 X5M - typical yellow P warning on the dashboard. I'm able to release the brake via the pull in the rear hatch and drive the car, no issues there.
I've tried the parking brake reset procedure - no change.
Codes read 6DDB and 6DDC. Tried clearing the codes - no change.
Strangely, my next step was disconnecting the battery for 15 minutes and reconnecting. Voila, the parking brake was back on! This leads me to believe that either the function in the actuator is intermittent, or there's something electrical between the actual button module and actuator itself.
The brake re-applying itself threw me a curveball...if it turned back on after battery reset it cant be the module can it? Anyone have any further ideas before I start randomly replacing things?
      12-21-2020, 02:44 AM   #2
handcn
Drives: 2011 X5 M
Originally Posted by S.W.G. View Post
Hey Guys,
I have a BMW PuMA case FYI:
The customer receives a check control message that the parking brake has failed. The parking brake cannot be released via the park brake button. In addition, the prompt tone rings several times, and the red indicator light of the parking brake lights up.
When handling a customer complaint, perform the following steps to put the vehicle into sleep: - switch off the ignition without operating the service brakes - lock the vehicle from the outside via the radio key fob - put the vehicle into sleep. Wait five minutes. -Unlock the vehicle via the radio key - start the engine - release the parking brake by button. If the customer has operated the emergency unlocking device for the parking brake, resume the operation of the parking brake function according to the instructions in the owner's manual.
If the customer has operated the emergency unlocking device of the parking brake, resume the operation of the parking brake function according to the instructions in the owner's manual. Then read the fault code storage record and compare whether the following fault code storage records are recorded:
DXC_ 70 0x6de2 - 6de2 - EMF fault: button damaged, slsiii0x6ddb - 6ddb - EMF fault: unable to tighten (tightened)
0x6ddc - 6ddc - EMF function: unable to release and / or EMF_ 70 0x6019 - PER_ BUTTON_ APPLY0x6020 - PER_ BUTTON_ RELEASE
If these fault codes are recorded, the fault memory is deleted and the function of the parking brake is checked by a test run to re evaluate the vehicle. If the function of the park brake is not limited, no further service is required. In this case, replacing parts and reprogramming will not help.
If other fault codes are recorded or currently exist, use ISTA / D to perform further diagnosis and implement test module.
      12-21-2020, 06:56 PM   #3
S.W.G.
Ahh man, that doesnt sound fun, seems strange that replacing parts wont help so it must be software based. This all happened a day or so after I did my Dinan tune
      12-21-2020, 09:37 PM   #4
bmwpower603
204
Drives: E36 m3 coupe 08 e90 M3
Hey Guys,
Common issue. Once you have pulled up with the special tool to release the e brake. You need to trying holding the switch down. Push it several times. Maybe even pull it once or twice during the sequence.
Keep repeating it. This is tricking the rebake actuator motor to get yellow light to come off.
This is the final attempt before you need to replace the unit.
      12-22-2020, 01:10 PM   #5
S.W.G.
Cool. I just spent ten minutes just toggling various timing on the switch outside the procedure. The *modulator* itself is what you're saying needs replaced?
      12-22-2020, 02:19 PM   #6
OllieX5M
Drives: 2010 BMW M5 and 2002 BMW M3
honestly just replace it with a unit from ebay which cost like 3-400 depneding on the seller. They come brand new and work great i jjuts had this issue in the summer and its been fine ever since.
      12-22-2020, 03:13 PM   #7
S.W.G.
Might be the case.
What are FCPeuro and Pelican parts smoking? 1100 for an actuator? I'd rather just have the stupid light on and wheel chocks!
      12-22-2020, 11:24 PM   #8
OllieX5M
It’s BMWs fault not there’s. Anyways I bought mine I’m in ebay works and looked new for $350. Make sure to tighten the brake shoes after install on both sides also so nothing clicks after replacement.
      12-27-2020, 05:58 PM   #9
S.W.G.
Went with the ebay option, will follow up if it works.
https://www.ebay.com/itm/Parking-Bra...-/331721372018
      12-29-2020, 03:50 PM   #10
Thecastle
307
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
Very common failure on the E70's and there are a lot of diy's to replace the brake module. Be prepared for most of a day to complete the job. I've done the job myself with an e-bay replacement module. Make sure the new module includes the brake lines. You will have to lift the car, remove both rear wheels disassemble the brakes to get at the e-breaks, and take apart most of the covers in the hatch. Nothin super hard, just a lot to remove to complete the job.
E70's kill parking breaks, sun roof tilt function breaks, front tension struts, heater control valve, and lol, the fun begins. Oh and they seem to have occasional oil leaks too ;-)
      12-30-2020, 06:14 AM   #11
GreenYamo
Drives: BMW X5
I have the same issue with the light, but mine has never been stuck on and needed to be released.
If I creep forward very slowly and apply the parking brake it will come on for 10 seconds, is this likely to need replacing also or could it be a communication issue?
      11-03-2021, 06:02 PM   #12
khalilbha
Drives: bmw x5 2007 4.8l
Guys i have the same issue with the parking break warning and the only thing i need to get rid of is the warning sound it does. I don't need the parking break to be funtionning properly since i never use it. WOuld it be possible to jusyt remove the warning sound ?
Thanks
      11-06-2021, 02:32 PM   #13
Bob_Ross
Drives: BMW X5 E70 M-Sport
Replaced mine today and have the scar to prove it! … dropped a wrench on my face ffs.
Took the best part of a day to do and axel stands a must.
Make sure you have a decent sized wrench to get the calliper bolts removed; or as I did, use the pole from your trolly jack for leverage!
werdn662.50
      12-21-2021, 10:38 AM   #14
S.W.G.
Resurrecting the zombie thread. I managed to get by for a year with the issue solving itself. Buuuuttttt....now she's stuck in the driveway with the brake "on" and the emergency release no longer works. Guess how I get to spend christmas
      12-22-2021, 07:37 AM   #15
Thecastle
307
Drives: F10 550i
2020 BMW X3  [0.00]
Buy one from eBay. It’s a lot cheaper. Very common e70 failure.
      07-10-2023, 12:37 PM   #16
werdn
werdn's Avatar
663
Drives: 997.1 GT3 Shark, ex E92 M3 ZCP
Still working 2-3 years later? Do you have the seller for it?
      08-04-2023, 08:17 PM   #17
osik88
osik88's Avatar
Drives: BMW X5 F15
Hello,
I’m facing the same issue.I replaced the actuator but nothing changed.Is anyone knows how to program/code it?
I tried with NCS but with no luck.
Thanks
      08-05-2023, 10:19 AM   #18
jbash87
257
Drives: 2006 M5, 2012 X5d, 2008 E91
2012 BMW X5 35d  [10.00]
2006 BMW M5  [10.00]
I stand corrected. TIS references reprogramming. I'll edit my response in the other thread.
You can do this via ISTA or possibly even INPA. Do you have either of those programs?
      08-05-2023, 02:20 PM   #19
osik88
osik88's Avatar
Drives: BMW X5 F15
Hi,
Yes I do have both of those.
      08-05-2023, 02:26 PM   #20
jbash87
257
2006 BMW M5  [10.00]
Excellent! Here is the procedure.
https://www.xbimmers.com/forums/show...3&postcount=10
      08-05-2023, 02:42 PM   #21
osik88
osik88's Avatar
Drives: BMW X5 F15
No Luck there just tried it DSC don’t receive signal from EMF
      08-05-2023, 02:43 PM   #22
osik88
osik88's Avatar
Drives: BMW X5 F15
EMF faulty power supply,Sporadic undervoltage by EMF what that could be
xbimmers
