BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Extended BMW 335d PIDs for Torque
      09-05-2018, 10:18 AM   #221
halcyon22
Drives: e90 335d, e39 m5
now that the bimmergeeks app is out, i noticed that there is trans temperature data available through the obd port with their app. Has there been any further development of this PID to made the same trans temp information available through torque?
      09-07-2018, 01:32 PM   #222
tryingtobebest
92
Drives: E90
Trying one more time, can someone please share nice GAUGEs LAYOUT!?
      09-14-2018, 08:30 PM   #223
DWR
798
Drives: 2009 335d
Not sure what you are trying to accomplish. Creating gauge layouts takes just a few minutes. Also, custom gauges are available online.
      09-14-2018, 08:35 PM   #224
DWR
798
Drives: 2009 335d
Originally Posted by 335stoner View Post
Is post 1 the most current file?
It is here, https://www.e90post.com/forums/showp...5&postcount=36
      12-08-2018, 01:15 PM   #225
SJM67
SJM67's Avatar
24
Drives: 2008 E92 335I Coupe
1995 BMW 318I  [0.00]
2008 BMW 335I  [0.00]
like this?
      02-12-2019, 08:22 PM   #226
halcyon22
Originally Posted by SJM67 View Post
like this?
how'd you get fuel rail pressure to show? thats not in the pid.
      02-26-2019, 09:02 AM   #227
tryingtobebest
92
Drives: E90
like this?
No, i mean you can EXPORT gauge layout and then just share it with community here and now im interested in yours because you somehow got fuel rail pressure!)
      03-03-2019, 08:08 PM   #228
robnitro
160
Drives: x5 35d e70 2011
https://anonfile.com/HfmdK1vbb5/BMW335dextendedxx_1_csv
I have that and a few calcs based on rpm/maf, vw tdi had maf mg per stroke.
Oh and mg fuel per stroke like the tdi had.
      03-12-2019, 10:14 PM   #229
SJM67
SJM67's Avatar
24
Torque Pro has Fuel Rail Pressure listed in the extended PID's.
      03-30-2019, 09:34 AM   #230
project_x
Drives: 328D F30
extended PIDS to measure DEF fluid levels
I know this thread is a bit old....but has anyone managed to use extended PIDs to measure the DEF level?
      04-16-2019, 10:28 PM   #231
simt
Australia
Drives: F22 m235i, F10 m535i
Hey, I've been looking through all the info here, can't find what I'm looking for;
Is there a PID or way to look at diesel injector fuel trim/compensation values?
I'm looking for an Android solution to a specific table I can get in INPA. 'Selective Mass Adjustment'. I use it to check the health of my diesel injectors and look for warning signs of a failing injector - I've been stranded twice!
Check out Cylinder 5 in this vid: https://youtu.be/FicbKEFSSgI
And my write up of it here: https://xoutpost.com/bmw-sav-forums/...ml#post1159871
I'm hoping there is an easier/quicker way to monitor this than having to pull out my laptop and cable all the time.
Any help appreciated,
Simeon
      05-01-2019, 09:34 AM   #232
blk35d
Drives: 2011 335d
If laziness is mother then daddy is frustration and I'm bout to take it out on the torque app.. I cannot get it to connect for the life of me.. Did anyone get a "select the right baud rate" message and can't connect? At this point I'm done with torque pro unless you guys have an answer.
Maybe I have already found my problem after digging into the forums.. I have the bimmer geeks k+dcan usb cable and well I haven't gone down yet but I'm pretty sure I just need to switch it from k to d can on the obd2 connector itself.
      05-02-2019, 04:09 PM   #233
blk35d
Drives: 2011 335d
Alright well elm 327 here I come bc the BG adapters are too fast for standard baud rate apps like Torque pro.
      05-22-2019, 01:23 PM   #234
kanlenner
Drives: bmw f22 m235i
Here is the ability to get a good BOOST
Thank you DWR, I am a rider from Taiwan. According to your tips, I finally read the correct boost value on my E60 535I:party0030::party0030::party0030::party0030:
https://youtu.be/A12ld-kfm6Q5I.
      05-31-2019, 02:48 AM   #235
Joe M
Drives: Bmw E46 M3, E92 335d
Are these PID's for the later N57 engine? I've tried on my '06 M57 and they don't seem to work.
Also, boost on torque pro seems to max out at 22psi for me, but it properly flat lines so I don't think this is the actual maximum, just the end of range for the reading, is this correct?
      07-27-2019, 08:19 AM   #236
madbim
madbim's Avatar
32
Drives: 08' E90 335xi
Can anyone confirm if the Pre SCR EGT is scaled correctly for a 35d? I'm seeing some higher than expected temps.
Logs -> https://datazap.me/u/madbim/35d-7-27...ta=8-15&solo=8
2008 E90 335xi - DPs, 5" IC, MHD Stg2+, xHP Stg3, xDelete | 2013 X5 35d - DUDMD Stg1, EGR Delete
