02-21-2023, 03:10 PM | #67 |
Supreme Allied Commander
3885
Rep 54,494
Drives: F80 M3
High perfomrance all alum. radiator with increased capacity and cooling.
2 row 42mm core (dual core) featuring CSF’s exclusive B-tube technology* Core features an ultra-efficient fin with 6.5mm fin height and multi-louvered design for maximum surface area contact Triple-pass flow structure allows the coolant to flow across the core of the radiator 3 times before exiting the radiator for lowest outlet temperatures possible CNC machined “quick-connect” inlet/outlet connections CNC machined brackets and fittings for superb fit and durability All-aluminum race style drain plug 1 hour “mirror finish” hand polish “Drop-in fit” requiring no modifications to install. Accepts all attaching OEM components including “quick-connect” hoses, AC condenser, mounting brackets, and fan shroud 7045 2011+ BMW 1 Series M 08-11 BMW 135i 07-11 BMW 335 manual transmissions only 7046($80 more) 2011+ BMW 1 Series M 08-11 BMW 135i 07-11 BMW 335 2009+ BMW Z4 sDrive30i sDrive35i Automatic transmissions |
06-15-2023, 01:38 PM | #76 | |
3885
Rep 54,494
Drives: F80 M3
2008 Turbocharged L6 3.0L Automatic 1 2009 Turbocharged L6 3.0L Automatic 1 2010 Turbocharged L6 3.0L Automatic 1 2011 Turbocharged L6 3.0L Automatic Dual Clutch 1 2012 Turbocharged L6 3.0L Automatic Dual Clutch 1 2013 Turbocharged L6 3.0L Automatic Dual Clutch |
ByeByeVTEC24.00 |
07-06-2023, 11:50 PM | #77 |
3885
Rep 54,494
Drives: F80 M3
11-03-2023, 03:24 PM | #84 |
3885
Rep 54,494
Drives: F80 M3
