F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Do I need to replace all tires when only needing one tire xdrive
GetBMWParts
      04-27-2024, 04:15 AM   #1
isaiauh.e82
Drives: 2017 bmw 340i
I hit a nast pot hole the other night and it shredded my tire and I’m aware when changing tires on an xdrive car you want to get all new tires so the tread depth is all the same to save your drivetrain but I just barely got these tires I’m probably a little over 3k miles deep into but maybe 4k I’m not sure if it’s too much to the point that I need to replace all four or should I just be able to buy one new one of the same brand/ tire my car is a 2017 340i xdrive please if someone could help
      04-27-2024, 08:44 AM   #2
alohasurftoad
3134
Drives: 440i gran coupe w/mppsk
It will be fine to replace just one.
      04-27-2024, 02:51 PM   #3
isaiauh.e82
So I should be good it won’t mess up my drivetrain it just scares me because that it’ll be super spendy
      04-27-2024, 03:16 PM   #4
alohasurftoad
3134
if it'll make you feel better, you can change two on the same axle. and rotate the same axle front,<--->back when it's time. you can criss cross if using non directional tires.
you don't need to change all four. if it were me, i'd just change one like i advised initially.
      04-27-2024, 04:32 PM   #5
isaiauh.e82
Thank you I appreciate it a lot🙏🏽🙏🏽
      04-27-2024, 07:58 PM   #6
chowser51
chowser51's Avatar
2040
Drives: F33 430 and F39 M35i
you can also check the tread depth and some tire places will shave the new tire to match.
f30post
