      03-28-2008, 10:42 AM   #67
Dave
formerly izzo/comeback
Dave's Avatar
287
Drives: 2016 RC 350 F Sport
2008 135i  [6.80]
btw saw this on m3 boards...
good reviews of the TR's
bmw center caps are nice touch
from his post
"I bought TRMotorsport MT1 wheels 18x9.5 with 265/35/18 Michelin Pilot Sport Cup all around. I'm using 10mm RE spacers on the rears. wheel as per TireRack are 19lb and according to Michelin 22lb for the tires
so 19+22=41, I got 43.20Lb so the rest might be for for the wheel weighs, air, scale error, etc"
BMW CCA # 418268
      03-28-2008, 11:53 AM   #68
Impulse
BMW ONE
Impulse's Avatar
15
Drives: 93 RX-7 R1, 135i
Mikeo can't wait to see pics when you get them on
135i - Alpine White - Black Leatherette - 6-Speed - Sport Package - Aluminum trim - 6FL
      03-28-2008, 04:55 PM   #69
Gary@TireRack
Moderator
Gary@TireRack's Avatar
369
Drives: Formerly 1995 M3
I'm headed out for the weekend guys. Talk to you on Monday.
Gill
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
      03-28-2008, 05:21 PM   #70
atr_hugo
No longer moderate
atr_hugo's Avatar
No_Country
325
Drives: '13 135i
Have fun Gill!! And as the folks at Morris Garage used to say, "Speed Safely!" ; -)
      03-28-2008, 08:38 PM   #71
mikeo
Santa Fe Concorso
mikeo's Avatar
103
Drives: '11 M-sport 328i, '13 X1 28i
Bad news! The TRMotorsports 18x8.5 et44 wheel mounted with 245x35 'Stone RE760s do NOT make a happy fitment in the front of a 135i. The wheel will spin but there is less than 1mm clearance on the strut and steering arm. Spacer use is not a solution because the wheel and tire already extends outside the front fender.
It must be said that I did not test drive the car or have photos of the fitment. But from my experience, this was not a workable street wheel/tire setup. I did not drive the setup as I want to return it to TireRack un-used and go for a better, to be determined, setup in the front. I'm thinking 18x8 et40-45 and a 225 tire will be about it for street in the front. And, 'gasp', I may have to forego my prejudice against staggered setups and go with a 18x9 rear wheel as I can't bear to drop to 18x8 rear.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      03-29-2008, 02:38 PM   #72
HebbNH
Resident Cacodemon Expert
HebbNH's Avatar
Drives: 2008 AW 135i 6MT
Thanks for the info mikeo. Sorry to hear that 18x8.5s won't fit in front. Looks like I too will probably be running 18x8s in front and 18x9s (or wider, if possible/necessary) in back.
BMS JB4 | BMS DCI | ETS intercooler | ETS charge pipe | HKS SSQV III | CP-E downpipes | BMWP exhaust | P3Cars vent gauge | LUX V3 angel eyes | Weisslicht smoked LED sidemarkers | Blackline LCI taillights | Slek Designs front lip | BMWP grills | Seibon M3 hood | iCarbon CSL trunk | iCarbon rear diffuser | BMWP suspension | Yokohama Advan Neova AD08s | Work Brombachers - FLOSS edition | H&R spacers | TC Kline studs | Project Kics R40 lugs
      03-29-2008, 08:35 PM   #73
E82tt6
E82tt6's Avatar
103
Drives: '08 Black Saphire Z4 MC
Same here. At this point, I'm think 18x8/235 up front is about as extreme as you can go for a steet setup.
'08 Black Saphire/Black Z4 M Coupe
RIP Gretta: Blue Water/Lemon 135i. Died to save me.
-ChuckV
      03-30-2008, 11:50 PM   #74
asv
44
Drives: 135i
Originally Posted by izzodesh View Post
asv
balling...
nice choice
i am still holding out for the MORR alloy pricing
Thanks!
Here are some shots of the wheel on the e90:
http://www.e90post.com/forums/showpo...7&postcount=59
I was hoping for Morr as well, but I figure it will be awhile before the 18's are available, and I wanted something now
      03-31-2008, 09:03 AM   #75
Gary@TireRack
Moderator
369
If anyone is curious, here's an 18x8 and 18x9 ASA AR2 setup on my 135i. The rear tires are worn to the tread bars.
18x8 ET40 225/40/18
18x9 ET45 255/35/18
Fits and drives fine. Looks aggressive. Neither the front or the back sticks out of the fender but it is close.
Some here are thinking about a 9" ET40 on the rear. This will give you a visual what it might look like pushed 5mm further out.
Gill
      03-31-2008, 11:56 AM   #76
E82tt6
E82tt6's Avatar
103
Think you could fit 235s up front with that setup?
-ChuckV
      03-31-2008, 12:27 PM   #77
Gary@TireRack
Moderator
369
Yes, but I'm not sure I'd like it. The 235/40 would be about .5" taller than the rear at 255/35 and I'm not convinced 265/35/18 would stay under the fender.
Gill
      03-31-2008, 12:31 PM   #78
randomquickness
219
Drives: 996tt
what if you were to go to a 235/35?
      03-31-2008, 12:38 PM   #79
Gary@TireRack
Moderator
369
Significantly less options but the size should work fine.
      03-31-2008, 12:45 PM   #80
Gary@TireRack
Moderator
369
Here's a side view.
      03-31-2008, 12:48 PM   #81
randomquickness
219
Drives: 996tt
when is the drop coming? haha
      04-02-2008, 11:05 AM   #82
twenzel
twenzel's Avatar
53
Drives: 15 Audi S3
Here is what I am thinking with lowering and some negative camber.
Rear:
18x9.5 et45 with 255/35/18
Front:
18x8.5 et42 with 245/35/18
      04-10-2008, 08:50 PM   #83
defcon1racing
grebo guru
Drives:
Rear:
Front:
twenzel,
Do you have a link for that wheel offset/tire size calulator? I looked around the site credited with the app, but couldn't find anything using their search fn. This looks like a very useful app.
Thanks,
Shane
(still no signature)
      04-10-2008, 09:13 PM   #84
mikeo
Santa Fe Concorso
mikeo's Avatar
103
Originally Posted by defcon1racing View Post
twenzel,
Thanks,
Shane
Here ya' go...
      04-10-2008, 09:19 PM   #85
BMW Dreamer
BMW Dreamer's Avatar
72
Drives: Modded 06 TL Manual
AWESOME. Answered some questions. I like the Dunlop M3 205/50/17" on 17"x8" Sport Edition 5 spoke wheels.
      04-10-2008, 09:23 PM   #86
defcon1racing
grebo guru
Drives:
Originally Posted by mikeo View Post
Mikeo,
Thanks!
Shane | def.con.one Racing
      04-10-2008, 10:06 PM   #87
defcon1racing
grebo guru
Drives:
What a shame. I was hoping the same wheel in a 17x8.5 would work with 255/40/17 track/auto-x tires. We really need a 8.5" front that will work to use 255s at all four corners as all the spec sheets I've checked require a 8.5" min. for 255s.
Are there any other suggestions out there or is it not possible to fit 255s on the front?
      04-11-2008, 08:50 AM   #88
mikeo
Santa Fe Concorso
mikeo's Avatar
103
Larry uses the LTW5 17x9 et 41 and a 3mm spacer, with 255x40. I suspect the 17x8.5 et 44 with a 3mm spacer would work for auto-x or track. I just didn't want to run spacers on the street, but may have to anyway to get a 8.5" wide wheel up front.
1addicts
