05-22-2014, 11:23 AM | #23 |
Enjoying driving
388
Rep 1,169
Yes, I believe you are right, although I do not know that for a fact. At the same time, its engine is completely different than the street version, which again defeats the purpose IMHO.
05-22-2014, 12:26 PM | #24 | |
e36s54, e70x5d
151
Rep 1,723
I dont see why that would be different for the C7R. As much as all of us would love to buy a certain sports car, then point at its racing counterpart and say "look, I have the same car" ....the reality of that is much different. Those days are gone and are most likely not coming back. There is a huge disconnect in every single vital component between street car and its racing counterpart. Unless, you look at amateur racing and specifically the Continental Challenge, Ferrari Challenge and Porsche Cup. All other racing use tube frames to achieve lower weight and completetly different suspension and chassis geometry for lower center of gravity. Even the body panels you see on those tube frame cars that make the car "look" like it's street counterpart are not the same body panels stamped at the factory. I have progressively stripped down 3 generations of m3s so far and it always comes down to very little weight you can lose (200-300 lbs) and not being able to get the car low enough using the OE suspension system and pickup points to make that specific system work with its chassis. Its only then that you realize why so many racing engineers choose custom chassis fabrication. I actually own and operate the worlds lightest e36m3 tub chassis race car @ 2350#s and it took a massive amount of clever cage work and all fiberglass body panels (lighter then CF, just not as strong, pretty or expensive) to make that happen....and the only thing in common this car now has to its street counterpart is the unmodified tub and the front/rear subframes along with the suspension system. |
05-22-2014, 03:17 PM | #25 | ||
Moderator
7525
Rep 19,368
05-22-2014, 03:32 PM | #26 | ||
112
Rep 210
