06-30-2023, 08:57 AM | #67 | |
1020
Rep 836
3R1CS07.50 |
06-30-2023, 09:41 AM | #68 | |
Rep 31
06-30-2023, 12:33 PM | #69 |
134
Rep 339
Is there that big of an advantage going to 295/35 squared vs the more common and shorter 295/30 squared? This is what I'm running now. I suppose going to 35 profile in rear can help with longitudinal grip. Any other reasons?
06-30-2023, 01:22 PM | #70 |
1020
Rep 836
Mostly the speedo is more accurate. Using a taller tire avoids shifting in autocross. A 30 series tire would be much more likely to need a shift to 3rd, particularly on a dct. On a hpde only tire....meh.
heyyouduh134.00 Car-Addicted7210.50 |
06-30-2023, 01:44 PM | #72 | |
91
Rep 74
3R1CS07.50 |
06-30-2023, 01:46 PM | #73 |
91
Rep 74
I honestly did it for looks. I hate the look of bicycle tires on cars
06-30-2023, 01:50 PM | #74 |
91
Rep 74
Just bought some kw clubsports 3 way from a member here. Supposedly Bimmerworld suggested that my stock suspension was last culprit for my braking issues. As I’m over driving the car with all the weight.
Can’t wait to install these |
Theruleslawyer1020.00 |
07-01-2023, 02:26 AM | #75 |
Rep 31
Please post updates on how your wheels and tires fit with these
07-01-2023, 12:24 PM | #76 |
27
Rep 19
I have the same coilovers and run 315/30 in the front. There is no noticeable rubbing but a small amount does occur as there's some paint worn in the wheel arch lining. We had to cut out some of the wheel arch lining, utilise Millway camber plates instead of the KW top mounts and adjustable drop links. It performs great on track. It also limits the amount the car can be lowered. You can see my build thread for pictures.
07-19-2023, 08:45 AM | #77 |
127
Rep 316
FOR BRAKES:
There's an inherent issue with the stock 4 piston calipers, the rotor is too thin and there is not enough thermal mass to absorb the heat from a track session, it peaks quick and then all the heat goes to the fluid and pad. Why did BMW make the rotor only 30mm thick is questionable but there a solution! I spoke with the guys at Paragon Braking about the issue (and suggested the thermal mass issue) and they are now going to make a heavier rotor for more thermal capacity. You can mention my name, Mitch from bimmerpost (you can ask for Godfrey at Paragon), they should know what you're talking about if not say you want the 72 vane rotor. Add some castrol SRF and now the weakest link should be either your pad or the dust seal, I suggest titanium shims to help insulate some of the heat transfer and also add some thermal mass. Pads are way more important than people think, you shed heat in the form of dust! Heat is the enemy! These F8x are amazing cars, the brakes are the weak point it's time we fix it without a BBK! |
07-19-2023, 01:44 PM | #78 |
371
Rep 417
Good stuff mitch32 Like the solution and must give that a try.
Then I think seats for me are next. Need to get something to better hold my arse in-place.
Quietly Effective
07-19-2023, 03:17 PM | #79 |
1020
Rep 836
Interested to hear how it performs. Without a dimension change how are they adding substantial mass? Filling in the vane are seems like it would compromise cooling. Better performing vanes seems like it would be perferred over a heavier rotor in stock size. I thought that was how girodiscs worked.
07-19-2023, 03:29 PM | #80 | |
1100
Rep 924
07-19-2023, 03:33 PM | #81 | |
1100
Rep 924
Fyi - Racing Brake sells stainless steel pistons and high temps boots and seals for the blue OEM brakes. With upgraded rotors and Ti shims it's a great set-up. You'll want to remove the dust/splash shields too for added air flow. https://racingbrake.com/bb-43bsp/ |
07-19-2023, 03:51 PM | #82 | |
127
Rep 316
08-27-2023, 09:30 AM | #83 |
91
Rep 74
The 295/35 didn’t fit with the kw cs. I had a 12 spacer on a 10.5 +25 wheel before. I had to run a 5mill slip on to get clearance. So it’s effectively 10.5 +7 to clear the spring I ordered a 18mm spacer just for a little more clearance. The car sits really low In the front now. Need to dial in the height. With these coils. Don’t want to destory my lip again |
08-28-2023, 09:08 AM | #85 | |
1020
Rep 836
08-28-2023, 09:17 AM | #86 | |
91
Rep 74
I’ll be down sizing to 275/35 again because tire rack doesn’t have 295/35 re71rs in stock. So there will be even mkre clearance |
09-04-2023, 10:59 AM | #87 |
91
Rep 74
So turns out the kw clubsports I bought from a member here were blown in the front. Pretty annoying cause he stopped responding to me. Sprayed shock juice all over my fender liner at the track and wheel.
Managed to get a 2 seconds faster pb at HMS Cars brakes finally feel good as well. Using the pfc 11. Homestead Speedway 1:38:41 |
09-04-2023, 11:25 AM | #88 |
Rep 4
That's a bummer man. Similar thing happened to me when I bought some used motons that were "just rebuilt" but blew a rear shock within 50miles. The seller couldn't believe it!
I will never buy used suspension components again. |
