BMW X3 Forum
BMW X3 Forum
      12-06-2022, 02:07 PM   #1
Stoy
20
Drives: 2016 BMW X3 35i M Sport
MHD flash stage 1
Just recently purchased MHD super license and flashed to stage 1 for my 2016 X3 N55. I have installed a larger intercooler, metal charge pipe, high flow intake, stock down pipes, coils and plugs. Does anyone recommend running stage 2 without the high flow catless down pipe? Any negative effect or go for it?
      12-06-2022, 09:14 PM   #2
Dekero
36
Drives: 2013 BMW X5 35I
You can do it. But the restrictive downpipe is going to slow down the overall response and may overheat the catalytic converter causing an O2 error code to pop..
Beyond that... Let it rip. I'm running Stage 2+ on my 2013 X5 35i and it's a beast....
If you decide to do it get 1 step colder plugs too...
      12-07-2022, 10:28 AM   #3
Stoy
20
Thanks, I live in a pretty cold environment and the summers are very mild. I rarely push the car to red line and most do my pulls are while rolling and not much from a stopped position. At some point i will add the after market down pipe.
      12-07-2022, 11:07 AM   #4
oVeRdOsE.
oVeRdOsE.'s Avatar
2820
Drives: F25 E91 Audi Avnt E90 Cayenne
N55 crank pulley are press fit, and according to a BMW tech near my place, it's not rare that N55 got issue with it, specially in our climate, that can go from -26°C to 30°C in a matter of 3-4 months.
Even on a stage 1 I would do the capture kit
https://vargasturbo.com/product/vtt-...-bolt-capture/
for the down pipe, I dont know too much about benefit on the N55, they are pretty fat from OEM, you can check E90/F30 section for more info.
Instead of a super licence, you could have gone with backend flash MHD license and get a JB4, so you have a better control about stock downpipe and pushing more PSI.
Probably cheaper than MHD SuperL + stage 2 maps and a down pipe. Im conviced that power difference wouldnt be that noticeable between those 2 options
      12-07-2022, 12:11 PM   #5
Stoy
20
thank you
      12-07-2022, 12:30 PM   #6
Stoy
20
thank you
      12-07-2022, 05:43 PM   #7
Dekero
36
You did better with the super license... The JB4 Is a piece of garbage... Had one for a year and spent the whole time chasing phantom bs errors, with lots of expense to fix problems that were all solved the day I pulled that piece of S off my truck....
      12-07-2022, 06:29 PM   #8
Stoy
20
thanks
      12-09-2022, 07:58 AM   #9
oVeRdOsE.
oVeRdOsE.'s Avatar
2820
what model did you have? Ive the latest.
just sayin N55 are not the strongest bmw engines, jb4 add more safety than MHD alone. Custom back end flash are pretty nice. You can manually dial up the boost per rpm via jb4 and log. If you're serious about your logging, 100% sure you'll get most of your engine, with proper monitoring without having exactly MHD requirement mods.
After few pulls and JB4 adjustment , some folks get their car professionally tuned after, and they get marginal gains. Pretty solid DIY safe tuning method, and if OP dont go with a DP, probably cheaper than MHD alone.
      12-10-2022, 10:58 AM   #10
Stoy
20
2016 X3 N55 M sport. Not looking to do 1/4 drags, just some extra HP for passing power on the hwy. Next mod will be the xhp transmission flash, not happy with the response of the factory setting. Since i already have the latest MHD wifi adapter, should be an easy flash
      12-11-2022, 12:48 PM   #11
Dekero
36
Good friend of mine has both the MHD tune and XHP and says it's a nice combo... I can't seem to aquire the Bawls to mess with these 6k+$ transmissions... Just not that brave yet...
      12-12-2022, 04:52 PM   #12
Stoy
20
It's all about your driving habits! If your type that likes to hammer the accelerator at every opportunity, then yes at some point problems will pop up, but if you drive moderately and use the mods sparingly, no reason unexpected issues will arise. Of course lots will depend on age and mileage of the car and how well the car is maintained.
      01-28-2023, 03:36 AM   #13
evilchargerfan
evilchargerfan's Avatar
272
Drives: 2012 F25 (N55), 2014 I01 (REX)
I ran the mhd stg 2 tune for well over a year, all seems fine
arm fmic
bms intake
ftp charge pipe
ftp boost pipe
poor mans exhaust (resonator delete + golf tee mod)
1 step colder plugs
oem dp
just installed a Catless dp, will flash stg2 plus.... soon
      02-07-2023, 03:36 PM   #14
jd_perspective
jd_perspective's Avatar
344
Drives: 2016 X3 35i M-Sport
so what "butt in seat" performance improvements are you feeling with the Stage 1?
I'm coming from a F32 with the B58 engine so with the weight and less powerful engine I am really missing the oomph...
2016 X3 35i M-Sport
2019 440i Coupe M-Sport - Retired
2018 330i Sedan M-Sport - Retired
2015 428i Gran Coupe M-Sport - Retired
      03-09-2023, 01:51 PM   #15
evilchargerfan
272
UPDATE:
installed catless dp
flashed stg 2+ map
OH MAN, that really woke up the car.
/the end
      04-22-2024, 09:09 PM   #16
Bammel438
Drives: 2016 BMW X3 xline
What’s the best flashing device I can use to flash my 2016 bmw x3.
      04-25-2024, 12:25 PM   #17
bwillpom
Drives: BMW X3 F25 LCI X-LINE
If you have access to e85 try running the state 1 e85 map with a tank of e85 and compare to the 93 tune set up.
xbimmers
