03-11-2024, 01:57 PM | #1 |
92
Rep 233
Drives: '18 M2 LCI
Camber plates for street driving?
Hi folks. I’m looking at getting a set of Ohlins R/T coilovers and have been chatting with a few shops to get their recommendations on camber plates.
I’ve received about equal responses in favor and against using them. I’ll be using the car for spirited driving and some road trips throughout the year, no track use (at least for the foreseeable future). The wheels will stay as stock 437m until the tires wear out, then upgrade to some wider wheels. I’m super torn on whether to get camber plates or not for my use case. One shop said I should get it for the adjustability and to get the most out of the suspension. Another shop said it’s overkill for what I need and will create a lot of NVH. I’m fine with NVH but have no context on what the NVH sounds/feels like. Would love to hear some people’s thoughts/expeirences before I have everything installed.
'18 M2 LCI 6spd
03-11-2024, 04:12 PM | #3 |
4022
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
If you have no track use, then you don't need camber plates IMO.
If you must have camber just to have more camber, and want to avoid NVH as much as possible your options are 1) new front BMW camber correction knuckles with -0.5deg additional camber built in, and 2) adjustable wishbone/lower control arms that allow you to extend the arm length (can get about -0.8deg extra). If you're looking to get camber plates anyways then Millway Street are the ticket.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
RyeM23.00 medphysdave4584.50 |
03-12-2024, 04:39 PM | #4 | |
4585
Rep 4,687
03-20-2024, 10:02 PM | #5 | |
BimmerPost Supporting Vendor
3863
Rep 54,426
Drives: F80 M3
If you think your tolerance to NVH is high, you can take advantage of the additional negative camber the plates offer. |
03-21-2024, 12:09 PM | #6 | |
15
Rep 43
03-21-2024, 12:29 PM | #7 |
560
Rep 570
I have Ohlins R&T and camber plates. I’m curious as to why someone would invest/upgrade to adjustable coil overs and not add proper camber plates to increase front-end grip through negative camber - esp. if track days are on the agenda. A/out plates, your front-end grip offered by the Ohlins will be undercut by lack of additional camber. Otherwise, stock suspension for 100% street is probably fine w/ upgraded dampers.
The camber plates eliminate the stock strut head bearings and rubber mounts that isolate the NVH from the suspension and steering. Replaced with a roller bearing and no rubber. You literally get more cabin noise and slight vibration, sharpness through the steering wheel. I feel it’s ok for the street but not if you value some balance of luxury over performance. I run -2.0 deg camber in front and it transforms the car in terms of steering and grip. It is my second car (1-2k miles er year) and, with zero toe, it does not scallop or eat the inner front tires like I was expecting. Just my opinion from an OG M2 with the set-up you mention. Good luck! |
03-21-2024, 12:59 PM | #8 |
4585
Rep 4,687
These cars require a lot of camber to not eat tires. Two track days a year and I'd get the camber plates. They'll pay for themselves on the first set of tires.
You could try the street plates. Can they get -3.5 up front? Anyhow, they aren't difficult to add and remove in between track days if the noise was too much
03-21-2024, 03:33 PM | #9 |
83
Rep 161
A set of street plates at 2.5 might be perfect for OP. Farkle loves his millways.
My vorschlags make a knocking noise on rough pavement or small imperfections in road, and that's pretty much all the roads I drive on. Its less annoying then constantly makes me think the suspensions loose... I check everything is bolted well every time i swap tires. If i wasn't planning on running 10 track days a year or high camber i'd seriously consider the millways. Last edited by Brokenbones; 03-21-2024 at 05:01 PM.. |
03-21-2024, 04:12 PM | #10 |
92
Rep 233
Drives: '18 M2 LCI
Thanks everyone. I don’t track the car, nor do I plan to for a bit. My main goal is to have a car that’s completely dialed in for spirited driving and carving back roads, but retain some level of comfort for road trips (mostly highway miles). Thinking about even sending the coilovers to 3DM for lighter springs/revalve.
Would millway street camber plates be the best option since they allow for camber to properly dial in the suspension, but minimize most of NVH that come with other camber plates like Vorshlag?
'18 M2 LCI 6spd
03-22-2024, 03:29 PM | #11 | |
3863
Rep 54,426
Drives: F80 M3
03-22-2024, 03:32 PM | #12 |
4585
Rep 4,687
I was running a total of -3.2 and it still wasn't enough to stay off the outer edge like I want. Tire temps were even with a cheap surface pyrometer, but I need to get a probe type to really check the evenness of tire temp.
03-24-2024, 01:45 AM | #13 |
504
Rep 880
I run the Millway camber plates (race version) and I have no problem with the added NVH. The tire noise in the M2 far exceeds any added noise from the camber plates. The camber plates in addition to thrust arm front bushing upgrade completely transforms the front end.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
03-24-2024, 09:07 AM | #14 | |
4585
Rep 4,687
03-24-2024, 09:17 AM | #15 |
504
Rep 880
Same here! Car felt like on rails in all conditions. The Millway thrust arm bushing is basically a rear control arm bushing with a lathed housing in aluminium, cheap to replace the bushing and you retain the rubber boot keeping the maintenance at a minimum.
