12-20-2022, 09:29 AM | #1 |
19
Rep 29
NBT EVO HU ID4 > ID6 Retrofit
Hi all,
Currently I have a F80 M3 from 04/2016, I have had it flashed from ID4 to ID6 by kubax86. Last week I used the BMW nav and during a trip that takes about 1 hour, the iDrive crashed 3 times. I know that ID4 comes with 2GB of ram and when you use ID6, 2GB of ram is not enough when you also want to used the BMW Nav. So I'm thinking of doing a retrofit of the headunit to a version that has a least 4GB of ram. I just checked what I currently have in the car and that is a NBT EVO HU with HW 2.3. Also I made a picture of the back of the unit what connections there are and are used. I read some things about GPS and ATM, but if I'm correct my car already uses ATM because the GPS (blue connector) is with my current setup also not used. I have found a NBT EVO HU HW3.1 version, with the exact same connections (only the GPS connection is missing) is it then a simple plug & play and some coding? Will the following unit also work? This one also have DAB+ so I could retrofit that also, or it that not possible? I don't care about touchscreen etc so if possible I would like the screen (professional) that I already have. I'm I missing something, or is my theory correct? Last edited by fabje; 12-20-2022 at 09:54 AM.. |
12-20-2022, 11:10 AM | #2 | |
1801
Rep 3,070
It just doesn't have Satellite radio. Thanks
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
12-20-2022, 12:34 PM | #3 |
19
Rep 29
12-21-2022, 10:22 AM | #4 |
1801
Rep 3,070
Correct
01-25-2023, 02:45 PM | #5 | |
Rep 4
Hi Fabje, I'm doing literally the exact same "retrofit". Currently driving a 2016 F32 which has NBT Evo. I've just bought a HW 4.1 ID6 unit, touch screen and controller. Was all of the wiring the same for both units? Thanks. |
01-26-2023, 06:40 AM | #6 | |
19
Rep 29
I'm only changing the unit itself, I found a HW 3.1 version with DAB+ and already has ID6 on it. I keep my current screen and controller, I don't like the finger prints on the screen Yesterday we made a backup of the current FCS, and when I put in the new unit we are going to try if it works to put back those saved FCS, otherwise I'm going to repair pack route. Also I need to replace the antenna, so I have DAB+ and route a cable from the unit to the antenna, but for that I'm going to wait until better weather. |
01-26-2023, 10:39 AM | #7 | |
Rep 4
Don't have to use the touchscreen (or just keep a nice microfibre handy) Luckily since I have a 2016 car I hopefully won't have to faff around with a lot of this stuff. |
mixmastermike55.00 |
02-08-2023, 06:45 AM | #8 | |
55
Rep 99
Im also about to go through this process, I picked up A HW 4.1 head unit and controller. Interested to see how this works out. |
02-08-2023, 10:48 AM | #9 |
19
Rep 29
I have now the unit worked in the car kubax86 helped me with the coding of the unit.
Including getting the service history from the old unit to the new unit, and already coding in DAB+, now it's up to me to replace the antenna and get the cable from the unit to the antenna. |
02-10-2023, 04:47 AM | #10 |
Coding ECU's remotely
448
Rep 1,181
Only thing to remember, if you car coming from ID4 then the screen (CID) will be an APIX1 - therefore, the latest firmware the headunit can take is 18-03 (NBTEvo_N) - after that you will get random black screens on the CID, this is because the HU is expecting APIX2 screen.
02-10-2023, 05:17 PM | #11 | |
1801
Rep 3,070
fabje18.50 kovalchuk7112.00 |
