05-14-2008, 07:48 PM | #89 |
Dr. Octagon
260
Rep 1,919
lucid:
This just in... I have some numbers for you. FWIW my OEM bootlid came in slightly higher than the figure you have quoted in the OP. Without carpeting or hardware the trunklid weighed in at 26.0 lbs. I understand there are variances with different scales, etc. but thought I would pass on the info. The OEM brake weights that were weighed on the same scale seem to correlate with your figures, however. I weighed the OEMs (Caliper, Rotor, and Dust Shield) and here are the results... Fronts: 41.8 lbs. Rears: 34.9 lbs. ...now onto the BBK and VRS double-sided trunk. I will get you the numbers asap. Stay tuned.
OC ///M
2013 E92 M3 Individual Sold: 2011 E92 M3 SSII | Sold: 2008 E92 M3 SSII | Into a Wall: 2008 E92 M3 SSII | Sold: 2007 E92 335i JB |
05-15-2008, 12:08 AM | #90 | |
612
Rep 10,407
05-15-2008, 06:09 AM | #91 | |
376
Rep 8,033
Does your trunk lid measurement include the mechanism or the lights? If it does, that might explain the difference. The catolog number does not include anything else other than the sheet metal. Also, did you by any chance get seperate measurements on the disc vs. caliper assemblies?
05-27-2008, 01:18 AM | #92 | ||
Dr. Octagon
260
Rep 1,919
My trunk weights did not include the lights/carpeting, trunk release or hardware. They were already transfered to the VRS lid. My measurements are as approximate as the tolerances in the $50 digital bathroom scale. (...sorry swamp.) VRS double-sided cf bootlid w/o hardware, carpeting, etc.---- 14.9 lbs. OEM trunklid w/o hardware, carpeting, etc.------------------ 26.0 lbs. Brembo 380 x 34 front rotor -------------------------------- 24.8 lbs. OEM front rotor-------------------------------------------- 26.6 lbs. Brembo 380 x 28 rear rotor --------------------------------- 17.0 lbs. OEM rear rotor -------------------------------------------- 22.8 lbs. Brembo 6 pot front caliper -------------------------------- 13.0 lbs. OEM front caliper ------------------------------------------ 15.2 lbs. Brembo 4 pot rear caliper ---------------------------------- 9.6 lbs. OEM rear caliper ------------------------------------------ 12.1 lbs.
OC ///M
05-27-2008, 07:17 AM | #93 |
Reincarnated
245
Rep 4,227
Thanks OC!
Looks like -24.6 lbs for a Brembo BBK swap. Not bad at all. Except the price for that kind of decrease is astronomical. -35.7 lbs for the trunk and BBK. Add some lighter wheels to that and you could be at ~55lbs decrease. Not too shabby. Add a Ti exhaust and you could be at ~90lbs. Looks like 100lbs is fairly attainable with "normal" mods. If you want to get crazy like Lucid, you could pull your trunk mat/mobility kit/battery cover out too! You would be at ~103lbs. Could do a battery swap if you wanted. I would add the hood to the figure once a cheaper option comes available.
05-27-2008, 09:48 AM | #94 | |
1913
Rep 4,128
Drives: M235i & G30 540i
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
05-29-2008, 11:44 AM | #95 | |
376
Rep 8,033
05-29-2008, 11:50 AM | #96 | |
376
Rep 8,033
05-30-2008, 01:06 AM | #99 |
Dr. Octagon
260
Rep 1,919
lucid:
Thanks for updating the OP. ...just one small correction, both OEM and BBK calipers were weighed with the pads still clipped on. The 100 lb target is easily achievable and results in improved performance you really can feel. (I'm being serious here now swamp... admittedly the decision to ante up for this weight loss program becomes easier to make with partial sponsorships. I don't think I could do it with this car, but swapping out the front seats would net a pretty hefty weight savings, just from the center of the car...isn't there like three motors in these seats? Are there any 'official' weights listed for the front seats? It would be interesting to see the difference vs. a set of Recaro's or whatever. Thanks again for making this thread.
OC ///M
2013 E92 M3 Individual Sold: 2011 E92 M3 SSII | Sold: 2008 E92 M3 SSII | Into a Wall: 2008 E92 M3 SSII | Sold: 2007 E92 335i JB Last edited by OC ///M; 05-30-2008 at 01:37 AM.. |
05-30-2008, 01:18 AM | #100 |
13
Rep 689
IIRC: The stock seats are 70-80 lbs each. Compared to ~20 for a lightweight seat. The seats in my other track toy are ~15lbs
Now, having said that there is no way I am swaping the seats. The center of the car is the least harmful place to have sprung weight. You will be giving up a ton of comfort for very little gain. 100lbs of sprund weight is going to make about a 2% change in accelration and less in cornering. Lightweight wheels, brakes will help the most since they are unsprung weight and also mostly rotating weight. I once went through this exercise and when confronted with the cost asociated with lighting the E46 I just spent a little more and got a 1600lbs lighter 2nd car. I have tried running the e46 without the rear seat and the diff/fuel pump noises drove me nuts. Not to mention having to explain what was wrong with the car when I picked up the date. Remember having to live with the modification and loss of confort, convience, or utility is a cost just as much as $$$ [edit] My race wheels & tires are 47lbs for a 18x9.5" rim with a 275/35-18 tire. about 4lbs less than stock compared to the same size rears.
Manual gearboxes, the rotary dial of cars.
06-04-2008, 09:51 PM | #101 |
612
Rep 10,407
Great thread. The conclusion is simple it really costs a lot (small fortune) to save even the weight of a passenger (~150 lb) which is about the threshold of what you can feel in a car at 3700lb and 400 hp.
Note: A slightly OT but interesting point: M-DCT is good for about the equivalent of 20hp at just about 9lb/hp and $2700 (not including tax) that works out to be $15/lb. By far one of the best bangs for the buck. Of course this is for acceleration (linear) concerns only, the extra weight of M-DCT does not help handling but is very central and likely not discernable in the real world. +1 on enigmas point - always the pragmatist even though a track fiend - don't mod to the point of making your car no good for a DD (unless you don't DD it). |
06-05-2008, 11:29 AM | #102 |
376
Rep 8,033
My conclusion after going through the exercise is that 100lbs is not worth $15k. I have removed about ~20lbs of stuff from the trunk, and that's as far as I will go with the exception of getting some light weight wheels. I am eying the MORR alloys that Carlos is developing for the E9X M3. He is doing his first production run. Let's see how they turn out. As for the Brembos, I am not interested in them as they cost too much and free BMW maintaince on brakes for 4 years is not something I want to give up. I was happy with the braking performance on the track to begin with. Track compound pads would help, but that's minor compared to replacing the whole setup. If one is racing the car, fade could be an issue, but I am not going to race it or anything, so not worth it for me. If I keep the car for more than 4 years, I might think about a Brembo kit then when the stock rotors, which should already have been replaced under the service agreement by that point, wear out. Finally, I am considering getting a '98 E36 M3 and gutting it for the track. They can be had for ~$13k with 70k miles. '02 E46 M3s are more like $23k, but by next summer they will dip below $20k.
09-13-2008, 11:49 AM | #103 |
Rep 96
Don't know if this has been mentioned but don't forget to drain your windshield washer reservoir (For track use). I don't know the size of the e92 m3 tank but usually you can drop about 10-15 lbs there.
09-13-2008, 11:51 AM | #104 |
48
Rep 1,664
How much is in there? That sucker must be huge.
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options 2007 Montego Blue 335i (retired) |
09-13-2008, 12:14 PM | #105 |
Veni Vidi Vici
89
Rep 2,750
Drives: '11 JB/BBe-6sp-e90
Garage List 2011 e90 M3-Sold [8.50]
2003 RS6 - Sold [0.00] 2009 e90 M3 - Gone [0.00] 2003 M3 SOLD [0.00] old 2002 [10.00] |
My old A4 had about two gallons up in the left front corner behind the headlamp. Emptying the tank is excellent advice.
Dinan compliment of stuff plus PF rotors and RG63s. Enough for now. Why, yes. I am an abrasive bastard. |
09-13-2008, 04:40 PM | #106 |
Rep 96
09-13-2008, 09:38 PM | #107 |
n00b
14
Rep 45
so, what are some good/simple mods one can do to lighten the car w/o voiding any warrantee?
the E46 M3 is about 3400 lbs, while the E90 is 3720lbs. so that is 320 lbs to catch... |
09-14-2008, 12:20 AM | #108 |
376
Rep 8,033
Check the original post of this thread. I documented most of the obvious weight reduction mods there.
09-14-2008, 07:55 AM | #110 | |
188
Rep 1,153
Also, any risk of altering the balance of the car with the various mods?? Great thread though!
2019 M2C MT (ED + PCD) | 2008 M3 Coupé MT | 1995 M3 LTW MT | BMW CCA HPDE Instructor
