Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Dyno n55 procede & DP
      03-23-2011, 04:27 PM   #1
Keik E92 M3
173
Drives: BMW M3 DCT
2009 BMW  [9.00]
2011 BMW 335i  [6.80]
Okay i am back home now... Something was up with either the dyno or my tune control My car was going wild in codes lol airbag error abs error tire pressure error etc etc.. But when i took it home all those codes went away.. The dyno guy was having problems getting the dyno to read but a quick call to shiv and he explained and directed the dyno guy...
BIG THANKS TO SHIV, Best customer service i have ever had by far!
Anyways the car put down 293whp & 370TQ
The TQ was real steady and didn't have any huge boost spikes etc. but the HP was way off to me, My car feels alot faster than 293WHP which is insane to me.. The dyno guy started doing something with his computer trying to figure out some issues and i set the car to map 0 to map 1 and 2 and it only gained about 17WHP from 0-1 and 2 so there is something wrong with either my car on the dyno or the dyno itself. But here is my last run...
BTW Dyno guy was hella nice and hella cool, it was at buttinwillow race way in California.. He let me do like 12 pulls for the price of 3..
This is what made me feel un easy is the pull.. on map 2 WEIRD
its kind of like it went to stock..
      03-23-2011, 04:32 PM   #2
madmanhiker
madmanhiker's Avatar
82
Drives: '11 E92 335i
I'm thinking you should put down more than 293hp for sure..... TQ looks right though......
-madmanhiker jax,fl
      03-23-2011, 04:40 PM   #3
Keik E92 M3
173
Drives: BMW M3 DCT
2009 BMW  [9.00]
Yeah i don't know whats up...
      03-23-2011, 05:01 PM   #4
Juiced46
74
Drives: 03 Turbo Cobra, 2011 335xi
What did it make for power on Map 0
      03-23-2011, 05:05 PM   #5
Mike@N54Tuning.com
Joint Chiefs of Staff
4918
Drives: 2007 335i, 2015 M3
Getting power out of the N55 is pretty tricky since its a MAF car. Post up the 370wtq runs as well as the stock runs also. Maybe seeing the curves will help us spot the problem.
Mike
      03-23-2011, 05:46 PM   #6
Pepe_pr
Puerto Rico
35
Drives: 135i black on black
this is WIERD??? were is the Dyno of the 370tQ?
USED TO HAVE A 385 whp 479 tq N55 335 2011 (AT) AND NOW A 135 M package 2010 (AT) 447whp/504tq
      03-23-2011, 05:57 PM   #7
Keik E92 M3
173
Drives: BMW M3 DCT
2009 BMW  [9.00]
he didn't print it, the car made 360-365-368-370tq but he didn't think it was correct. I believe that should be right but the HP is way to low.
      03-23-2011, 06:10 PM   #8
Juiced46
74
So what is the sheet you posted above?
      03-23-2011, 06:11 PM   #9
OpenFlash
1737
Drives: A Lot
Without seeing the actual dyno graph, I'm willing to bet that your car went into valet mode in the middle of a run. This is the one issue with running a boost setting that is equal to your max boost setting. If boost exceeds the max boost setting by 1psi for longer than 1 second, the Procede will go into valet mode. And on the dyno, when you lug it from a low RPM, in a high gear, just this can happen. You can get around this by increasing the boost delay user adjustable value or by increasing the max boost value.
The other problem your dyno operator had was that he didn't know not to press past the throttle kick-down switch. When he did this, the car would downshift. This is why he thought your transmission was slipping. Once I explained this to him, that issue was solved.
I'm actually on a dyno right now as I type this. I'll be writing up a "How To Dyno Your N55/N54" tutorial just to avoid these issues in the future.
BTW, our n55 with our DP and home-brew 3" exhaust is putting down:
353whp/425lbft at 15psi
342whp/380lbft at 12psi
Pretty easy formula and will be explained later tonight...
Cheers,
Shiv
      03-23-2011, 06:18 PM   #10
Juiced46
74
Cheers,
Shiv
Shiv, do you have any exact recommended settings for the boost delay and max boost if this issue occurs?
If we set the max boost to more boost then the 14psi you are telling us to run now on the N55 wouldnt it make more, essentially whatever we set it to? Is there anyway to set it to say Max of 16, but only run 14? Slightly confused on what you are trying to say here.
      03-23-2011, 06:27 PM   #11
chocobo15
(X_X) O-(^.^Q)
16
Drives: 2013 528i
Shiv you guys make your own DP's now?
      03-23-2011, 06:30 PM   #12
Slops
Slops's Avatar
South Africa
188
Drives: 2005 C55 AMG
Yup i have 1
      03-23-2011, 07:03 PM   #13
Keik E92 M3
173
Drives: BMW M3 DCT
2009 BMW  [9.00]
Cheers,
Shiv
This is exactly what i think my car was doing. Because even in map 0 it was making similar power to map 1 and 2. I never got past 300whp.. But on the street my car was a huge difference between map 0 and map 1.
Your guys car put down alot of power, i was hoping to get this amount. PM me if you can. I am going to send some Data-logs your way.
      03-23-2011, 07:25 PM   #14
e92sport
38
Drives: black e92 sport
Cheers,
Shiv
Damn that torque is insane!!! What is your exhaust set up like? I'm in the market right now for making a custom 3" exhaust
      03-23-2011, 07:38 PM   #15
OpenFlash
1737
Drives: A Lot
From my testing today:
15psi
14psi
12psi
Stock tune
Mods: Procede v5 3-21, Vishnu DP, Vishnu Charge pipe, muffler shop catback with dual magnaflow mufflers
CF: 1.05
I'll post a 'how-to dyno' later tonight. The procedure is pretty common sense but sometimes things can get overlooked and you end up with an invalid result.
Cheers.
shiv
      03-23-2011, 07:38 PM   #16
FrankiE90
FrankiE90's Avatar
654
Drives: Krooked Sk8board
what a cool place to dyno
"7's only racing"
awesome.
so increasing the boost delay values // or increasing max boost values.
I'm add'n that to the mental note.
awaiting "how to dyno ur n54/n55"
n55 such a torque monster.
keikdasneak did u happen to get the runfiles saved to
ur computer?
dynojet has a free download software
to read ur files.
FrankiE90 AKA:.[The TANK] *CLICK THE SIG
E90s (been gone but not forgotten) • KW clubsports • • • • • • • • • • 18" BBS GT4 // Build E30 (pending) + E46 M3 Wagon ESTORIL Blue
      03-23-2011, 08:05 PM   #17
madmanhiker
82
yup - and I have one too... and i LOVE it.
-madmanhiker jax,fl
      03-23-2011, 11:26 PM   #18
htt760
PROcede it and Call it a DAY
17
Drives: 2011 135i DCT, 2011 335i
Me tooo.... The DP and Procede Combo is monster torque!!! .... Im a little concerned about the DCT holding the torque because it just rips!!
      03-24-2011, 02:58 AM   #19
shockin330i
shockin330i's Avatar
798
Drives: 2016 ZCP M3
I had the same results back in the day.
run 3 is 13psi and run 8 is 14
ERnie
2016 BSM/f80/ZCP
      03-24-2011, 05:48 AM   #20
Pepe_pr
Puerto Rico
35
Shocking that dyno you did not have the new maps rigth? Neither the fuel conector?
      03-24-2011, 08:37 AM   #21
shockin330i
798
Drives: 2016 ZCP M3
Correct
ERnie
2016 BSM/f80/ZCP
      03-24-2011, 10:19 AM   #22
htt760
17
Correct
Shockin, is yours an automatic? If so like Shiv said the throttle switch kicked in the percent increase on load and i guess down shifted. This happened to me on the dyno as well with a automatic 335i.
We have to gradually pull up around 2500 to 2700 rpms before we can stab the thorttle.
