05-16-2009, 07:56 AM | #45 |
374
Rep 8,033
XP12 has more bite, but I didn't have trouble modulating it. You would be fine with either I think. I got XP12s mainly because of the temperature issues I was having at the Glen; they can operate at higher temps than the XP10s. Measuring rotor temps and having an objective sense of where things are might help you make the choice. HT10s I used at the Glen scored both rotors deeply in several locations. After a day with the XP12s, those grooves are smoothed out, so they can grind things down. Although the wear with XP12s is even, which is a good thing, it is somewhat visible after one track day. So, I guess that is the trade-off between a more aggresive pad like the XP12 and RS19/XP10 (fade resistance and bite vs rotor wear). My 2 cents...I know there are other people on this forum who have used XP12s, so maybe they can chime in as well.
05-16-2009, 12:33 PM | #46 |
Bates '08 Interlagos Launch
126
Rep 1,230
Ya, so there are always tradeoffs. I think that if you are not a super hard braker, go with the xp10. I used them for two seasons (note on my z06, not m3), and they were great. I never really felt like I needed the xp12, but I am not hard on brakes and would occasionally take a cool down lap mid-session just to regroup.
Lucid, thats cool the carbotechs smoothed your pads out for you. I guess it makes sense though that the wear is visible.. it was only touching half the rotor surface most of the time! BTW, I never have actually worn a rotor down, they always spidered and needed replacement far before they wore through. |
05-16-2009, 12:55 PM | #47 |
374
Rep 8,033
Although there are no real "cracks", there is plenty of spidering on my front rotors. They are done...
05-16-2009, 01:58 PM | #48 |
73
Rep 724
WHO has the best price for the RS19s? Turner and German Performance are the same. Anybody else? They are starting to become less rare now that all the shops are beginning to get them in again.
05-18-2009, 10:58 AM | #50 |
84
Rep 628
My Carbotech XP-10's has no place for the wear sensors?? What is the case with the XP-12's?? By the way I dont have sensor on the rear drive side break.
Bedded them this weekend and seems fine. There is some noise when cold but not unbarable. Cleaned the rotors somewhat. When changed the pads, bleeded the breaks I realized how much damage was done by the melted OEM pads. There are tons of deposite on the rotor, and the pads looked like marble and cooked. How could you remove the metal plate shielding the rear rotors?? Anyone?? I have a feeling that thing just hurts the break cooling. |
05-18-2009, 06:01 PM | #51 | |
73
Rep 724
05-18-2009, 06:24 PM | #52 | |
30
Rep 915
I could not get their site to list them either. Perhaps you have to use the telephone. vz
Previous Track Toy |
05-18-2009, 06:32 PM | #53 | |
28
Rep 309
We should have done a Carbotech group buy. Also, what is everyone running for brake fluid after bleeding?
The Verdict: Every other manufacturer should give up on building their own cars and just make M3s instead. -Car and Driver June 2008
05-18-2009, 06:56 PM | #54 |
374
Rep 8,033
Yes, this is a problem with Carbotechs. The bonding material overflows into the contact sensor groove. You don't really want the sensor on when you are at the track anyway. You should know how much pad material you have left. Once the sensor makes contact, the light on the dash comes on, and you need a special tool to reset it and replace the sensor. Just zip tie the the sensor and its cables to your suspension.
05-18-2009, 07:46 PM | #55 |
16
Rep 275
05-19-2009, 09:22 AM | #56 |
30
Rep 915
That is what I do plus I use electrician tape around the end to make sure that it does not make inadvertant contact with metal.
vz
Previous Track Toy Last edited by von_zoom; 05-19-2009 at 12:12 PM.. |
05-19-2009, 11:16 AM | #57 |
84
Rep 628
05-19-2009, 12:11 PM | #58 | |
30
Rep 915
vz
05-20-2009, 02:29 PM | #59 |
84
Rep 628
Castrol SRF looks - by color only- similar to the factory break fluid. This is good since a BMW tech will not be able to see you changed your fluid, which potentialy could void the warranty on the breaks.
However it is not easy to see the new fluid when you bleed your breaks. ATE has blue and gold color fluids so it is easy to see the new fluid comming into the system. The cold modulation on the XP-10 is not as good as the OEM pads but as soon as there is some heat they work better. |
05-20-2009, 03:19 PM | #60 | |
28
Rep 311
05-20-2009, 03:43 PM | #61 | |
84
Rep 628
I got the SRF, not because I need it but was available when others (Motul, Super ATE) were not. |
05-20-2009, 09:57 PM | #63 | |
128
Rep 1,144
I find it funny how many people say that SRF is unnecessary and then are also whistling the merits of an $8K BBK. SRF is magical. If you are a track rat, instead of flushing 4x per year, you will only need to do it once, and on top of that, probably not heave to bleed the system either. |
