BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) BMW E-sys coding for the f48 x1
      05-12-2016, 09:54 PM   #89
dmnc02
dmnc02's Avatar
920
Drives: 2015 M4
Originally Posted by eml View Post
Right now the adaptive feature only works when the light switch is set to automatic (one click to the left of "off"). Is there a way to enable the feature when the switch is placed on regular main beam position (two clicks to the right of "off")?
I am not sure.
For High Beam Assistant, this is controlled by BDC_BODY > FLA_AKTIVIERUNG, which can be set to LDS_in_A (feature only available with the light switch in position A) or LDS_in_A_oder 2 (feature available with the light switch in position A or II).
There isn't a similar AFS_AKTIVIERUNG parameter for VLD, so it is possible that FLA_AKTIVIERUNG controls the activation of both adaptive features (VLD and HBA), but I have not tried this on my wife's car.
2015 Mineral Grey ///M4 6MT
      05-12-2016, 11:03 PM   #90
PF1
92
Drives: F48 X1 xDrive25i M Sport
Does anyone know how to activate rear lights to be on all the time? ie. Together with front DRLs.
Thanks!
      05-13-2016, 12:20 AM   #91
M-Nick
M-Nick's Avatar
37
Drives: BMW
Thanks!
BDC_BODY > 3064 > MAPPING_TAGFAHRL_1_H_L_OUTPUT > sl_l
BDC_BODY > 3064 > MAPPING_TAGFAHRL_1_H_R_OUTPUT > sl_r
BDC_BODY > 3065 > MAPPING_TAGFAHRL_2_H_L_OUTPUT > sl_2_l
BDC_BODY > 3065 > MAPPING_TAGFAHRL_2_H_R_OUTPUT > sl_2_r
      05-13-2016, 06:22 PM   #92
PF1
92
Thanks M-Nick, found those lines now so will give that a go!
Different line for that function than the F30 guides I was using.
      06-28-2016, 03:57 PM   #93
smm68
Netherlands
Drives: X1 x25d
hello
is there a way to disable collision warning and braking by default via coding?
thanks
      07-06-2016, 02:45 PM   #94
hyperspeed
hyperspeed's Avatar
233
Drives: 2018 R8, MYP, GLE
Can anyone confirm if we're to use F056 or F025?
2018 F80 M3 AW / SO
      07-06-2016, 08:21 PM   #95
PF1
92
You use F056 to start the Esys software (the launch screen) then use F025 to Connect to the car.
      07-07-2016, 09:04 AM   #96
dmnc02
dmnc02's Avatar
920
Drives: 2015 M4
This is not right. You select F048 (not F056) as the Car Series in E-Sys Launcher and then F056 (not F025) as the Connection Target in E-Sys.
Appreciate 2
stefan2361.50
963mw331.00
      07-07-2016, 11:21 PM   #97
stefan
stefan's Avatar
No_Country
2362
Drives: M2 Comp
Haha wow looks like things got easier since I last coded an E39 and e46. Ordered an enet cable and will report my findings.
      07-08-2016, 04:37 AM   #98
PF1
92
Oh yes you are right, I had a brain fade moment there lol
      07-08-2016, 04:21 PM   #99
ScottishX1
ScottishX1's Avatar
Scotland
23
Drives: 16 X1 F48 25D M-Sport Estoril
Could someone please send me a link to the latest e-sys and psdzdata?
Thanks in advance!
      07-09-2016, 01:25 PM   #100
simon.
923
Drives: F48 25D mSport
Thanks in advance!
Pm Shawn Sheridan & ask him nicely & he will send all the links that you need
      07-10-2016, 12:49 PM   #101
ScottishX1
ScottishX1's Avatar
Scotland
23
Thanks Simon
      07-11-2016, 04:23 PM   #102
smm68
Netherlands
Drives: X1 x25d
For those who are interested, with the help of Almaretto I managed to disable Front Collision Warning, Pre-crash and Pedestrian warning in my X1 F048.
I decided to do so after reading several cases of the system inadvertantly kicking-in and braking the car in normal situations.
Notice that once disabled FCW cannot be turned on through the dashboard button.
Here are the parameters.
Module is KAFAS2
Section 3060
FCW_ON_OFF -> FCW_off, Werte=00
PRE_CRASH_ON_OFF -> pre_crash_off, Werte=00
Section 3150
PPP_MANUAL_ACTIVATION_ON_OFF -> Werte=00
Many thanks to Almaretto
      07-12-2016, 09:45 AM   #103
DG20
DG20's Avatar
970
Drives: M340i
Hey, does anyone know where to find a cheat sheet for the X1?
Instagram: @dg_g20
      07-12-2016, 09:54 AM   #104
Saintsman
Saintsman's Avatar
40
Drives: X1 2.0i x-drive Sport AW
Originally Posted by Vogit View Post
2) Display road speed in the instrument cluster (With seat and wheel set for comfort i can't easily see both the speedo and the information display).
If the speed changes to kmh that would be perfect for continental driving.
      07-12-2016, 02:02 PM   #105
BillyBonk
Drives: 2016 X1
https://docs.google.com/spreadsheets...bnw/edit#gid=0
Try this link.
      07-13-2016, 10:06 AM   #106
Vogit
93
Drives: X1 xDrive 20D xLine
Just checked, and if you set units to km the speed display in the instrument cluster does read in km/h. The speed displayed when setting cruise control is still in mph, however.
My last car, a VW, had a permanent digital km/h display in the cluster, which was handy, but didn't have any km/h markings on the speedo dial. I always find the useful as a quick distance conversion from miles to km when driving sur le continent.
      07-13-2016, 11:27 AM   #107
Saintsman
Saintsman's Avatar
40
Its an odd mix. On my recent trip I set the units to kms and had all the speed limit signs changed to kmh, but was still reading mpg and mph in cruise as you said. Other cars I've had have set everything to kph, l/100 etc. Still, it didn't effect the drive experience so I'll just put up with it next time.
      07-13-2016, 03:25 PM   #108
ScottishX1
ScottishX1's Avatar
Scotland
23
Do you know what his username is?
      07-13-2016, 03:46 PM   #109
Vogit
93
Look on the bimmerfest.com forum - he's "shawnsheridan"
      07-15-2016, 02:32 PM   #110
ScottishX1
ScottishX1's Avatar
Scotland
23
Just done my 1st coding, enabled the speedo in the instrument cluster, works great
KOMBI - 3000 - BC_DIGITAL_V
Change it from nicht_aktiv to aktiv
Going to try some others tomorrow.
xbimmers
