05-03-2020, 06:16 PM | #1 |
GGGBMR
Rep 5
Drives: 2020 M550i, 2007 530xi
Rattle from front passenger seat/headrest
I have a new M550. Great so far (except can hardly drive due to virus shutdowns). But I have one very annoying rattle that I think is from the front passenger seat/headrest. Happens when going over rough patch of road or just small bumps at any speed over about 20mph. Obviously will bring to dealer but any thoughts out there?
05-03-2020, 09:56 PM | #2 |
17
Rep 30
I had the same thing, sounds like it's coming from the passenger seat, but I've narrowed it down to the sunroof. Only rattles when the sunroof is closed and the shade is open. Will have the dealer look at it next time it's in for service.
05-03-2020, 10:57 PM | #3 |
GGGBMR
Rep 5
Interesting. I will check that out. Thanks
05-12-2020, 01:28 PM | #4 | |
Rep 8
05-12-2020, 06:49 PM | #5 |
GGGBMR
Rep 5
Well, that is true, in that I haven't even had a passenger yet. But I have tried the seat belt trick, and it hasn't worked.
05-13-2020, 03:01 AM | #6 | |
163
Rep 321
I also recently had the sunroof squeaking issue that you mentioned on my G30. It seems like a common issue. I was going to take it to the dealer to have it looked at under warranty, but tbh I was too lazy for something so simple! Then, I remembered I still had some of the Gummi Pflege around (hadn't used it since I used it on my E90 years ago) and I lubed up all of the rubber seals around the sunroof and BOOM no more noise! Try it out.
2018 G30 540i xDrive M Sport | Carbon Black Metallic | KW V3 Coilovers | F90 Suspension | F90 Brakes | 20" HRE FF10 Liquid Black Wheels | Michelin Pilot Sport 4S Tires | Ivory White Dakota Leather | Carbon Fiber Trim | Executive Package | Bowers & Wilkins Diamond Surround Sound System | JL Audio 12W6v3 and XD600/1v2 | Ceramic Controls | BM3 Stage 2+ E50 ECU Tune | xHP Stage 3 TCU Tune | Dorch Stage 2 HPFP | MST Cold Air Intake | FTP Chargepipe | AA Catted Downpipe | Remus Catback Exhaust
05-15-2020, 02:41 PM | #7 |
248
Rep 538
In my car, I have a similar rattle, but it's the passenger seat belt buckle hitting the plastic covered pillar between the doors. fixed it by placing some adhesive 1/4" thick felt tape on the pillar where the buckle was hitting. Obviously only happens when no passenger with seat belt on.
05-15-2020, 03:41 PM | #8 |
GGGBMR
Rep 5
I have tried all the seat belt buckle tricks, including fastening the seat belt as if there was a passenger in the seat. But still the rattle. And the visible vibration of the seat back and headrest coincide with the rattle.
I will take it to dealer as soon as it is safe to do so. Thanks for all the inputs and suggestions. |
06-07-2020, 11:35 AM | #10 |
GGGBMR
Rep 5
So, finally was able to take to the dealership to get seat rattle looked at. Fortunately there was a guy there with a lot of experience who had seen this before, and the solution was simple. My wife is working overseas and can't get back here due to the virus. So nobody has been in the front passenger seat since I picked up the car. As a result the seat was in the full upright position from the factory. Simply tilting the seat back about 10 degrees resolved the situation since this allows more flexibility, per the mechanic, especially with a brand new car.
07-23-2020, 02:00 PM | #11 |
17
Rep 30
I had the dealer take a look at my rattle while the car was in for an oil change. They determined the rattle was coming from the sunroof seal and replaced it. Haven't driven it yet to confirm, but the dealer said that it eliminated the rattle on their road test.
07-26-2020, 08:54 AM | #12 | |
181
Rep 546
