BMW X5
      11-13-2018, 05:22 PM   #45
e90_2_f80
e90_2_f80's Avatar
239
Drives: M3
Originally Posted by denniss View Post
this will not work, its for 2018. Tirerack is not aware of the bolt pattern change. You will need to return those
You are wrong on this.
The MSW has a 5 x 112 pattern and fit the hub as well. DrKev is correct and his fitment was confirmed by tirerack and my BMW dealer parts guy.
Tirerack did scan of a G05 x5 with msport and the MSW style 48, also 49, and OZ cortina also works.
Cheers!
I hope you are right. I spoke to tirerack today and they confirmed that they don't have anything for 2019 g05. When are you getting your set ?
I placed the order today via TR.
Call them and ask for Ethan x4689
      11-13-2018, 05:40 PM   #46
NOVA99
163
Drives: 2021 M-B GLS 580
I am still waiting for someone (tire mfg. or forum member that finds something) to come up with a tire only solution for all season. My current and previous m-sports I put Conti DSW on the 20 inch staggered--works great. No solution yet for the new G05 22 inch that I can find. I am about a year out and looking forward to M50i; hope there is staggered 22 inch all season coming. JLR & Conti have 22 inch for RRS but those setups are not staggered or quite as wide. All your new G05's look spectacular BTW.
2020 X5 M50i
2017 X5 50i M-Sport (Retired)
2013 X5 50i M-Sport (Retired)
      11-14-2018, 12:18 AM   #47
tobian
Poland
25
Drives: 2019 BMW X5 40i
I ordered 20' wheels for winter - front 9J, rear 10,5J.
Which size of tires will be the best for this setup?
      11-14-2018, 03:30 AM   #48
BigCactus
74
Drives: X5M Comp F95
You've made a mistake and you should change your order - you had to order both front/rear 9J and tires 275/45/20. That's a right size in Poland - call your Dealer.
      11-14-2018, 04:51 AM   #49
tobian
Poland
25
When I will change my order for:
Front: 275/45/20 ET 35 - 9J
Rear: 275/45/20 ET 25 - 9J
Then it will be ok?
      11-14-2018, 04:55 AM   #50
Jrunr
Germany
188
Drives: 2019 BMW X5 M40i - G05
I can't wait to see pics of these winter sets on the G05!
Please post pics ASAP!!
      11-15-2018, 08:12 PM   #51
GWN18
Drives: 2019 X40i MSport (on order)
Has anybody put these on a G05 Msport yet? I would be interested to see photos if possible. The mfg confirmed that 19" will not fit over the Msport callipers but 20" is good.
      11-15-2018, 11:02 PM   #52
Refujeet
265
Drives: X7
Waiting for my car...should have been here on Monday.
I'll be mounting Nokian Hakka R3s on these.
      11-16-2018, 03:21 AM   #53
M3 Chris
M3 Chris's Avatar
38
Drives: 991.2 GT3 RS, X7 4.0
Just ordered VMR 710 20 X 9.5 ET 37 in matte black.
Square setup with Yokohama Iceguard IG5 in 275/45/20
I might get 25MM spacers to push the wheels out to be more flush with fenders
Suck i have to take off the 22's so soon..
      11-16-2018, 08:29 AM   #54
DrKevM5
DrKevM5's Avatar
2278
Drives: G05 X5, F87 M2
Confirming the 20" winter package from Tire Rack does in fact mount beautifully on the G05. Not my truck, but I asked one of my service guys to test fit it. Plenty of room around calipers.
?16 M2 Long Beach Blue/Black, 6MT
'22 X5 4.0 M Sport Black Sapphire/Tartufo
?22 Tesla Model Y Performance Midnight Silver/White
e90_2_f80239.00
      11-16-2018, 09:04 AM   #55
Jrunr
Germany
188
Awesome!!
      11-16-2018, 09:44 AM   #56
M3 Chris
M3 Chris's Avatar
38
Good looking wheels!
Do you know if tire rack supplied new tpms sensors? Supposedly you have to supply your vin to get the tpms sensors to be programmed first.
      11-16-2018, 09:54 AM   #57
denniss
denniss's Avatar
392
Drives: BMW
So you know if tire rack supplied new tpms sensors? Supposedly you have to supply your vin to get the tpms sensors or be programmed first.
good point, i am sure these sensors are not cheap!!
      11-16-2018, 10:10 AM   #58
DrKevM5
DrKevM5's Avatar
2278
Wheels come mounted with TPMS
      11-16-2018, 12:09 PM   #59
Jrunr
Germany
188
Looking for more winter set-ups here! Anyone else have anything?
      11-16-2018, 02:09 PM   #60
like2short
139
Drives: E93 m3
wheels from GL/GLS or ML/GLE or even S-Class can work.
mercedes is 5x112 with the same centerbore as BMW now. (66.6mm).
The GL/GLS has offset around -60mm, so you will likely need a 15-20mm spacer for an X5.
The S-Class is around -40mm which might fit directly without need for spacers, get the appropriate lug bolts.
      11-17-2018, 03:22 AM   #61
Jrunr
Germany
188
I called tire rack and even though i had the size and offset they wouldn't recommend any wheels because they don't know if the spokes will clear the brakes... I need to get a winter set ordered here SOON!
      11-17-2018, 03:34 AM   #62
JLR0523
90
Drives: 2019 X5 50i
Sounds great. Our X5 50i is in production now. So we’ll need to get a set ordered soon. My only remaining question - the test mounting for these wheels looks great. However it’s the std caliper. I will have the M brakes. Will these wheels work w those calipers?
Thx in advance for all the info on this winter setup!
      11-17-2018, 09:36 AM   #63
DrKevM5
DrKevM5's Avatar
2278
Sounds great. Our X5 50i is in production now. So we'll need to get a set ordered soon. My only remaining question - the test mounting for these wheels looks great. However it's the std caliper. I will have the M brakes. Will these wheels work w those calipers?
I also ordered the M brakes. It will definitely clear the calipers. A 19" setup could be a little tight.
      11-17-2018, 03:55 PM   #64
JLR0523
90
Drives: 2019 X5 50i
Thanks. I’ll be going 20” so I should be good.
EDIT: since posting this, I went to tire rack and it he MSW type 48 in 20” are sold out for the season. Damn.
      11-17-2018, 04:26 PM   #65
DrKevM5
DrKevM5's Avatar
2278
Thanks. I'll be going 20" so I should be good.
EDIT: since posting this, I went to tire rack and it he MSW type 48 in 20" are sold out for the season. Damn.
I called my guy at Tire Rack, and apparently there was a run on them yesterday after I confirmed fit. :
      11-17-2018, 10:40 PM   #66
XGoober
XGoober's Avatar
295
Drives: X5 45e
Apologies if this is a dumb question but I am a newcomer to needing winter tires. Last season was my first time living near snowy conditions so I had a set of Blizzaks mounted on my F15 stock rims. I see most folks in this thread seem to prefer a completely separate set of rims and tires rather than just swapping the tires twice per year.
Any reason why that would be preferable? I can think of salt perhaps causing corrosion on the rims, but I typically wash my car as soon as I get down from the mountain (just go up for ski days, and back to wet but not snowy conditions for the rest of the time).
Thanks!
xbimmers
