02-06-2019, 12:13 PM | #23 |
1412
Rep 1,812
All X3d (xDrive28d) use the 96mm rubber giubo for all dates of production. So not really as much of an issue.
It also uses the ATC 45L transfer case which uses a chain drive. I bet the flange is not pressed on either. By the way, the x3d is a very nice car. I tuned my dad's X3d with my 245hp/400ft-lbs tune, which works perfectly fine with stock emissions equipment, and it gained 2-3mpg to the running average. Regarding clutches, yes, all clutches eventually wear out, as those are actually normal wear items. Different tire sizes will accelerate that wear, that's just inevitable. It shouldn't be a whole transfer case replacement for that. The clutches can be replaced. Of course it's up to the owner if they want to put up with that.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. |
02-06-2019, 12:33 PM | #24 |
David
786
Rep 2,009
They eventually wear out yes, but very prematurely. That was in the issue in my car at approx 45k miles, so regardless of what happens with the output shaft it's life still isnt very long haha
02-06-2019, 12:35 PM | #25 |
197
Rep 368
So, if I remember right the stock disc is rubber with aluminum sleeves around the bolt holes. So is the one that you ordered just all rubber with no sleeves? Is that a custom item or is it available off-the-shelf anywhere? My TC already has 20 K on it, but I would be tempted to try this fix. It definitely sounds like a must if I pull it down and rebuild it again.
02-06-2019, 12:37 PM | #26 |
1412
Rep 1,812
Are the pictures not showing up for you, or anyone else?
I uploaded them on my Onedrive and embedded from there.
02-06-2019, 12:39 PM | #27 | |
1412
Rep 1,812
I have this exact part arriving today:
02-06-2019, 12:43 PM | #29 |
1412
Rep 1,812
I will fix the pics ASAP. That would make a lot more sense.
Kudos to everyone using just their imagination!
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. Last edited by Enabled; 02-06-2019 at 02:18 PM.. |
02-06-2019, 02:48 PM | #30 | |
1412
Rep 1,812
My original transfer case is at almost 90k miles, without clutch issues. Once I open it, I will evaluate the clutches. I would have loved to find out why that failed so quickly on yours, however.
02-06-2019, 07:21 PM | #31 |
David
786
Rep 2,009
Not sure I'm the second owner but looking at the previous owners info in iDrive suggests it was an older woman, you did see the google doc with the list of failures right?
Transfer case failures database I'm not the only one who's had clutch pack failure that early, but then again it could be caused by metal flakes in the fluid from the output shaft
02-06-2019, 07:39 PM | #32 |
1412
Rep 1,812
Yes, I have seen that thread. There are at least 2 different failure types, and since the dealer did most of those replacements, there isn't really a good way to know which failure was which. Missed opportunity by them to actually solve a problem..
How did yours fail and what led to the diag of clutches gone out? Output flange seems to be more common, but this isn't definitive. For now, I'll be running mine in 2wd mode, until I actually need 4wd.
02-06-2019, 07:43 PM | #33 |
David
786
Rep 2,009
I had the misfire/skipping feeling under hard acceleration which only leads me to believe the clutches are slipping
02-07-2019, 10:09 AM | #34 |
197
Rep 368
Mine had a similar feeling before the flange self-destructed. It starts to slip before it completely rounds the teeth out. In my 2 cases the clutches were fine. But I can imagine that some miss placed shavings could do some pretty good damage to the clutches. I don't think too many people have torn them apart
02-07-2019, 02:18 PM | #35 |
1412
Rep 1,812
I agree, it sounds like output flange failure actually, on the verge of letting go completely. Then you have front wheels pulling for a while, and you will have transmission output plausibility codes.
kdog_x, did your new case come fully filled with fluid? I checked mine twice, once on floor, and again on car, and it seemed to be full. I didn't check again later. Also, was your flange hand-pressed, or did you use a puller at any time? All mine required was a moderate tug and it came out.
02-07-2019, 03:06 PM | #36 |
197
Rep 368
My new one came with fluid, but it leaked all over the shipping box. I topped it back off on the car. I didn't remove the flange from the new one, but if I remember right the old one took some persuading with a rubber mallet to remove.
02-11-2019, 10:29 AM | #37 |
1412
Rep 1,812
After some discussion with a ZF drivetrain expert at BMW HQ, they recommended to use Loctite 660 on flanges with mild wear, because it's designed to replace air gaps in splined shafts.
Vibration protection is the goal to save the output flange. He did say that output flange may benefit from some hardening, but looking at the mild wear on the transfer case shaft and flange, I'd rather not have that be the harder component, and put the eventual wear onto transmission output shaft.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. Last edited by Enabled; 02-11-2019 at 10:49 AM.. |
02-11-2019, 10:58 AM | #38 |
David
786
Rep 2,009
Did you ever find out if the part was updated from pre-lci cars? I heard there was a different part number, seems like nobody can confirm anything.
02-11-2019, 11:07 AM | #39 |
1412
Rep 1,812
For the transfer case itself?
There is no update. The LCI just uses a 96mm flex disc, so the transfer case has a 96mm output flange of the same design. Vs. the pre-LCI's 105mm. That's the only reason for the part number ending in 27108643150 vs 27108643149. Now if there is an update between the very first part number and the 150 or 149, no idea. All the part numbers lead to the same design drawings and revisions, just different output flange size.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. Last edited by Enabled; 02-11-2019 at 11:28 AM.. |
02-11-2019, 11:57 AM | #41 |
1412
Rep 1,812
He did not, as his focus is the ZF transmission. I did get some interesting warnings from him to avoid launches and all launch control coding, because the torque converter lockup overheats the tone ring which can explode the planetary gears. I wasn't even intending to launch. Lol
Also, the transmission is already put into 'neutral' while idling by using torque converter, and brake A and B clutch behaviors to pull the output torque. It won't be full neutral, however.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. Last edited by Enabled; 02-11-2019 at 12:05 PM.. |
02-14-2019, 09:49 AM | #42 |
1412
Rep 1,812
Also, I found out revision history on the ATC35L, and the major changes for updated part numbers were for corrosion protection on the output flanges, I believe especially the front output flange, since it sits lower. So nothing real significant.
FaRKle!4023.50 |
02-16-2019, 09:11 AM | #43 |
197
Rep 368
That loctite 660 is popular for repairing wobbly crank pulleys on Miata engines so theoretically it would work great for this application. It dries anaerobically though, so if it's exposed to air it will not harden. I'm thinking it may be anaerobic enough just reinstalling the spacer and circlip and bolting the driveshaft back in place. The loctite videos on youtube recommend using a hardening primer (7649) before applying the 660. The video indicates it's good to go in an hour with the primer, though I'd probably still go with a 12 hour cure.
02-16-2019, 01:24 PM | #44 | |
1412
Rep 1,812
