F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Oil Burner?
proTUNING Freaks
      02-07-2013, 11:53 AM   #23
shivaswrath
shivaswrath's Avatar
649
Drives: 2012 335i
Thanks! Geez, they recommend checking the oil level whenever you fuel up? I'd get screamed at sitting at the gas station waiting the 3 minutes for the engine to measure it...
$6.77 for a quart of oil is kind of stupid...but I guess now with my
I'll be all set....
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
      02-08-2013, 06:13 PM   #24
PeterM
17
Drives: bmw 335i
Finally hit 1k miles on a hard break in and oil is at maximum.
2013 EB2 335i 6MT
      02-11-2013, 01:49 PM   #25
Axman85
77
Drives: 335i x-Drive M-Sport Min. Grey
Well, 630 miles into that new quart and it's down 25% again. Maybe I should drive like an old lady and not go beyond 4k rpm. TROUBLING to say the least.
      02-11-2013, 09:24 PM   #26
Noeh
Drives: 2019 BMW X3 xDrive30i
I'm wary of Audi's 2.0T because of oil consumption, I hope this is not widespread with the N20
      02-12-2013, 10:14 PM   #27
WilliamE92
WilliamE92's Avatar
21
Drives: 2013 EB F30 335 MT
After a "hard" break in my N55 hasn't dropped a tick from max after 4k miles.
Changed the oil to German Castrol (0w-30) at 4k, and still sitting at max 3k miles later.
Had the same result with my N54 - little to no oil consumption whatsoever.
I'd be interested to see how those who are experiencing excessive oil consumption broke in their engines.
      04-05-2013, 03:27 PM   #28
Axman85
77
At 4200 miles I was down a 2nd quart. BMW NA told me that they won't even investigate oil consumption unless it's at a rate of 1 qt every 750 miles or less. A bunch of BS.
      04-05-2013, 04:31 PM   #29
tdizzle
107
Drives: 2017 F80 ZCP
Sheesh, that seems high. I was down half a quart at 6800 miles. At 3k it still read 100%.
      04-06-2013, 10:48 PM   #30
shivaswrath
649
Drives: 2012 335i
At 11,500, had an addt'l qt added at 5 or 6k, and still at max.
I get a free change end of April, so lets see...
      04-07-2013, 10:54 AM   #31
cfm56d7b
5886
Drives: 2017 440i Gran Coupe & 2015 X5
I just checked oil level at 978 miles (2013 BMW 335i xDrive). At maximum.
      04-07-2013, 01:28 PM   #32
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Drives: 2018 Audi S3
Any one else seeing any oil consumption on an F30 335xi? Just shy of 1k miles and my oil level is down about 25%. Hope it's not an oil burner.
Yes I added a quart at around 10k. It said via onboard diagnostics it was at minimum. I added a quart and it was ok.
I think it typical of any turbo car to burn a bit of oil especially during breakin, nothing to get freaked out about. Audi's on te other hand are strangely widely known for their love of devouring oil. Everyone I knew that owned an a4 always complained about the oil lamp being lit constantly. I have a friend at work and his wife's a4 needed new turbos before 10k and new timing belt. I like Audi styling but not a fan of their poor quality.
FBO-PS1 and stuff
      04-16-2013, 05:41 PM   #33
Agamemnon
175
Drives: 2016 m3 ss2 zcp full leather
Coming up to 3,000 km after a nice open road trip around the Olympic Peninsula. Onboard measurement states that oil is at maximum. My break in period has been done per the owner's manual and I have tried to vary the engine speeds throughout. No heavier throttle usage until the oil is completely warmed up.
      04-20-2013, 08:43 PM   #34
NordicBob
NordicBob's Avatar
Drives: '16 M4 Sapphire Black metallic
I just checked the oil level on our 2013 335 M Sport and it showed that it was down about 20 to 25% according to the iDrive reading on the display. Prior to that it was at 100% probably 500 miles ago. From the above posts, I guess that it is normal to for the N55 to use some oil. Will check with the our dealer to see what they say. BTW, our 2001 330ci used about a quart every 5-6K miles.
335i M Sport to M4
      04-21-2013, 03:52 PM   #35
Seagull
Seagull's Avatar
289
Drives: F87 M2, E84 X1
I just added 1 quart after 6000km.... I'm not worried.
All my other ones did the same over break in. Hopefully after this initial one, I would think about 1 quart a year is about right ( 20,000km or so ). At that rate, it will be solid until 100k km and then start to consume some more.
At least that's my experience.
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT
      04-23-2013, 12:17 PM   #36
BoneMan_E60
BoneMan_E60's Avatar
Drives: X3 M40i
I had a4 2.0t that drank 1 quart of oil every 3k miles. On the Audi forums, they say unless it is 1 qt every 750-1000 miles, it is considered normal. I said BS and traded it for 535. I have had my CPO 1 year and have added 1 quart of oil over 12k miles. I noticed my oil level dropped after I was out doing some "spirited" driving with friends. On my normal commute and occasional full throttle run, it does not seem to consume. I would be interested to know how hard people push their cars. I suspect those with high consumption do more "spirited driving"? Just my thoughts.
f30post
