BMW X3 Forum
BMW X3 Forum
      03-24-2024, 01:50 PM   #1
04detroitls
04detroitls's Avatar
61
Drives: 21 x3m
  [0.00]
2024 BMW X3MC  [0.00]
2021 BMW X3M  [0.00]
JB4 f97/98 Install guide?
Is there a good write up or YT on this, the only YT video i found on a f97 wasn't that great. Just need to know the location of the plugs I need to connect w the JB4
      03-25-2024, 07:27 AM   #2
mikestpierre
36
Drives: F98 - X4M Competition
Kies has a decent video for installing a Dahler module on an S58. The video is for an M3, but connections are the same for the JB4.
That video along with the JB4 instructions should be all you need.
That, and some time and patience to get to the charge pipe sensor.
      03-27-2024, 05:59 AM   #3
04detroitls
61
Drives: 21 x3m
  [0.00]
2021 BMW X3M  [0.00]
found this one
any tips on getting that charge pipe sensor?
      03-27-2024, 08:15 AM   #4
mikestpierre
36
I drove the front end on ramps, removed the bottom engine cover (just a bunch of torx), fed the wire from the top, then stuck my hand up to hook it up.
I am downplaying how difficult it was, my hands were cut up and I had to get into the right position to do it. Hand kept cramping up, but it was December, so that’s my fault. Took around 30 minutes.
The popular alternative is popping the rivets in the wheel well to partially remove the liner and reach in from the side. If you have the rivets and rivet tool, it might take less time.
If you plan on replacing the reflectors with paint matched ones, you can do them both at the same time, as the reflectors require removing part of the wheel well liner.
      03-28-2024, 02:13 PM   #5
mills84
23
Drives: 2021 X3MC TR/AG
https://www.jb4tuned.com/instruction...58_INSTALL.pdf
      03-28-2024, 08:58 PM   #6
M4Lou
414
Drives: 21'-x3m40i 23'-m4c 24'-x3mc
Originally Posted by mills84 View Post
The TMAP is the hard one. The JB4 instructions covers it well. You can watch this RChip video - but do not take all the crap off from the bottom to get to the TMAP sensor. That is a waste of time. I did it.
Like the JB4 instructions say, pull off the drivers side wheel and turn steering to the right. There is a panel that allows access. It is like 8-10 or so 8mm trim screws. Then look forward and up and you'll see - just like the JB4 pic.
xbimmers
