12-02-2023, 11:54 PM | #1 |
349
Rep 244
Drives: 2022 BMW X3MC
To start off I have a 22 Brooklyn Grey Comp. I’ve been looking at carbon parts since purchasing the car about a year ago.
With recent black Friday deals I finally pulled the trigger on a few parts. RW Carbon front lip RW Carbon rear diffuser RW Carbon side skirts RW Carbon full replacement grill Autotecknic Carbon mirror covers eBay Carbon side vents (runnstar) eBay Carbon center console (runnstar) eBay Carbon steering wheel trim (runnstar) eBay Carbon radio bezel trim (runnstar) Amazon Carbon magnetic paddles Aliexpress Carbon seat back covers JBSpeed Carbon Roundels Automotive Passion Carbon front mud flaps So far I have received the RW front lip and diffuser. They had fast shipping and they seem to be good quality. Today I installed the rear diffuser. Pretty simple install. Only 4 screws to remove the oem diffuser. Figuring out how to get the plastics clips to release was probably the hardest part. Just took my time and looked at them carefully to figure out what needed to be compressed to remove. Install of the diffuser was straight forward as well. It’s a very tight fit…I started with one side and just carefully worked my way to the other. Fit the 4 screws back and admired the new look. One bonus after install I noticed the rear “kick motion” power liftgate still works. I thought I had read previously that rear diffusers caused a loss of this functionality so this was a nice surprise. If I have to be picky about anything with the diffuser the fit around the exhaust area is not 100% perfect. There is a little space where it just doesn’t quite fit snuggly. But overall fit, finish and quality is great. This isn’t major and you wouldn’t notice. I’ll be installing the front lip tomorrow and will add to this thread as I receive the other items as well. Eventually, I may add side skirts. I’ve also been thinking about having someone wrap my roof in Carbon as well. We’ll see how far this goes 😂 Here is a video showing the kick liftgate still working. https://youtu.be/VMNu5CZSQFY?si=ede0aB4AvF3X8wAV |
12-03-2023, 04:55 PM | #3 |
349
Rep 244
12-03-2023, 05:10 PM | #4 |
349
Rep 244
Was able to get the lip installed today. It took a bit longer as I did it alone. Did not use a lift nor did I jack up the car. Took my time to get it aligned and use painters tape as a guide to get it where i wanted.
The lip came with pre drilled holes which I had assumed a couple would have been for the the stock bolts but that was not the case. All pre drilled holes took self tapping screws which they provided. Instead of a power drill I used a small hand drill bit that I had which worked really well. After mocking it up I used a few strips of 3m tape on the areas where the lip would make contact with the bumper. This also helped to get it aligned and hold it up enough to drill and use the provided screws. Overall, another quality part and I’m happy with the outcome! |
12-03-2023, 06:43 PM | #5 | |
Need mo $$s
833
Rep 885
2020 TRM-BLACK X4///M Competition
2020 Porsche Macan 1995 Dodge Stealth TwinTurbo Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport |
ttx3m349.00 |
12-03-2023, 09:05 PM | #7 | |
227
Rep 155
2022 X3MC MBB (mine), 2021 X7 40i BSM (wife's), 2014 640i BSM (sold)
Build page --> https://x3.xbimmers.com/forums/showthread.php?t=1849502 |
12-03-2023, 09:27 PM | #8 |
349
Rep 244
12-04-2023, 01:45 AM | #9 | |
1074
Rep 902
Drives: 2022 X3 M40i LCI
Carbon front kidney grill surround is my next fix. I’ve gone carbon interior first as I can see it more.
2022 X3 M40i LCI. Brooklyn Grey Metallic. Driving Assistant Professional. Black with Blue Stitching Vernasca Leather M Seats. Comfort Pack. Pano Roof. Carbon Fibre Interior Trim, inc. seat backs. 21” 718 Alloys. Blue M Sport Callipers. Anniversary badges. Floating centre caps. Performance flow through rear spoiler. Front splitter. Carbon mirror caps. OEM carbon steering wheel trim. G80 carbon paddle shifters.
12-04-2023, 06:56 AM | #10 |
349
Rep 244
When you get the grill surround let me know how the install was. I would like the front vents but I’ve read install on those is kind of a pain and after installing the front lip that would now have to come off to access the pins that hold them on the bottom. So probably will not do the front vents at this point!
12-04-2023, 09:02 AM | #11 | |
3072
Rep 4,393
Drives: 2022 F97 X3M Comp LCI
in hindsight, the side front vents is easy too. simply remove the two bottom plastic pins and pull the vents upward. when you have enough clearance, remove the PDC sensor. pull out and they’ll detach quickly. grab the replacement piece and start from the top. install half way, then go through the front fender wheel lining to install the PDC sensor from the rear. once clipped, finish pushing the side vent all the way down. install the two bottom pins and youre done. but yeah, shouldve done that first before the front lip.
BMW MY22 F97 X3MC LCI - CURRENT BUILD THREAD| Instagram: @danniexi
BMW MY16 F80 M3 - GONE BMW MY08 E92 335XI - GONE BMW MY06 E46 325XI - GONE |
12-04-2023, 02:25 PM | #12 | |
Need mo $$s
833
Rep 885
Just my $.02
12-04-2023, 07:46 PM | #13 | |
349
Rep 244
I like this as well…the side fender vents I went with the “boomerang” piece only. Liked that look better than the full vent. |
95wildtt832.50 |
12-08-2023, 09:39 PM | #15 |
349
Rep 244
Autotecknic mirror caps and side vent trim arrived this week. I cleaned these up with Graphene tonight and will get them installed tomorrow after I give the car a bath!
12-09-2023, 06:57 PM | #16 |
349
Rep 244
Cleaned up the car today and attempted install of the Autotecknic mirror caps and side vent trim.
Mirror caps 👍 Side vent trim (boomerangs) 👎 I would definitely NOT recommend the side vent trim. It’s a stick on so it just covers the existing trim. It did not fit well and when test fitting before sticking. They came ready with 3m tape. I tried anyways and it would not stick and could not get it to sit flush. I ended up scratching up my oem boomerang trim piece in the process. I though maybe it was the 3m tape that came pre installed so I removed it and added my own (same that’s I just used last weekend on my front lip). Still a no go. I think the biggest issue is that it doesn’t sit flush so you can’t get it to stick. Didn’t even attempt the other side. Going to contact Autotecknic about this. Autotecknic mirror caps fit great no problems there. Five minutes to install those. By the time I got done messing with the boomerang it was dark so I’ll have to get a photo later. Anyways, would not recommend trying the boomerang overlays. Not worth it imo. |
12-10-2023, 06:54 AM | #17 | |
1074
Rep 902
https://a.aliexpress.com/_mtGyp2u I went without X3M badge as mine is not an X3M Don’t forget Autotecknic is just the same Chinese stuff with a mark up and quicker delivery times so the fitment will still be hit and miss.
ttx3m349.00 |
12-10-2023, 03:30 PM | #18 |
349
Rep 244
Fitment with the ones I received was certainly a miss. The ones you have look pretty good!
My only concern is swapping the badge. I want to keep the badge vs having them blank. New ones might be the way to go…I think I’ve read they are not the easiest to remove and I want to keep all my parts for return to stock. Does anyone know where to buy the side vent x3m badges? |
12-10-2023, 04:52 PM | #19 |
349
Rep 244
Looks like they may not sell the badge separate. Instead have to buy the whole trim piece.
12-11-2023, 02:44 AM | #20 |
1074
Rep 902
I chose to not have a badge. The ones I ordered could have come with a badge. It isn’t shown in the sellers pictures for copyright reasons. Privately message the seller and he should send you pictures.
12-20-2023, 03:32 PM | #22 | |
36
Rep 17
