02-12-2019, 06:55 PM | #67 |
4975
Rep 2,268
4600lbs? LOL.
A Macan is 400lbs lighter.
don't read this. too late...
///M TOWN16568.00 M3 Adjuster7905.50 |
02-12-2019, 06:56 PM | #69 |
BMW Fanatic
374
Rep 1,413
Drives: 2020 X3 M
Is this going to be the specifications for the new M3 and M4?
SteveSpy
Current Ride: 2020 X3 M |
02-12-2019, 06:59 PM | #70 |
393
Rep 487
F97/F98 need to trim some weight! No CF roof, no CF drive shaft in Competition Pack? CF strut bar should have been extended and replace those two metal one on the two side. Would expect 503hp AWD to run at least faster than 3.5s 0-60 from official number. The front/rear tire would have been nicer in 265 / 295 setup. BMW should have opt for flared F/R fenders on F97/F98.
Patiently waiting for G80/G82 M3/M4 specs to come ... |
02-12-2019, 07:03 PM | #73 |
Administrator
40906
Rep 21,240
Videos:
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
Ibiza3611.50 chicagofan0019147.50 |
02-12-2019, 07:11 PM | #74 |
1999
Rep 2,499
I'm just guessing, but I believe it's because of the electronic parking brake. I'm betting that BMW has a combination floating caliper that functions as the parking brake as well. Honestly, this probably has a net positive gain in performance due to the lower unsprung mass of the caliper as well as not requiring the drum parking brake. Fixed caliper brakes are heavier and provide very little benefit on a road car like this in the rear. The extent of "performance" driving an X3 M will undergo in its life are stop light rag races and excessive speed while weaving in and out of traffic on the freeway. These are not really activities where a fade-free brake system is needed.
02-12-2019, 07:12 PM | #75 |
363
Rep 781
Drives: 2013 328i E92 LMB
Just watched the Facebook video for these. Apparently they only have 4WD and 4WD Sport, no 2WD. Will be interesting to see what that means but it's a little bit disappointing.
BMW CCA Member# 481791 Current: 2013 E92 328i LMB/Saddle Brown (1 of 21 for E92 LCI in that combo), 2018 F31 330xi AW/Saddle Brown Sold: 2011 1M BS/Black, 2008 E90 328xi AW/Beige, 2001 E46 330xi SG/Black |
02-12-2019, 07:18 PM | #78 |
BMW Client Advisor
3458
Rep 2,504
Drives: 2020 M340i
Sign me up!!
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. |
02-12-2019, 07:19 PM | #79 | |
1910
Rep 5,105
Nice vehicle to be sure...but near $100kCAD with tax...crazy. IMO of course.
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
02-12-2019, 07:20 PM | #80 |
56
Rep 54
Drives: 2009 328i xDrive
Toronto Red looks sharp!
02-12-2019, 07:33 PM | #83 | |
418
Rep 884
There is no deformity, as you say. When the TC is slipping (is not locked) the limiting factor is heat build up. Programming of the TC stall speed is used to control heat build up and driveability. What you're referring to is a ballooning effect from centrifugal forces within the TC at very high rpms. I doubt a 7600 rpm is cause for excessive ballooning. The VQ37HR in Nissan/Infiniti applications revs to 7600 with a standard TC equipped 7 speed auto. BMW's turbocharged inline 6s are all about low-end grunt and rapid spool times. The emphasis, good or bad, has moved away from high rpm excitement to savage low end thrust......really has nothing to do with rpm limitation on the 8HP series ZF transmissions. |
pcmike144.00 |
02-12-2019, 07:37 PM | #85 | ||
3612
Rep 2,858
Are ventilated front seats available with the M sport seats? EDIT: updated M sport seat in Sakhir displays ventsZ
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD |
02-12-2019, 07:40 PM | #86 |
2191
Rep 2,557
It's probably worth noting that "curb weight" includes commonly equip options, looking at OP there are going to be a lot of features standard, and the exec pack probably will be high take rate so curb weight is gonna be pretty much as heavy as it will get
02-12-2019, 07:41 PM | #87 | |
633
Rep 568
I really want one of these but I think I'll hold on to the m40i til the x6m comes out. I need a v8 in my life haha
18 X3 M40i/ Dark Graphite/ Cognac/ MP ECU Stage 2.5
kozzi927.00 |
02-12-2019, 07:41 PM | #88 |
3612
Rep 2,858
Probably too low volume to justify the additional costs when compared to the M3/M4 which is higher volume for the M///arketing.
