04-12-2024, 06:00 PM | #1 |
Rep 3
Drives: Alpina B7
I don’t know how I went this long without noticing but the front passenger wheel is different than the rest. They’re both classic 20spoked so that’s my excuse as to not seeing it. Does anyone know the correct part number for the wheel or any sites with OE/near OE replacements (top is the odd one out)
04-12-2024, 07:48 PM | #2 |
588
Rep 834
https://www.realoem.com/bmw/enUS/sho...diagId=36_1486
...and would look for Used ones from eBay.. ..regardless any Alpina wheel is going to be overpriced. Your top picture looks to be like the pre-LCI F01/F02 Alpina style wheel (Front: 36107980131, Rear: 36107980132), while the bottom picture is the LCI F01/F02 Alpina style wheel with their parts numbers provided at the beginning of my post. Last edited by M_Bimmer; 04-12-2024 at 08:06 PM.. |
04-13-2024, 10:33 AM | #3 |
4486
Rep 7,529
You should also be able to verify the wheel’s oe part number. Since the wheels have a hubcap…the part number may be located around the hub once you remove the hub cap. Depending on the amount of space…if limited you may only see the last 7 digits of the 11 digit part number. Once you have the correct part number you need, simply google BMW xx xx x xxx xxx to find vendors that have that wheel up for sale on the internet.
If the wheel’s specs aren’t located around the hub…then look for it on the back side of the wheel where the specs should be engraved (or molded if wheel is cast) into the rear spokes. Good luck finding the correct wheel.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-13-2024 at 10:40 AM.. |
