02-15-2020, 04:29 AM | #1 |
216
Rep 174
What ETs will work with the G20
I am about to pull the trigger on a set with the following specs
8.5"et32 front with 9.5"et40 19", the wheels are Ispiri FFR1 in matte satin bronze I have the M-sport package with the adaptive m-suspension. Will these specs work? ET32 on the fronts and ET40 on the rears are to conservative? Thanks in advance.
Sunset orange 330e M-Sport
YT:http://www.youtube.com/c/Mazzman IG: https://www.instagram.com/m4zzman/ Last edited by Mazman; 02-15-2020 at 04:44 AM.. |
02-15-2020, 09:45 AM | #2 |
160
Rep 170
I can't remember my exact front specs but I Believe we're doing around 12mm more poke then stock with an 8.5.
Rear I'm doing 10.5 with a plus 50. I'll have 255/30/20 and 295/25/20 |
02-17-2020, 01:22 AM | #3 |
216
Rep 174
Thanks for the input
What ET are you running on the fronts? So with 1" wider wheel and ET50 how do reckon 9.5" with 40 would look? Are you sitting flush with 10.5/50?
YT:http://www.youtube.com/c/Mazzman IG: https://www.instagram.com/m4zzman/ |
02-17-2020, 10:14 AM | #4 | |
160
Rep 170
I don't have my specs written down, shop ordering my wheels does. What I'd suggest for you is look up your oem specs of the wheels, and then punch them in on will they fit, or some other fitment calculator, and then look at the comparison to give you an idea. I can tell you mine will be fairly aggressive, not to everyone's preference but I like pushing the limits to what will fit especially when lowered, But my wheel itself will pass the top edge of the fender around 1-2mm at stock height/alignment, but I will have a conservative stretch. So all rubber will be within the wheel well. |
03-19-2020, 08:51 PM | #5 | |
3552
Rep 2,374
Are you concerned with the very low profile? |
03-19-2020, 10:57 PM | #6 | ||
160
Rep 170
If you have lots of potholes and run cheap quality wheels you may be more prone to cracked or bent wheels, or bulging tires. But worth the risk IMO. 19s just look so small everyone thinks it's on 18s. My only advice is stay as close to oem diameter as possible for Speedo accuracy, and don't vary front ti back diameters more than the allowable 1% I Believe it is |
03-20-2020, 02:09 PM | #7 | |
3552
Rep 2,374
Preciseyyc160.00 |
03-20-2020, 02:16 PM | #8 | ||
160
Rep 170
Hopefully not too much if any delays with them with this whole virus thing as they're being built in Japan and then need to be shipped over, ETA at time of ordering was late April or sometime in May, so far no word of delays, hopefully it stays that way. |
