BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > what modification next?
ARMA SPEED
      11-26-2016, 08:11 PM   #1
Kwongyy
Drives: MG 3 SERIES
Hi guys. So my current exhaust modification is an MPE (backbox only)
Personally i didnt notice a big difference from standard. Ive seen all these 140i have loud burble and pops with just MPE.
So I want something that will give me a deeper and throatier sound and also the burbles when i rev.
I dont want to have to remap it because of what i want. Whats are the options for me?
      11-26-2016, 08:12 PM   #2
mbanks21
mbanks21's Avatar
1276
Drives: 2015 335i MSport
Downpipe or res delete
2015 335i Msport/6 JB4/EWG/E30/VRSF DP/ER CP/ VRSF Race Exhaust/ Injen Intake/Verde Axis 19x8.5/9.5 245/35/275/30 Conti Extreme CS/ H&R Sports / Motorsport Hardware Stud Conversion
      11-27-2016, 07:29 PM   #3
Kwongyy
Drives: MG 3 SERIES
is res delete cutting out the silencer from my current OEM pipe?
      11-27-2016, 07:41 PM   #4
mbanks21
mbanks21's Avatar
1276
Yep
      11-28-2016, 06:58 AM   #5
Kwongyy
Drives: MG 3 SERIES
Does any one know where can I find midpipes? Don't want to cut into the OEM pipe.
I know local custom specialists but seeing if there are any places that sell them already ?
      11-28-2016, 09:52 AM   #6
daveyfx
37
Drives: 2016 340i xDrive
http://www.awe-tuning.com/awe-bmw-f3...i-440i-exhaust
(performance midpipe)
https://www.remus.eu/front-silencer-20830.html
http://www.dinancars.com/product/d66...ries&mid=1237/
There may be others, but I'm not aware.
      11-28-2016, 11:37 AM   #7
Mike@N54Tuning.com
BimmerPost Supporting Vendor
4927
Drives: 2007 335i, 2015 M3
+1
Downpipes will give you a nice deeper exhaust tone!
Mike
      11-28-2016, 12:43 PM   #8
BASELINE
136
Drives: A few...
+1
Mike
+2
I'd go catless DP. Add a bit of sound with the functionality of more power and better spool. Then if you want more noise you could always start removing the resonators....one at a time to make sure you don't overshoot your desired Db level.
      11-28-2016, 07:26 PM   #9
mike@x-ph.com
mike@x-ph.com's Avatar
24463
Downpipe
Check the vendor section for Cyber Monday deals
https://x-ph.com/sale/
Phone number 702-494-9435
      11-28-2016, 11:16 PM   #10
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
3070
Drives: 340 6MT, 50e, others
MPPSK will crack and burble on b58
cmplaya211.50
      11-30-2016, 01:31 AM   #11
E90ROXS
E90ROXS's Avatar
225
Drives: E90
But it will also crack your wallet
mbanks211275.50
      11-30-2016, 10:05 AM   #12
NorCalTR707
Drives: 2016 340i
2016 340i + JB4
I just got an Evolution Racewerks Downpipe, and I'm curious; won't I get a catalytic efficiency fault from the post cat sensor after install and driving?
      11-30-2016, 01:10 PM   #13
mike@x-ph.com
24463
Originally Posted by NorCalTR707 View Post
2016 340i + JB4
No, JB4 will hide the code
Post pics of the downpipe
      11-30-2016, 05:43 PM   #14
NorCalTR707
Drives: 2016 340i
Thanks,Will do Mike. About an hour ago I put 3.5 Gallons of E-85 in the tank, and filled the rest up with 91. Put the JB4 into Map 2 for the first time as I understood you could put it in Map 2 with E-85 for higher turbo boost. Right after leaving the gas station I got the drivetrain malfunction warning, and the acceleration was super sluggish... Turned car off, fired it back up, no more warning, so I put it back in Map 1 and it drove just fine. Can anyone explain why the 340i didn't seem to like Map 2?
      11-30-2016, 05:51 PM   #15
mike@x-ph.com
24463
You should not be using E85 with the B58 engine
      11-30-2016, 06:15 PM   #16
NorCalTR707
Drives: 2016 340i
Can you Elaborate?
      11-30-2016, 06:18 PM   #17
mike@x-ph.com
24463
Can you Elaborate?
Per terry
Hey guys,
Been plugging away on the B58 E85 tuning and have some information to share.
First the good news. With sufficient octane the turbo hardware has plenty of room for more power. I turned boost up and was able to get around 440whp out of the car 100% stock on E40 with a much too lean AFR. I suspect the factory turbo with just a high flow intake added will ultimately support around 460-475whp.
Now the bad news. It looks as if BMW has placed an IPW fuel limiter in to the DME firmware. This could be an attempt to hinder flash tuners or could simply be to avoid some sort of an injector or fuel system flow limit we don't know about yet. On previous models we've altered the DME's fuel pressure signal as a back door to to raise IPW. On this model when altering the fuel pressure the DME responds by lowering it's load target proportionally to keep IPW consistent.
We can work around it fairly easily with a CANbus JB4 by dynamically altering the load back to the DME to be within its new lower range and add dutycycle to bring boost up. While we get the boost curve we want the IPW is fixed so AFR leans out.
What this means is that pump gas JB4 tuning is no problem. Race gas only tuning may get a bit sketchy at higher power levels. Maybe around 400whp. And E85 tuning is for the most part a no-go at least for now.
We're likely going to have to turn to something external like meth or TBI to further extend the fueling range.
Work continues... The logs have been purposefully not posted as I've noticed some would-be competitors IP addresses reading these B58 JB4 threads.
      11-30-2016, 06:40 PM   #18
NorCalTR707
Drives: 2016 340i
I've read about S55 having similar issues, that were resolved by gapping the spark plugs, do you think that would benefit the situation with my B58?
      12-07-2016, 01:32 PM   #19
carguy19
carguy19's Avatar
107
Drives: 2021 M340
If you are referring to the fueling issue copied from Terry above. Gapping the plugs won't do anything to help fueling and injector pulse width.
      12-07-2016, 02:18 PM   #20
Mike@N54Tuning.com
4927
As above E85 not a great idea on these motors for now as there is a full limiter built into the logic.
Mike
      12-08-2016, 02:21 AM   #21
ErkanTR16
64-bit
ErkanTR16's Avatar
598
Drives: 2018 BMW 340i xDrive
Ain't that right.
Roki187126.00
