04-03-2019, 09:01 AM | #1 |
BimmerPost Supporting Vendor
4517
Rep 1,862
Drives: powered by bootmod3
*** bootmod3 for BMW B58 - Now Available ***
Featured on BIMMERPOST.com Our team has worked tirelessly on BMW B58 engine support adding support for all of bootmod3 features while programming the DME without removal from engine bay. Initial flash time that includes unlocking the DME is around 3 minutes and switching maps takes just 19 seconds using the standard ENET-OBD cable. Licenses can be purchased by clicking on the link provided below: https://www.protuningfreaks.com/coll...0i-m140i-m340i B58 FEATURES INCLUDED WITH PURCHASE TODAY - Exhaust Burble adjustment - Cold Start (cat heating) disable - Exhaust Flap adjustment - Speed Limiter (VMAX) Removal - Catalytic Monitors (CEL) on/off - End User Map configuration for all maps - Tuning Editor fur custom tuning - Datalogging hundreds of data channels available and many more to come Stage 1 91 octane: up to 18% HP / 26% TQ Stage 1 93 octane: up to 20% HP / 26% TQ Stage 2 91 octane: up to 24% HP / 32% TQ Stage 2 93 octane: up to 26% HP / 32% TQ Stage 2 AGG (Aggressive burble) versions of maps available E30 and Race gas maps are on the way! Current released OTS Maps make their peak power at just around 16-16.5psi so lots more to follow with higher octane OTS but also custom tuned maps by bootmod3 tuners. With some B58s and bootmod3 custom tunes pushing B58s past 700whp already it'll be really fun to see where the platform takes us!
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
04-03-2019, 09:09 AM | #2 |
Cheapskate
4464
Rep 4,995
Awesome. I purchased and can't wait to flash when I get home.
I'm still on the fence on picking the stage 1 flash or going catless and picking stage 2. Is it that noticeable of a difference from stage 1 with stock hardware? Mainly I'm eager to flash now and not sure I want to deal with the smell either. |
N26Ghost497.50 RedSectorA37.50 |
04-03-2019, 09:10 AM | #3 | |
726
Rep 364
04-03-2019, 09:12 AM | #5 |
604
Rep 631
Nice! Thank's y'all!
Since I'm new to the flashing world (sorry if this has been answered before), for those of us with MPPSK, when we do the unlock/flash and we need to flash back to stock for dealer visits, what happens? Will it flash back to the MPPSK tune or back to the original stock tune? Also, any negatives to running Stage 2 with the stock cat and MPPSK exhaust? |
04-03-2019, 09:13 AM | #6 | |
726
Rep 364
For stage 2 we recommend having a highflow downpipe. You can flash it and provide logs on a ticket, we can review it for you |
04-03-2019, 09:16 AM | #7 | |
604
Rep 631
Halim@HCP725.50 |
04-03-2019, 09:20 AM | #8 |
Cheapskate
4464
Rep 4,995
Thanks. Also curious if any 6MT beta testers had to upgrade clutches, or did the stock clutch hold the power fine?
04-03-2019, 09:23 AM | #9 |
IG @bmwF9xG80
3817
Rep 7,595
Drives: G80 M3, X4M, G07 X7m50
No need to upgrade clutches, BM3 OTS doesn't push your car over the limit
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
kern4174464.00 BuffaloSoldierH3.00 |
04-03-2019, 09:56 AM | #11 | |
70
Rep 93
Not recommended to go Max Burbles as well if you care about your turbos, but if you don't go ahead and the melt cat away |
04-03-2019, 09:59 AM | #13 |
Rep 6
I know that i cant use max burbles Im asking which settings i can use to max it out for stock system
04-03-2019, 10:05 AM | #14 |
263
Rep 954
@proTUNING Freaks if someone is coming from another ECU/TCU tune, what would they need to do in order to load BM3 tunes?
If a DME is previously "unlocked", what's the protocol? |
bmc34016.50 InstigatorX58.00 |
04-03-2019, 10:14 AM | #15 |
135
Rep 233
Is the DME Unlock + Initial flash just as fast using the Wifi Agent? Or would you recommend using the standard ENet Cable and a computer for the initial unlock?
04-03-2019, 10:23 AM | #18 |
89
Rep 242
proTUNING Freaks
Will this change the sport display HP /TQ values? are your dyno graphs displayed WHP or @ flywheel? Can you clarify the peak boost pressure between stages? 16.5 max stage 2 seems low (a good thing!!!!)
M240i xdrive - K&N Drop in, MPE
12.3 @ 108 Stock |
Powaup1259.00 |
04-03-2019, 10:39 AM | #19 |
205
Rep 495
Drives: BMW 330e F30 M-sport
Question to understand the different tune options:
Is the main difference between stage1 and 2 maps the boost? And is the main difference between 91 and 93 octane maps the timing?
Thorbjorn
16 BMW F30 330e M-sport Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs |
04-03-2019, 11:09 AM | #21 | |
726
Rep 364
Boost on stage 1 and 2 is different, together with a different boost control to address the backpressure difference. 91 and 93 octane maps have a difference in ignition advance. |
04-03-2019, 11:14 AM | #22 | |
205
Rep 495
I realize this might be slightly off topic for this thread(?), will there be a separate thread for B48 perhaps? Anyway: I assume this will be roughly similar on B48. Will downpipe be the only recommended mod for Stage2 on B48 as well? I'm running a 200cpi high flow cat, will that be fine for the Stage 2 map?
Thorbjorn
Tags |
bm3, bootmod3 |
