BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
Mporium BMW
      04-26-2010, 05:02 PM   #23
STALKER
169
Drives: 997.2 GT3, Golf R
Anyone else want to share their specs?
      05-06-2010, 07:10 PM   #24
Jaypod
Jaypod's Avatar
No_Country
125
Drives: Frozen M3, AM V8V, 991 GT3
Just had my Motons installed today:
Front
Camber Left: -2 3/32 Right: -2 5/16
Toe Left: 0 Right: 0
Rear
Camber Left: -1 1/2 Right: -1 1/2
Toe Left: 1/32 Right: 1/32
Looking forward to getting it to the track on Sunday!
      05-06-2010, 07:23 PM   #25
STALKER
169
Front
Rear
Congrats!!!
How much did they lower the car overall?
You got some very decent camber out of the front without plates. Did you pull the pins?
      05-06-2010, 07:24 PM   #26
OMID INC
OMID INC's Avatar
92
Drives: E70 X5
i dont think you can adjust caster as easily as toe and camber
      05-06-2010, 07:34 PM   #27
Jaypod
Jaypod's Avatar
No_Country
125
Originally Posted by STALKER View Post
Congrats!!!
Thanks - yes they pulled the pins to max out camber on the front without plates. Very happy with the result. Feels very good. Will have to double check the actual drop, but I asked them for between .5" to .75".
AP Racing BBK was also installed today as well!
      05-06-2010, 07:36 PM   #28
STALKER
169
woohoo!!!!
Congrats, your car has so many goodies now.
      07-08-2010, 09:53 PM   #29
STALKER
169
I don't think you can adjust the caster, can you?
      07-09-2010, 07:00 AM   #30
dawgdog
150
Drives: 2015 M3, 2016 GT3
Ground Control Suspension
camber front left -2.69 rt - 2.68
camber reasr left -1.97 rt - 1.98
toe front left 0.01 in. rt 0.01 in.
toe rear left 0.05 in. rt 0.05 in.
2015 f80 M3, 2016 GT3
      07-09-2010, 10:01 AM   #31
V1.47fan
1979
Drives: TheArtist formerly known as M3
Tires:AD08's
F:255/30-19 stock 19's 15mm spacers
R: 275/30-19 stock 19's
Front:
Left Camber: -2.0 drilled out slots
Right Camber: -1.9 drilled out slots
zero toe
Rear:
Left Camber: -1.7
Right Camber: -1.6
Toe In: .15
NO RUBBING!!
      07-09-2010, 12:25 PM   #32
808MGuy
808MGuy's Avatar
221
Drives: 2009 E90 M3
It seems like everyone posting their alignment specs are on coilovers and dropped well over 1". Anybody have specs after just a spring install?
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
      07-09-2010, 01:28 PM   #33
signes
signes's Avatar
201
Drives: 991 GT3 RS
For stock suspension (pins pulled), I am at 1.2-1.3 front and 2.0 rear. Need to dial back the rear a bit I think, but disappointed I didn't get more up front.
GT3 RS | Desperately seeking the next great M car...
      07-09-2010, 02:13 PM   #34
LiM3y
LiM3y's Avatar
70
Drives: 2008 E90 M3
From a dealer
Hope this helps. I had Eibach springs put in and they used standard specs
      07-09-2010, 04:08 PM   #35
808MGuy
808MGuy's Avatar
221
Drives: 2009 E90 M3
So did they get it back to spec after the Eibach install? Those sheets only show the factory spec but it doesn't show what your actual numbers were.
      07-09-2010, 06:40 PM   #36
LiM3y
LiM3y's Avatar
70
Drives: 2008 E90 M3
These sheets are from when I knocked the alignment out on the stock set up. The original dealer aligned me to 335 specs, which are different. Another dealer faxed me the specs shown on this sheet. When I had the Eibachs added, the new specs lined up with these specs limits - they didn't even comment that the car had been dropped a little. The car has been aligned twice since the install - once immediately afterwards, and again after I hit a kerb hard during a track day and knocked the alignment out slightly enough to be irritating. I don't have the before/after spec sheet any more
      07-11-2010, 01:46 PM   #37
WCH
WCH's Avatar
348
Drives: '20 M8C convertible
E92 ZCP specs
Anyone know if the 2011 ZCP has different alignment specs?
      07-14-2010, 07:21 PM   #38
JH M3
JH M3's Avatar
117
Drives: 2017 F80 M3 ZCP Azurite Black
Just had my alignment done today. I have Eibach springs and stock 19" wheels.
      07-15-2010, 01:27 AM   #39
mastek
e36s54, e70x5d
mastek's Avatar
151
Drives: slow
-3.5 camber front
-2.0 camber rear
Handles very well at the track (for a heavy car)
and destroys street tires up front too
      07-15-2010, 07:18 PM   #40
Bubbles
Bubbles's Avatar
Cayman Islands
2753
Drives: Green Bastard
Just got my ZCP aligned for track work.
On stock ZCP suspension I got:
Camber
-1.7 Front Left/ -1.6 Front Right
-1.9 Left Rear/ -1.7 Right Rear
Front Total Toe
.12
Rear Total Toe
.11
Running ARC 18s 275/35/18 all around.
      07-15-2010, 09:33 PM   #41
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
After my Eibach install here is what I aligned the car to:
0 toe front, with a touch of toe in for the rear (1/32 in each side)
-1.4 degrees of camber up front and -1.7 degrees in the rear.
This is at the ride height almost exactly what Eibach quotes 0.8" lower in the front and 0.6" lower in the. I also have 15mm/12mm spacers.
      07-20-2010, 02:54 PM   #42
hammbone50
17
Drives: 2011 M3 Coupe
Where are you guys getting your alignments done? The dealership? If so what are they charging you?
      07-20-2010, 03:04 PM   #43
STALKER
169
Stay away from the dealer, they will charge you a lot and want to keep it at factory specs.
      07-20-2010, 03:10 PM   #44
hammbone50
17
Thanks with that being said is there anyone in the Delaware area that any of you guys have used and recommended. I could also use a shop recommendation for the spring install. Thanks!
m3post
