03-31-2024, 01:21 PM | #1 |
16
Rep 140
ABS Fault - Wheel speed sensor - Front left active fault (not reading)
Hello: An ABS fault appeared for the front left wheel sensor and as result I have replaced it with a new sensor. That didn't fix the issue, thus, I moved the sensor to the right side to see if fault code moves and it didn't. Then looking through my Schwaben datalogger for all 4 wheel speeds, I see all 3 reporting data while moving in straight line, expect for the front left as indicated by the fault code. However, If I turn or drive in a circular pattern then the faulty wheel speed does read. Any idea what may cause the speed sensor not read while driving in straight line?
Vehicle: 2008 E92 M3, 140k miles, DCT transmission Active fault codes: 5D91 - DSC: wheel-speed sensor plausibility, front left. 5D96/not present: DSC: wheel-speed sensor direction of rotation front-left 5D90/present: DSC: Wheel speed sensor power supply many thanks in advance |
03-31-2024, 01:52 PM | #2 | |
493
Rep 487
Drives: 2009 E93 M3 DCT
03-31-2024, 03:37 PM | #3 |
16
Rep 140
Yes, I have checked the wires & connection multiple times and everything seemed sound. The only thing I am suspecting at this point is the wheel hub, but I am not aware of how to check it. Any ideas before I attempt to purchase a new hub?
Thanks for the input |
04-21-2024, 06:59 PM | #6 |
16
Rep 140
Another update:
I pulled the fender liner, and checked the connections and wires. No visible damage of any sort. Any other suggestions I can try? Thanks in advance |
