05-15-2020, 02:30 PM | #23 |
79
Rep 138
Personally, I think the MPF Carbon looks awesome...
J
330i M Sport Plus Previous- 435D M Sport Last edited by Phippsy81; 05-15-2020 at 02:39 PM.. |
Swagasaurus-R3X44.50 SiFi730.00 |
06-02-2020, 02:28 PM | #24 | |
45
Rep 59
What's your YT channel? |
Mazman215.50 |
06-03-2020, 01:27 AM | #25 |
216
Rep 174
Sunset orange 330e M-Sport
YT:http://www.youtube.com/c/Mazzman IG: https://www.instagram.com/m4zzman/ |
Swagasaurus-R3X44.50 Tanzanite330i0.00 |
05-31-2021, 07:21 AM | #27 |
Rep 2
Kies Spoiler sale
If anyones looking for a spoiler, I've just found this from Kies Motorsport and it looks pretty good but relatively expensive. Is this worth the price?
https://www.kiesmotorsports.com/coll...-trunk-spoiler |
05-31-2021, 03:27 PM | #28 |
1026
Rep 286
Drives: 2021 M340 RWD
I ended up ordering the new M3 spoiler and it looks awesome. The splitter came from CA after about 8 months. It is not OEM.
"Either get busy living, or get busy dying. That's GD right." - Red (Shawshank)
05-31-2021, 03:56 PM | #29 |
37
Rep 88
I ordered an M4 style one from Automodz (link below for the G22 but they have even more G20 options). When it arrives and I get it installed I will post pics.
https://automodz.ca/collections/rear...carbon-spoiler |
06-03-2021, 02:47 PM | #30 |
Rep 36
07-06-2021, 11:38 PM | #31 |
1026
Rep 286
I got it from Evan and his guys at BMWPARTSPROs
07-07-2021, 03:33 AM | #32 | |
Rep 16
07-07-2021, 12:33 PM | #33 |
351
Rep 429
Although its more than what people will probably want to spend, I installed the Autotecknic Dry Carbon Competition Plus spoiler. Quality and fitment is amazing and I love how it follows the natural lines of the car.
https://autotecknic.com/collections/...r-g20-3-series
2020 MG 330i xDrive M Sport
2023 AR M3 Competition M xDrive |
07-07-2021, 01:42 PM | #34 | |
3770
Rep 2,700
Thanks
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
08-12-2021, 11:45 AM | #35 |
47
Rep 44
Perhaps not the best first post, but - AA Concepts has an end of summer 10% discount code running now and has a few nice looking CF options - M3 CS rep, M3 CS with a higher kick up, M4 style, and an M3 "performance style" that looks closer to the M Performance spoiler.
I've gone back and forth on options for the last few weeks and finally pulled the trigger on their M3 CS replica - will post back once I have it installed. Should be very similar to Mazman and the dravit grey M340i that has pics floating around here. Anyway, hope that helps - seems hard to beat for ~$250 shipped. |
08-12-2021, 10:45 PM | #36 | ||
14
Rep 35
08-30-2021, 09:11 AM | #37 |
47
Rep 44
So finally installed my AA Concepts M3 CS rep carbon fiber lip.
FIT: The fitment is great. I'd say A-, if OEM is A to A+. Basically, almost OEM fit. FINISH: The CF weave is perfect throughout the lip itself, and the clear coat is well done without any orange peel. If I had a qualm, it's that the lip mold is a little wavy - when you view the top of the lip from the side of the car, you can see where it's not perfectly smooth across. For a <$300 lip, this is still much better than average. But beware, if you want perfect, then buy an OEM part. INSTALL: Relatively straightforward, albeit a bit nerve-racking. Process below: 1. Remove your existing lip by first lining the length of the trunk lid where it meets the rear side of the spoiler with painters tape. 2. Pry up the existing lip using a bondo spreader or nylon pry tool (I used the nylon pry tool that IND-distribution includes in their install kit for painted reflectors). 3. Don't worry about the tape residue, and don't try to scratch or rub it off with your hands. 4. Work the length of the lip and remove. 5. Apply 1/4" "3M Auto Exterior Attachment" tape to all edges of the AA Concepts spoiler. This is where 1/4" tape is handy since it bends to shape well. More common 1/2" tape is overkill and likely a PITA to apply to the part. 6. Remove tape residue using a 3M Stripe Off Wheel Adhesive Remover Eraser Wheel attached to a drill. This is the nerve-racking part - I'd never used one of these, and it seemed like this would abrade the paint. TRUST IT - it's f'n magic and I wouldn't even attempt this job in the future without this wheel. Within about 5 minutes using the wheel, all of the leftover adhesive was gone and the paint was perfect. I applied some bug and tar remover to a few straggling bits but otherwise all was well. 7. I removed all remaining waxes, sealants, whatever using a ceramic coat prep spray that removes wax, but an isopropyl alcohol wipe works equally well. Basically, you want the paint to "squeak" afterward. 8. Install the lip - remove the backing from the tape on any hard to reach spots, and get a bit of a start with the backing on the other spots. Very gently align the lip on the trunk, then remove backing and stick firm. 9. Admire your work, and apply sealant / wax. 10. Finished product below: |
calbearz2437.00 |
09-13-2021, 10:38 AM | #38 | |
Rep 11
09-13-2021, 05:10 PM | #39 |
37
Rep 88
Yes, but it took a little while, maybe a month or so though. I didnt receive any communications from them after ordering for the better part of that time and when I eventually emailed they sent me the tracking info. At that stage I got it pretty quickly, but I think it may already have been in transit.
09-14-2021, 09:07 AM | #40 |
1777
Rep 597
We've got a number of options for the G20 and G22 on our website. Loads in stock too!
https://autoid.co/search?type=articl...t&q=G20*+G22** |
09-15-2021, 05:38 PM | #41 |
Rep 2
Hello guys
Do whatever you want, but dont buy this one. There is no way for it to fit on your trunk due to shape and material. It pushes itself back. https://www.ebay.com/itm/For-2019-20...-127632-2357-0 |
09-18-2021, 07:01 PM | #42 |
Drive it like you stole it
66
Rep 279
Drives: 2020 Sapphire Black M340i
I got mine from kiesmotorsports and I couldn't be happier.
09-23-2021, 12:56 PM | #43 | |
Rep 36
09-30-2021, 10:47 AM | #44 | |
Rep 47
how was your experience with automodz? looking to place order but my gut holding me back any contact number or person specifically ? thanks. |
