TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Engine / Exhaust / Drivetrain Modification
      10-28-2019, 11:47 AM   #89
frankenm
frankenm's Avatar
96
Drives: 12' X5M, 99 M3
Pics
This setup is fucking great - still running stock tuning and trying to pass smog - Exhaust note is much better from about 3k+ with all stock cats+exhaust otherwise it isn’t noticeable but the improvement is really nice much better
Makes some really nice spool and blowoff sounds which is easily noticeable in the cabin above 3k .... will probably put the JB4 back on and do some experimenting the stock tune sucks.
2012 X5M - M5 S63TU Turbos/Manifolds, Custom Exhaust, Intake, JB4/BCM, OEM race stripes
1999 323
- M3 Clone - Hardtop - S50 Cams, S52, 3.23 LSD, Koni Sport, 18' E46 M3 Wheels
      10-30-2019, 05:04 AM   #90
Robbie1977
Robbie1977's Avatar
13
Drives: BMW x6 5.0
2010 X6  [10.00]
Originally Posted by frankenm View Post
Pics
Hi there, I was just wondering was there any reason why your primary o2 seniors are wired over the wrong way?
      10-30-2019, 01:36 PM   #91
frankenm
frankenm's Avatar
96
ECU detected they were getting swapped signals and set off a CEL a few times, would happen immediately on startup.
I swapped them and this has so far been running great without throwing malfunctions and CEL’s.
I daily this right now and no issues
1999 323
      10-31-2019, 03:27 AM   #92
Robbie1977
Robbie1977's Avatar
13
Drives: BMW x6 5.0
2010 X6  [10.00]
Interesting, I had a similar problem a while back, I just unplugged the primary O2 on one side. May try this and see what happens..
      10-31-2019, 01:20 PM   #93
frankenm
frankenm's Avatar
96
That sure is one way to fix the problem .....
I need to look at the manifold that came off the truck again - they are supposed to be the same but the ECU thinks differently.
1999 323
      11-09-2019, 10:45 PM   #94
Dawgz
2022 M4 Comp Xdrive
1023
Drives: 2022 M4 Comp Xdrive
Pics
How is it power wise?
      11-11-2019, 10:56 PM   #95
frankenm
frankenm's Avatar
96
Mostly stock honestly but the exhaust and turbo sounds now make it way better .... wife said it sounds like a spaceship.
The spooling and blowoff is really good .... will be way better once I get some good downpipes and modify my exhaust
I’ve thought about putting it on a dyno if I can find a decent one that is local
1999 323
      12-03-2019, 12:32 PM   #96
frankenm
frankenm's Avatar
96
Running this setup with about 2k miles on it have been able to keep the CEL off for the most part feels really strong ... the ECU has complained about the atmospheric blowoff sometimes but doesn’t seem to bother it much since it hasn’t triggered a CEL and only set a code off once for O2 after deacceleration.
Ive noticed the exhaust notes a lot more now and it sounds significantly better when just driving around in normal D mode ... has a much sportier sound a lot less chug if that makes sense.
Probably going to make some intakes to vent the blowoff valves back in but not to concerned at this point.
Very happy with this
1999 323
m5james432.00
      01-16-2020, 06:09 PM   #97
greekster
Drives: 2010 X5M
hello frank, been following your progress. I'm definitely interested in buying a kit from you if you think of making one. Any progress with this set up?
      01-17-2020, 02:50 PM   #98
frankenm
frankenm's Avatar
96
Sent you a PM
1999 323
      08-26-2020, 10:20 PM   #99
m5james
m5james's Avatar
432
Drives: '10 X5M Alpine White on Sakhir
I don't recall but are you flashed?
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      08-29-2020, 12:05 PM   #100
frankenm
frankenm's Avatar
96
stock tuning and jb4 only
1999 323
      09-01-2020, 08:35 PM   #101
m5james
m5james's Avatar
432
Mind sharing screenshots of your JB4 settings, including Map 6? I've messed with mine so much over the years I don't even know what stock settings were anymore. At this point I'm 90 FOL and max boost is 21psi from like 3500rpm onwards if I recall but things like the ratio settings and what not escape me. I just wanna copy and paste what works.
      09-20-2020, 10:46 PM   #102
frankenm
frankenm's Avatar
96
Next time I work on the truck I can ... not doing shit with it at the moment so could be while
1999 323
      09-23-2020, 07:48 PM   #103
Dawgz
2022 M4 Comp Xdrive
1023
I wonder how much you're putting down. The m5 turbo manifold alone should give you 10-15whp...the bigger turbos another 30
      10-27-2020, 10:02 PM   #104
Dawgz
2022 M4 Comp Xdrive
1023
Interesting to see the f10 turbos can push 30psi (24psi safely).
https://bmwtuning.co/bmw-s63tu-stock-turbo-max-boost/
      10-27-2020, 10:16 PM   #105
m5james
m5james's Avatar
432
The question is who makes a tune that'll reach those numbers. I'm running and Halim Cazimi/HCP tune (he's since moved onto newer platforms) and JB4, yet the car will go into limp mode doing anything over 21psi. I'd love to run more if there was a way around this.
      10-27-2020, 10:39 PM   #106
Dawgz
2022 M4 Comp Xdrive
1023
I've spoken to Frank Smith and he's willing to tune it for me once I've installed it.
      01-14-2022, 04:25 AM   #107
Dawgz
2022 M4 Comp Xdrive
1023
Alright so I got a set of these manifolds in. Not going to use the S63tu turbos though as I have upgraded stage 2 pureturbos.
Looking at the dimensions it seems all that's needed is to machine the lip on the manifold and the turbos should fit. I test fit my stock turbos in these and it seems that's all that's needed. The gasket that this manifold uses also fits the turbo side perfectly.
I approached RK autoworkes about the machining and they are already well aware of what to do to make this fit, as they told me they've done this before for others.
      06-19-2022, 11:58 PM   #108
TTV8M
TTV8M's Avatar
126
Drives: '23 AMG GLE53, '10 X6M
2023 AMG GLE53  [0.00]
2010 BMW X6M  [0.00]
2008 Mini Cooper S  [0.00]
Originally Posted by greddy91 View Post
Insert dick comment about using search, but really I'm just too lazy to also do that and link you.
'10 X6M
'08 Cooper S
      01-17-2023, 06:01 PM   #109
x800pro6
ZEE DEE
Australia
15
Drives: 335i
I'm doing the same project. I bought m5 manifold, also had a friend who worked for bmw. He had sitting in his shed basically bran new m5 turbo. That the dealer obviously replaced under warranty. So I bought them from him. No shaft play or signs of damaged oil seals.
      01-17-2023, 11:59 PM   #110
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
797
Drives: BMW M3 JB 04 Coupe
Awesome looking forward to updates.
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
xbimmers
