01-16-2019, 04:50 PM | #45 | |
96
Rep 397
I壇 love to get this done but have been waiting on a proper tune and at this point I知 planning to setup my own but that route with the proper software and shop space is still at least 6 months out for me at minimum so I知 just sitting here looking at this stuff waiting to be installed |
02-11-2019, 12:26 PM | #46 | |
13
Rep 35
02-11-2019, 12:41 PM | #47 |
13
Rep 35
So I am now almost finished installing the M5 intakes along with the Ramair dry filters. everything is bolt on except obviously I've removed the airbox filter from the original M5 parts.My plan is to fabricate a channel to direct the air around the radiator (similar to the M5) and onwards to a heat shield to avoid heat soak.
The map sensors are also plug and play between applications, I've fitted new gasket seals and bolts just about everywhere for best practise. I can confirm that X6M PCV lines reach the the M5 intakes on the turbos perfectly except the short one on the left side of the manifold cover. A little fabrication of a smaller vacuum line is required... (nothing major) see pictures below The biggest PITA at the minute is that I am trying to re-route all lines and wiring harnesses as much as possible to get a cleaner look ... Last edited by Robbie1977; 02-11-2019 at 12:53 PM.. |
m5james432.00 |
02-13-2019, 11:50 PM | #49 |
13
Rep 35
Yep sorry for the lack of pictures, I've moved most of the accessories to where the Cabin air filter is located behind the windshield panel. longer vacuum lines have been ran through and under the left fender. Since this picture I have moved some more stuff. My aim is to get the engine bay as clean as possible before I start to fabricate some custom pieces around the engine bay to hide empty voids and give the bay a more curved appearance, either welded aluminium panels painted along with the strut bars or maybe carbon fibre panels.
ATM we are making custom air channels which will channel air from around the radiator up to the Ramair filters which requires a custom heat shield trap / box. PITA as on both sides of the engines slightly different ares to build solutions around, one side houses the ABS box and the other side the coolant tank etc etc. am getting there though. pictures to follow soon. |
02-16-2019, 03:13 AM | #52 |
654
Rep 1,252
Nice, I had that same setup before I made some cold air ones, but heat soak was so bad. I ended up making my own...
https://www.xbimmers.com/forums/show....php?t=1508868 They would burn my hand before, so I added the gold tape, made a huge difference! |
02-16-2019, 09:11 PM | #53 | |
13
Rep 35
I致e found myself using the lower parts of the M5 air boxes with modification just to retain the tray and shape so that I can make a template from each side before I either cast them in carbon fibre or send them to my friend to make a copy from aluminium |
02-16-2019, 09:32 PM | #54 | ||
654
Rep 1,252
02-26-2019, 01:48 AM | #55 |
27
Rep 172
My setup
Still having o2 sensor issues Error code is 2C24 or P0040 O2 sensors swopped I have modified the stock airbox to act as a intake scoop. Works well IATs much lower Working on 100mm intakes in those last pics just waiting on 100mm air filters |
02-26-2019, 01:55 AM | #56 |
797
Rep 3,154
What are you using for those wraps on the coolant lines? Can i get a link please so i can order them for my car too. Thank you.
Current Mods:
2004 E46 M3cs JB/CSL 2010 E70 X5M AW/BLACK 2011 VW Golf R DSG White/Black IG: @060Motorsports |
02-26-2019, 02:36 AM | #57 |
27
Rep 172
02-26-2019, 02:53 AM | #58 |
797
Rep 3,154
Ah good to know. Guess i'll have to look for another solution.
Current Mods:
03-04-2019, 11:41 PM | #59 |
654
Rep 1,252
0-60Motorsports796.50 |
03-05-2019, 04:23 PM | #60 | |
797
Rep 3,154
Current Mods:
03-12-2019, 05:51 AM | #61 | |
13
Rep 35
Thanks |
03-12-2019, 07:21 PM | #62 | ||
654
Rep 1,252
03-16-2019, 03:55 PM | #63 |
13
Rep 35
03-16-2019, 08:14 PM | #64 |
654
Rep 1,252
X5M doesn't use MAF... it doesn't have MAF in the intake. I wasn't sure if you guys doing the swap of the turbo and intake manifold were doing that part too.
03-20-2019, 11:30 PM | #65 |
2022 M4 Comp Xdrive
1023
Rep 1,538
I think you guys are over exerting the need for cowals and getting colder air on to the filters. Although it would be nice to have but the slight difference in having them and not is not going to be a big issue as post turbo compression of the air will heat up the charged temps to a point where the colder inlet temp is negligible. Fear not as the post intercooler temps will be what we should be looking to drop. Usually it will be anywhere from 90 - 140 post intercooler temps.
03-24-2019, 08:08 PM | #66 |
2022 M4 Comp Xdrive
1023
Rep 1,538
Just did mine today, used 3.5" Airaid tubing, and K&N cone filters.
Hood closes with no issue. Now I just need to make low profile scoops so at speed, fresh air rushes to the filters. Will be logging intake temps as it is now and then see if the scoops make a drastic difference. Will try to match the outside air temperature for both readings. |
