10-08-2020, 09:16 PM | #67 |
Rep 23
I am freaking out right now, because all of the pieces are enroute to me next week, and Newtis is shut down!!! Just plunked down and pulled the trigger last week. Can you help me with the wiring plug numbers and colors between the ACC, LDM, and DSC units? I did not anticipate the shutdown, and didn't take any pictures of the schematics! I really hope I can wire this up blind with all your help without NewTis!
I remember that P_CAN is R and R/BU, but what pins are the S_CAN? Also couldn't remember the wire color and location for the wake pin. Fuse is F7 I believe, which piggy backs onto the RDC fuse. Where does the LDM mount? I remember seeing a picture at the driver side. Thanks!! |
10-12-2020, 11:09 AM | #69 |
Rep 23
Should I install the SZL as a whole unit, or only swapped out/in the cruise control stalk with the ribbon cable only, leaving the rest of the SZL intact? Trying to figure out what allows for best compatibility.
It sounds like you are all saying that the base SZL is the same, I am thinking of swapping just the stalk only. Last edited by asdf4fdsa; 10-12-2020 at 11:36 AM.. |
10-12-2020, 09:51 PM | #71 |
Rep 23
The SZL existing in the car has a 6-pin vertical connector (?) and 12-pin horizontal (X1880) connector. The new SZL has a 12-pin vertical (X10170) and 12-pin horizontal connector (X1880). The X10170 connects up to the clock spring, whereas the X1880 goes to the actual SZL. The extra pins on the clock spring (vertical connector) looks to be for heated steering and lane departure options, which my car does not have. I'll see about adding this later.
I could not find a reference to the 6pin vertical connector. The only difference I could find is there seems to be 2 sets of colors for wires to the steering wheel airbag. The pins map up directly, so should be a direct swap. I was lucky, the dismantler sent me the connector as well! |
10-15-2020, 05:02 PM | #72 |
Rep 23
I ended up installing the SZL as a whole, moved the pins from the 6-pin connector to the 12-pin connector (now I have an option to get a heated steering wheel!). LDM and ACC are also installed. Errors I am getting right now are:
6E92 - DSC Control unit coding: no repair measure available CE66 - Message error (wheel torque brake, 0xE1), receiver LDM, transmitter DSC The center dash also flashes between the clock and cruise control symbol repeatedly. I added $541 to the VO, but still no ACC yet. Looks like I need the ACC DSC installed. |
10-17-2020, 12:52 PM | #73 |
Rep 23
DSC installed. Errors were still present after adding VO for $5DF, and removing $541.
I ended up coding the VO with FA write, then coding into CAS and FRM with NCS Expert(expert mode). Then using ISTAp to program the DSC and ACC, which it picked up requiring programming and coding (with barely enough battery power to spare). Started the car, turned steering wheel and the traction control light turned off, no more error lights on the dash. The previously unused indicators on the dash can now be exercised! ACC with Stop & Go is now working!! Thanks to the detailed notes from robinasu on this thread! |
03-19-2021, 02:01 AM | #74 |
Rep 2
E71 ACC + lane departure warning
Hello dumitru.o
I'm interesting to upgrade my 2011 X6 E71 40d with ACC + lane departure warning. Any Suggestion? By the way, We are neighbors, I live in Bulgaria. Thanks |
06-03-2021, 07:22 AM | #75 | |
Rep 4
I setup completely the DSC with ACC, LDM, FRR, SZL and JBBE3. All modules can be see in INPA but ACC doesn't work. |
06-03-2021, 12:00 PM | #76 |
14
Rep 132
Hydro
That was before I swapped in a new hydro unit, I believe. My 2012 LCI X5 needed a DSC/Hydro unit that has "ACC" on the label. Those units have an additional sensor in the hydro block that the ACC needs. It was hard to find for me, but eventually one popped up and no problems after that.
06-03-2021, 10:14 PM | #77 | |
Rep 4
04-23-2022, 01:57 AM | #78 | |
coding BMW.....
490
Rep 890
i can help you with that, can get almost all the needed parts for you . please send me a PM with your email address and the VIN of the car thanks |
04-24-2022, 11:31 AM | #79 | ||
coding BMW.....
490
Rep 890
08-05-2022, 05:04 PM | #80 |
Rep 2
Glad I found this post!! I'm about embark on this for my e70 35d. I've read through this whole thread multiple times but still have some questions (still going to re-read it a few more times lol). I've been sitting on an ACC SZL for a while, and ready to make this happen. Bought it originally for my e92 to do ACC $541, but would much rather have ACC $5DF on my new to me x5
It's a non-LCI 2009 e70 35d US spec. VIN: 5UXFF03519LJ95391 build date: 2008/11 I followed along for the most part, but there is a lot of discovery/trial and error posts as members were figuring out their retrofit along the way. Also, most seem to be LCI, so I am curious: 1.) Will I need to swap to the later DSC with ACC function? The early post from dumitru.o regarding his non-lci e70 diesel successful retrofit, seems to suggest that it was not needed. I recognize that the later DSC with ACC function have extra brake pressure sensors, and I see that all the LCI guys needed it to complete their retrofit. I understand that I already have SA544(cruise with brake function) and will not need to replace the KOMBI and should have 34516865025 for my current DSC. Since the ACC stop and go has been available before my car's build date, I would guess there's a chance, but understand too if I need to get the updated DSC. 2.) Will non-LCI require replacement of the junction box and footwell module to JBBF3R and FRM3R? I also have old CCC system, never considered CIC retrofit because I just added an android unit and screen. Can CCC be coded for $5DF, is it even required to code the CCC? Once my new account limitations have subsided I plan to message dumitru.o, hope he has access to stuff at a better rate than current ebay offerings. Any help clearing up my confusion of DSC for non-LCI cars would be greatly appreciated!! Thanks! blue9mustang@yahoo.com |
08-06-2022, 02:13 AM | #81 |
coding BMW.....
490
Rep 890
Hi
You need to replace both the DSC (with an ACC version ) and the junction box with one from LCI. I still have some parts for this retrofit which might help you: ACC radar sensor, rear PDC wiring for the RPDC, LDM module. Unfortunately the wiring for ACC retrofit has been sold but it can be rebuilt Prices on eBay are always higher because lots of fees needs to be paid to eBay |
12-27-2022, 11:05 AM | #82 |
66
Rep 105
Hi I’ve read this thread multiple times but I am still confused on what parts are needed to retrofit ACC + Stop&Go ($5DF) to an LCI E70 (build date 02/2013). This is what I was able to gather:
New dsc unit with pressure sensors 34516854707 FRR70 radar sensor LDM unit SZL stalk with acc controls Are new FRM and JBBF needed? |
12-27-2022, 03:45 PM | #84 |
66
Rep 105
Ok thank you for confirming. Do you happen to have the wiring diagrams needed to complete this retrofit?
Also is the LDM the same thing as acc control unit or are they 2 separate things? Last edited by AshwinLB; 12-27-2022 at 04:16 PM.. Reason: Additional question |
04-08-2023, 10:12 PM | #87 |
Rep 2
