XBimmers.com | BMW X6 Forum X5 Forum
TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Engine / Exhaust / Drivetrain Modification
      12-14-2021, 12:00 AM   #23
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
797
Drives: BMW M3 JB 04 Coupe
Originally Posted by Ebtahi98 View Post
No no / ABSOLUTELY NOT !!!! / these would
Be diff name and etc ! / I absolutely agree! / this would be a small closed club not mass volume
Any updates on this?
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
      12-15-2021, 01:53 PM   #24
m5james
m5james's Avatar
432
Drives: '10 X5M Alpine White on Sakhir
Originally Posted by TTV8M View Post
found these:
https://autotalent.com/products/afe-...c5771c08&_ss=r
looks a little cheesy tho
Wrong body style.
      12-19-2021, 08:07 PM   #25
9vapors
654
Drives: CB X5M
I had mine for the E70 made with some oval piping I bought on eBay… they certainly could have been prettier, if I had any welding skills I just pie cut them much nicer, but even with the silicone elbows etc, it was still under $500…
Appreciate 3
      12-25-2021, 10:40 AM   #26
Ebtahi98
Ebtahi98's Avatar
44
Drives: BMW13E70X5M720?hpAudi2003RS66+
2018 BMW  [0.00]
1989/2000/2006/2018 ...  [0.00]
2004 Audi RS6   [0.00]
2002 BMW Z8  [10.00]
This fits well and clears my hood, what you can't see are the two air intakes that literally like suck air the way they're positioned in the kidneys that go through the M (gutted) air box / probably provides a little-5-10hp / to no power increase but the sounds are worth it ! (Non super oiled - I use these just barely oiled) I have another style similar to the way that Gentlemens were welded it just didn't sit right.
      12-27-2021, 10:32 AM   #27
Dawgz
2022 M4 Comp Xdrive
1023
Drives: 2022 M4 Comp Xdrive
This is probably robbing power by taking in hot air rather than cold air as the stock system at least does.
      12-27-2021, 10:37 AM   #28
0-60Motorsports
Bahrain
797
I agree with the above that this is going to be heat soaking big time in the summer. All those noises you here etc it's the only positive side of that setup otherwise you are 100% losing power.
Current Mods:
IG: @060Motorsports
      01-12-2022, 07:22 PM   #29
Ebtahi98
Ebtahi98's Avatar
44
2018 BMW  [0.00]
2002 BMW Z8  [10.00]
I've logged the temperatures under the hood I have scoops under the M intake the stock box that has been hollowed out it's actually not that bad
      01-13-2022, 10:23 AM   #30
imschwaggy
Drives: e36
if u end up making a new set, or anything ill buy your old ones .
      01-13-2022, 03:41 PM   #31
m5james
m5james's Avatar
432
I'll agree with others that you're sucking in a lot of hot air. As for oiling, we don't have a MAF so it doesn't really matter.
      01-17-2022, 02:02 PM   #32
Ebtahi98
Ebtahi98's Avatar
44
2018 BMW  [0.00]
2002 BMW Z8  [10.00]
I definitely am sucking in some hot air but when I log it's not as terrible as you think but I won't give it up for the wonderful sounds I had a different type of filter in a little different set up in there before this works beautifully and according to the logs which I can take a screenshot of then again I am in the northeast and it is winter - come the warm weather again I'll show you it's not as terrible as you think but like I said with the scoops under where you have the two air inlets for the airbox without those scoops you're gonna go up about 15°- 20° EASY !
xbimmers
