04-05-2024, 12:48 PM | #1 |
11
Rep 26
325ci e46 - Brake pedal to the floor after spinning
Hi.
I tried to drift my e46 (it has a locking diff and a manual) After being spun, the brake pedal becomes absolutely soft - falls to the floor and the car doesn't brake. If you press it one more time - it becomes firm again like always. I disabled totally the DSC (holding DSC button for 5secs). What can be the problem? Maybe I should take out the ABS fuse before drift training? The brake fluid is fresh and level is ok. |
04-05-2024, 01:04 PM | #2 |
2502
Rep 3,620
I like the line of electronic thinking, but - is there a chance your brake fluid level is low and you momentarily slosh the fluid up to the side and let some air in? I wouldn't think it'd suddenly purge back out right afterwards so probably not, but - maybe check the level?
04-05-2024, 10:06 PM | #3 |
161
Rep 199
Drives: BMW Z4C 3.0si 3 pedal
Could be pad knock back.
04-06-2024, 02:05 PM | #4 |
2347
Rep 5,804
I agree. It sounds like the brake piston(s) are getting pulled back off of the pads and into the caliper while drifting. Getting the pedal back after pumping/bumping the brake pedal once and then works properly again. There’s not much you can do with stock calipers. The usual solution is to install 6 lbf/in anti-knock-back springs behind each piston.
