07-27-2022, 12:46 PM | #23 |
369
Rep 416
Video from a rainy day with the PCA. Took my 2013 F30 to the track and we had a blast passing all day long. Not a single point bye. Intermediate Group.
Enjoy!
Quietly Effective
07-31-2022, 11:45 AM | #24 |
11437
Rep 3,408
07-31-2022, 10:07 PM | #25 |
369
Rep 416
Stock F30 with PS4S tires. The equalizer was the rain. And maybe that I've done a number of track days in rain, not to mention my hardware isn't nearly as costly so running balls out wasn't so scary.
Tracking in the rain is a blast. Don't let a rainy day keep you away. I've owned a couple of P-Cars. Our local PCA puts on some great events.
Quietly Effective
MacklinUSOB518.00 FlorinQCK-2.50 |
08-01-2022, 08:39 PM | #26 | |
518
Rep 891
I had a set of PS4S on the car in, first thing I changed on it, actually. They kicked off my suspension rabbit hole. Living in an apartment I had to run RS4 for drive on/off (NYC). Inferior to the PS4S in the wet, no doubt, but more manageable than the other 200TWs.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
08-02-2022, 09:27 AM | #28 | |
518
Rep 891
Camber is what really changes the game, though. There are even some OEM options for that as well if you want less of a project.
FlorinQCK-2.50 |
08-02-2022, 11:53 AM | #29 | |
261
Rep 666
as for camber, what is the right setup? should i buy the camber plate as well? |
08-02-2022, 01:20 PM | #30 | |
518
Rep 891
If I were to suggest 2 mods alongside a front suspension refresh it would be the Millway Street Camber Plates and the Millway Street thrust arm/tension strut monoballs. Both add very little NVH which is great for a daily, but you get the benefits of camber adjustment on top of the reduced deflection on the thrust arm. I have been running -3/-2 for a while and it has a great balance. Toe you can leave stock, or start getting closer to neutral on the front end. For a more streetable alignment -2/-1.5~ with stock toe raises the limit quite a lot without going too crazy. https://www.millway.se/camber-plates...0-f31-f32.html https://www.millway.se/front-control...w-f20-f30.html
08-02-2022, 01:39 PM | #31 | |
261
Rep 666
damn, everyone on the forum suggest the monoballs, the options are either VAC monoball or millway monoball. i guess i m probably going to get the VAC monoball because it's already pressed in, and just simple removing and install.
the monoball itself is cheaper by its own, but looking at 7 years old age, changing the arm is not a bad idea, i would think... so it can go another 7 years. how about rear suspension? no need to refresh them? Quote:
FlorinQCK-2.50 |
08-02-2022, 03:01 PM | #32 | |
518
Rep 891
https://www.millway.se/front-tension...lemforder.html As for the rear suspension, it typically gets less wear than the front. I am still on stock hardware for the most part on my 2012 and it's still tight and holds alignment well. You could replace the struts, they are pretty easy and inexpensive.
FlorinQCK-2.50 |
08-04-2022, 07:05 PM | #33 |
Check out my Youtube @n55david!
1296
Rep 3,534
Drives: 2017 m240i, 2015 X3 x35i
I'm just here for the dodge hate.. I love it
Yeah IC is a must even on a stock car etc
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
