02-23-2021, 04:09 PM | #45 |
356
Rep 361
Another thing I noticed with these coilovers recently... even with the GC "street" camber plates with bearing mount... I can hear some noise when turning the wheel while at low speeds / parking. Not quite as loud as the normal spring binding you would hear with some coilovers. I suspect its the bottom of the spring rubbing on that blue plastic ring above the height adjustment collars. It's not very loud but just curious if anyone else with B16s notices this.
03-25-2021, 10:23 PM | #46 |
1343
Rep 1,881
anybody running aftermarket sway bay end links with these? i am finally installing today after having these sit for 1.5yrs, and realized i cant run the Bimmerworld end links i bought.
Is there an aftermarket adj end link that is made to work with oem style strut (domed ball joint connector)? |
03-25-2021, 11:03 PM | #47 | |
356
Rep 361
https://www.bimmerworld.com/Suspensi...pter-Pair.html |
03-26-2021, 03:59 AM | #48 | |
1343
Rep 1,881
04-02-2021, 03:31 PM | #49 |
1343
Rep 1,881
so I was able to source spherical domed washers to use Aftermarket end links on oem/Bilstein struts. i ordered a few extras, if anybody needs them let me know, $12/shipped for a pair.
i used these to mount Bimmerworld adj end links, worked perfect. |
04-03-2021, 06:02 PM | #50 | |
552
Rep 580
also, just want to confirm, when u go full SOFT, is the dial "raising" up? The blue dial and the blue stop pin collar are confusing to me. For fronts, i made two full turns from bottom. For rears, i had only two full turns from bottom as well, and is sitting way too high at the moment. Going to make 3 more turns tonight and see what it goes.
Current - 2011 E90 M3, Jet Black, 6MT ZCP. Recaro/Bilstein/BBS/StopTech/Haimus/Turner/Pinnacle/BE/Auto Solutions/Macht Schnell/GC/Whiteline/Slon/Alpine
Sold - 2008 E92 M3, AW x FR, 6MT. CF roof is oh-so-Sexy! IG @misterclutch888 Slow Build |
04-25-2021, 10:09 PM | #51 | |
Mmmmmmmm
14
Rep 40
How much space do you have up front between the b16 coilovers and the inside edge of the wheel/tire? Are you running any spacers? Thanks. |
04-26-2021, 09:01 AM | #52 | |
356
Rep 361
I'm not running any front spacers, just 12mm on the rear (but I had those prior to the coilovers). The front is close but I don't see any evidence that it has actually rubbed on the inside. This is after tracking the car as well. I might add a 5mm spacer just for extra clearance but it's not an issue yet. Keep in mind these are 265/35r18 Federal 595 RS-Pro which are nearly as wide as some other brands in 275. And here is an updated pic of the car now that it has settled a little. |
04-26-2021, 11:53 AM | #53 | |
Mmmmmmmm
14
Rep 40
Awesome thanks so much for the help! I think these are going to be my next upgrade. |
04-27-2021, 01:53 PM | #54 |
552
Rep 580
Installed mine few weeks ago, havent driven it much. Going to adjust the height and alignment again once i put some mileage on it.
Question, do u guys find it bumpy even at 5/10 for both front and rear?
04-27-2021, 03:01 PM | #55 |
Save the manuals!
6028
Rep 6,754
This thread is about the Damptronic (aka EDC compatible) version, not the B16 PSS manually adjustable ones so you may not find that answer here.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
05-06-2021, 02:30 PM | #58 |
356
Rep 361
05-07-2021, 12:11 AM | #60 |
1343
Rep 1,881
i was also confused for a second, this thread is about b16 DAMPTRONIC coilovers.
05-10-2021, 01:06 PM | #61 |
1074
Rep 1,025
If you really want to track the car the Damptronic is going to be leaving you desiring for more. I had them on my car prior to changing to a MCS 2-way setup and when really pushed you can't compare. For a daily/weekend cruiser though I think the Damptronic is the best option for an EDC equipped car.
Steve::::2012 AW E92::::IG - @sjs0433
05-15-2021, 06:25 PM | #62 |
Save the manuals!
6028
Rep 6,754
Good clearance up front with 265/35/18 Hankook RS4 and 18x9.5 ET25 Titan7 TS-5. Should be able to run 275/35 easily without needing a space. This is with the adjusters set to 3 coils from the bottom.
07-13-2023, 03:16 PM | #63 |
31
Rep 35
Reviving an old thread.
Just got this set in and am looking to order some ground control camber plates. https://groundcontrolstore.com/colle...t-camber-plate Does anyone know what the spring inner diameter is for the Damptronics? |
03-19-2024, 07:55 AM | #64 |
166
Rep 420
Reviving an old thread. B16 on order with millway camber plates will post a review once done.
Andreweatstacos68.50 |
