08-25-2019, 06:21 PM | #23 |
17
Rep 91
Drives: 2016 340i
Finished mine a couple weekends ago. Used an M-style pair off Amazon and was not happy with the quality. Actually saw some CF splitting on some of the edges. Swapped out for a pair from ebay which was much better build quality. Substantial use of CF and clear coat. I also liked the subtle difference of the M-style wing extension.
Random byproduct though, my passenger side mirror no longer tilts down when put in Reverse, it tilts inward and does not return. Not sure what could have caused this, the mirror controls work perfectly fine. I'll report back if I fix it in case others encounter it. Also, one piece of missing info from the original writeup (which was suuper helpful) was the removal of the center tilt control module. The silver screw in the center needs to be removed and then you can pull the unit straight out with a little wiggling and force. It pushes right back in. Be careful when reinserting the silver screw, as it threads into soft plastic and is easy to strip. If you take your time, everything comes apart easy and goes back together nicely. {Photo upload not working} Last edited by evermire; 08-27-2019 at 11:20 PM.. |
VipinLJ1944.50 |
08-30-2019, 09:26 PM | #24 | |
125
Rep 184
///M340i Portimão
My Exes: E36, E46, F30 |
09-01-2019, 07:08 PM | #25 |
17
Rep 91
Drives: 2016 340i
09-08-2019, 10:25 PM | #26 | |
69
Rep 111
2022 BMW ///540i xDrive Bernina Grey Metallic Amber Effect
2019 BMW X5 40i ///M-Sport (Recalled) Mineral White Metallic 2011 Porsche Panamera Turbo S (Sold) Basalt Black Metallic 2009 BMW X6 50i Dinan (Sold) Alpine White 2003 BMW ///M3 (Sold) Laguna Seca Blue | 1995 BMW ///M3 (Sold) Santorini Blue II |
12-13-2019, 07:15 PM | #28 | |
208
Rep 547
I was actually able to do the install in a different way that saved a bunch of steps and completely avoiding taking the glass out. Props to this guy for showing this method: Tried my best to take pictures but all I did was first tilt the mirrors all the way down and right (driver) left (passenger). Then I stuck a small slim flathead screwdriver in the gap between the black bezel and the glass and pushed the top tab up and the bottom one down while applying outward pressure with my left hand. Once the top gets release I stuck a pry tool at the bottom corner next to the camera and pried it out. Got the passenger side cap off without breaking any clips and I just broke one clip on driver side. Super easy and took me 10 minutes to do each side.
Current: 2020 M340xi Previous: 2016 340xi |
01-29-2020, 12:33 PM | #30 |
160
Rep 170
02-06-2020, 05:35 PM | #31 |
69
Rep 111
I'll take a few more pictures and posted shortly
02-22-2020, 01:07 PM | #32 |
393
Rep 1,041
03-21-2020, 11:40 PM | #33 | ||
167
Rep 1,222
05-07-2020, 09:54 AM | #34 | |||
37
Rep 58
G20 M340i portimao blue
05-07-2020, 10:12 AM | #35 | ||||
167
Rep 1,222
PortimaoMystique37.00 |
05-07-2020, 10:15 AM | #36 | |||||
37
Rep 58
05-07-2020, 10:39 PM | #37 | |
208
Rep 547
And those are pretty similar to the ones I have. Different ebay seller but probably the same supplier. 5 months in and mine are doing pretty well.
05-10-2020, 07:26 PM | #38 |
37
Rep 58
Welp. Finally got around to placing the mirror caps. Unfortunately the fit on the driver side one is not too satisfactory even after I removed and replaced 5-6 times. Seems to be a quality control issue but it's expected given $150 eBay ones. The passenger side looks great tho and seems to be on there pretty solid! I've contacted the eBay dealer and can hopefully get a replacement
[IMG][/IMG]
05-14-2020, 10:44 PM | #39 | |
203
Rep 371
Tried my best to take pictures but all I did was first tilt the mirrors all the way down and right (driver) left (passenger). Then I stuck a small slim flathead screwdriver in the gap between the black bezel and the glass and pushed the top tab up and the bottom one down while applying outward pressure with my left hand. Once the top gets release I stuck a pry tool at the bottom corner next to the camera and pried it out. Got the passenger side cap off without breaking any clips and I just broke one clip on driver side. Super easy and took me 10 minutes to do each side. So you managed taking them off following this guide? Thank you ! |
05-15-2020, 01:48 PM | #40 |
393
Rep 1,041
02-14-2022, 10:16 PM | #43 |
218
Rep 412
I don't think they make one. You'd have to get a custom over lay made or send the mirror to someone to skin it in real CF, clearcoat it.
2020 M340i xDrive - Mineral Grey Metallic/Cognac - MG Flasher Stage 2 OTS 93 | XHP Stage 3 | AA DP | Valvemaster | MST
2008 Infiniti G37S Coupe 6MT - Black/Black IG: jpowers36 |
04-12-2023, 06:28 PM | #44 | |
114
Rep 110
Drives: 440i GC, 650i GC, i7 xDrive60
