BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
Mporium BMW
      07-24-2008, 10:20 AM   #45
evosport
evosport's Avatar
Drives: M3 CSL Cab
Originally Posted by slammedm3 View Post
Thanks for the replies,
Quick question for you, are you guys planning on coming out with a Short Shifter Kit for the E9x M3?
We use AutoSolutions short shifter kits as a rule. I am hopeful we will see a kit very soon.
Originally Posted by mvagusta View Post
these guy's want your business and thay care about how thay are being judged on there product'ssThay don't have to do this on this board.. The reason why is thay really care on what we think....And i don't think that we would make them rich on buying pulley's.. I needed to say something because i own a business and i can understand on what there doing...When your heart is set on something that you like doing it really show's...Brad your good... I'll be buying... I bought your bumper markers and thay were perfect... thank's...
Thanks! It is great to see people that understand!
Originally Posted by lucid View Post
Thanks for the answers Brad.
I am not saying BMW engineers are maximizing performance at all costs. Actually, that's why I mentioned "trade-off". They are maximizing performance against competing criteria such as emissions, durability, everyday drivability, etc.
What I am taking away from your answer is that the car might run into some cooling and charging issues if it is operated at low rpms for an extended period of time.
One last question: have you taken an E9X M3 equiped with your product to the track? If you did, what oil temp did it reach after about 25 minutes of hard driving? I am still trying to understand why cooling would not be an issue even at higher vehicle/engine speeds if the car is pushed really hard. It's not as if the stock setup simply stays pinned at 210 degrees. Mine was running at around 255 on a tight track with a relatively short straight. So, why would under-driving the water pump not result in less cooling in those conditions? Are you saying that the water pump cativates at those engine speeds and does not function optimally in the stock setup to begin with so slowing it down doesn't result in less cooling at high revs?
Well this last weekend at Buttonwillow, 3 stock cars went into limp due to oil temps too high - and these are stock cars. I have not done any data logging further then that on track.
However, YES, BMW engineers the water pump to have an the most effective range at lower RPM. So on track, you very easily could have a cavitation issue. This is the case on every other modern BMW we have data-logged. We will be data-logging on the e92 shortly.
Cavitation has nothing to do with straights or turns, it has only to do with RPM.
Yes, exactly. Again, this has been the case on every other prior modern M car (e36, e46, e39, e60). We will be data-logging an e92 as soon as possible, but I would expect it to be the same.
Originally Posted by ChitownM3 View Post
I think I'll be adding this mod to my list sometime next year. Cheap horsepower, I'm all for it!
Thanks!
Originally Posted by CatchM3 View Post
good responses. I'll be placing an order soon
Thanks!
Originally Posted by nd54 View Post
I accept the challenge Brad. I will fly down to Southern California to do the test. However the following conditions must be met by your company:
1. We use my car, which is in Socal right now. It is completely stock, a software flash may have been done but I can have the ecu flashed back to stock.
2. We use a shop of my choice, with a dyno I choose. This will be a neutral location for both of us.
3. You can supply the pulley kit, however none of your staff is allowed to install the kit or be anywhere near the dyno for the duration of the test.
The wager remains the same. If there is indeed a 21bhp gain I will issue an apology and pay for the trip, dyno costs, install etc... If the gain is less than 21bhp your company will pay for the installation and removal, dyno testing, my hotel and flights. Let me know so I can make flight arrangements and book some time off.
OK, but if you are serious, then email or PM me. Your conditions are not acceptable as is.
1. your car is fine.
2. as long as it is a dyno-jet 248c (same dyno to see same results) and is not a competitor (must remove bias) - we must agree on the shop
3. why would I allow something to be installed by someone that may or may not know what they are doing? How would us installing the kit lead to any artificial gain? This is just a silly point.
4. The results must be within a range of +/- some percentage. Every car is not exactly the same. That is why we show REAL results on a car, and in fact I will have dyno runs soon from two other nationally known BMW shops on the east coast (Turner and BimmerWorld - where you can also buy this kit from). Just like with software (you said your car may have software), did you get the exact gains they claim? Typically there is a 10-20% variance from car to car (sometimes more). This is well documented by everyone in the industry from BMW to the entry-level tuner.
Again, if you are serious, then I am 100% a go, I would not make a challenge that we were not up for. We just need to agree to conditions that do not set us up to fail. I am a bit smarter then that.
Thanks everyone (well almost everyone, j/k)!
Thanks
Brad
      07-24-2008, 10:26 AM   #46
lucid
lucid's Avatar
374
Drives: E30 M3; Expedition
Are you referring to 3 stock E9X M3s here? If so, interesting information.
Please let us know when you have the data.
Yes, of course cavitation has nothing to do with track layout. I know that. But air flow, and consequently, cooling, does. What I mean is that I am concerned about what will happen to my car when pushed hard on a track that does not allow for much cooling (relatively speaking) and oil temperature run high.
Just to clarify, I am not trying to give you a hard time. I am skeptical with these kinds of things general, and would like to understand the issues and see the relevant data before buying into an aftermarket product. Looking forward to learning about what you guys find out/log.
Thanks.
      07-24-2008, 10:30 AM   #47
evosport
evosport's Avatar
Drives: M3 CSL Cab
Are you referring to 3 stock E9X M3s here? If so, interesting information. Thanks.
Yes. I think one was DSG and two were manual. I heard from the instructors in two and one was owned by a club racer (we were there racing)
Of course! That is what we do. We spend a LOT of time collecting data. Again, anyone local can come by and see us!
Yep, that is correct.
Thanks
Brad
      07-24-2008, 10:38 AM   #48
nd54
76
Drives: RDSport RS 46
I'll PM you later today to make arrangements, however I absolutely will not use any Dynojet model, this is the most important condition. A pulley install is supposed to be straightforward and takes less than an hour, there is no reason for your staff to install it. How about we agree on 15% variation, roughly 18-24bhp?
I think that the above conditions represent a fair real life test, not everyone will use a Dynojet 248c to test their car (I never would), and most people won't be able to use your tech for the install.
Let me know if this is ok, I'm looking forward to it. Any excuse to go to Socal...
Thanks
Brad
      07-24-2008, 10:46 AM   #49
evosport
evosport's Avatar
Drives: M3 CSL Cab
If you are going to challenge me on the results, call them BS - you need to be able to use the SAME equipment.
You obviously know that every brand of dyno reads differently. Depending on the brand, the variation could be 50% less or 50% more gain.
A dynojet 248c is the most commonly used dyno nationwide to test cars for numbers. We use it for this reason. You CAN go to a dynojet 248c ANYWHERE in the US and get a number that is within 5% of any other dynojet. Two magazines have done this exact test in the last few years.
You called us out, I replied. If you want to take the challenge, then it will only be using the SAME equipment, that is the only way to guarantee parity and fairness.
If you change your mind, let me know.
FYI, the pulley install is about 4 hours (I was basing 2 hours off the M5 install - but this is more involved). It is done from above and below the car, not above like previous model M3's. You must remove the lower under panels, remove the airbox, remove the fan, remove one of the idler pulleys. Then when you are done, you have to replace all of those items. You MIGHT be able to do it quicker, but we choose not to RUSH on $70K+ cars - not worth scratching or damaging or not installing something correctly. We will provide complete instructions to do this.
thanks
brad
      07-24-2008, 10:47 AM   #50
SlammedR8
SlammedR8's Avatar
521
Drives: 2019 X5 40i/2020 R8 V10 Spyder
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather
2020 Range Rover HSE - Black/Black
2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black
      07-24-2008, 10:48 AM   #51
KonigsTiger
Racying Dynamics
KonigsTiger's Avatar
118
Drives: E92M3 RS46 Club Sport, others
I'm certain you can get a few hp out of a pulley but can't see how that would not affect A/C or anything AT ALL. Has to affect something. Now, the effect may be so minimal that one should not care, but I would let someone else do it and test it first.
      07-24-2008, 10:50 AM   #52
evosport
evosport's Avatar
Drives: M3 CSL Cab
I hear ya, but please realize that the V8 M3 motor is essentially the same as the V10 M5 motor less 2cyl. Especially on the front. The accessories, etc - and we have been running pulleys on the v10 since the release of that motor. Just an FYI.
thanks
Brad
      07-24-2008, 10:54 AM   #53
SlammedR8
SlammedR8's Avatar
521
Im running the Rogue Pulleys, and there is absolutley no drawback/negative.
Doesnt affect A/C or anything AT ALL
Current:
      07-24-2008, 11:01 AM   #54
lucid
lucid's Avatar
374
He did say it would affect cooling and charging if you run the engine at low revs for extended periods of time, as in stuck in a traffic jam maybe? Cooling and charging are the real issues to look out for.
I wouldn't worry about the A/C. The A/C compressor will not be on all the time unless you are driving around at noon in the middle of the desert. Even if you do that, and the compressor needs to run all the time, it shouldn't damage the compressor or the A/C system. You'll just get a little less cold air in the cabin. And I guess the compressor might not be running at peak efficiency (I must assume it is designed to run at a specific rotational speed which would change with the pulley), which might mean slightly higher fuel consumption, but it would be a rather small difference I would guess. Just a guess though.
      07-24-2008, 11:08 AM   #55
JEllis
JEllis's Avatar
532
Drives: E36 M3, E92 M3
Thanks!
Thanks!
Thanks
Brad
Overheating M3's? First time I have heard of this.... expected you to say they were 335i's....
Jason
http://www.m3post.com/forums/signaturepics/sigpic14547_7.gif
Instagram: jellismotorwerks
      07-24-2008, 11:10 AM   #56
CatchM3
CatchM3's Avatar
260
Drives: 2020 X6M Competition DG
2008 E90 M3  [9.00]
2020 X6M Competition // Donington Grey // Executive Package// Bower and Wilkins Sound System // Driver Assistance Package // CF Trim
      07-24-2008, 11:11 AM   #57
lucid
lucid's Avatar
374
Jason
Well, he said they were being raced, so I am not surprised. An additional oil cooler should solve the problem. I think that's a pretty common mod with E36 M3s that are being tracked hard/raced.
      07-24-2008, 11:14 AM   #58
evosport
evosport's Avatar
Drives: M3 CSL Cab
Tracked in the drivers school, but yes, driven hard.
      07-24-2008, 11:15 AM   #59
T Bone
T Bone's Avatar
532
Drives: 2008 335xi Coupe
First of all Brad and Simon are stand up guys and Evosport is good company.....
I just think there are some questions that people have on this specific product. In my experience with the pulleys on the M6:
  • I took issue with the pricing - a pulley on a BMW is 4-5X price of a domestic - but this is just personal and non-relevant opinion to performance
  • I just didn't see real world performance with my pulleys but I did see slightly higher oil temps
I had the pulleys on my M6 last year when I went to Mosport in my M6. I have gone again this year, with the stock pulleys. There is a long uphill straight at Mosport. There was no appreciable difference in speeds at the end of the straight. With the pulleys, the car did run hotter.
I have no doubt that the dynos show these results. And my buttt dyno may be miscalibrated. But can you corroberate with some trap speeds at the dragstrip with all things being equal except the pulleys?
ND54, props.....go visit!
"Aerodynamics are for people who cannot build engines"......Enzo Ferrari
      07-24-2008, 11:17 AM   #60
lucid
lucid's Avatar
374
Do you know what oil temps they were running when they went into limp mode? There are 3 reports on the M3s on the forum, including mine, which reached 255 on hot summer days at the track that did not limp, so I am curious as to where the trigger point is. 275 maybe?
      07-24-2008, 11:23 AM   #61
lucid
lucid's Avatar
374
How much hotter to be specific?
      07-24-2008, 11:32 AM   #62
T Bone
T Bone's Avatar
532
Putting around town with the stock pulleys, the oil temp was a needlewidth cooler than the middle meatball
Putting around town with the Evosport pulleys, the oil temp was a needwidth warmer than the middle meatball
Around the track with stock pulleys, the temp was between the middle and other meatball.
Around the track with the Evosport pulleys, the temp was slightly higher and closer to the second meatball.
Sorry unscientific but noticable. No limps in the M6
      07-24-2008, 11:37 AM   #63
lucid
lucid's Avatar
374
What, you don't have a digital oil temp gauge installed on your dash!!!
All this time, I thought you knew what you were doing!
Now, can you please tell me what the numbers above the three meatballs are on the M6? Same as the M3?
      07-24-2008, 11:44 AM   #64
T Bone
T Bone's Avatar
532
As you can see with civilized Metric societies, we have very clean instrument clusters. See the middle 3 meatballs for reference.
Middle meatball is 100 degrees C not sure if the scale is linear.
      07-24-2008, 12:03 PM   #65
KonigsTiger
Racying Dynamics
118
I don't see anything different to my M3 other than the CF. Am I missing something?
      07-24-2008, 12:04 PM   #66
lucid
lucid's Avatar
374
Couldn't agree more on this one. We're totally stuck in the stone age here.
OK. The M3 has the same numbers above the meatballs (in awkard units of course). 120-210-300 F. So the temps you are running in your M6 are pretty much identical to mine in the conditions that you describe in stock form.
m3post
